Bookmark
this site! |
| MEGAsquirt A place to collectively sort out this megasquirt gizmo |
Remove
advertisements today by clicking
here and subscribing. Only $3.50 per month. |
Thread Tools |
#6 | ||
huh is the red setup for the cas pickup? the one with a 1k resistor on it, the part where it goes between d9 and r13 where is the trace from or going to, if you don't mind that is, my board doesn't seem to have a hole there like that. But there is a hole in the board further to the db37 but in the same middle area.
Damn I need better info but I appericate it atleast its a working area to go from. |
#7 | ||
red is tach input, blue is spark out.
post pics, they might have modded the board? http://www.bgsoflex.com/v22/msv22.html http://msextra.com/doc/ms2extra/MS2-Extra_4g63.htm |
#9 | ||
![]() By techsalvager at 2010-07-27 ![]() By techsalvager at 2010-07-27 Apologies of the bad blurriness of them. Anyways I used pin two off the cpu to connect the .1uf cap to. but I'm not sure my 5v pull up for the cmp signal is correct. |
#16 | ||
#17 | ||
| Thread Tools | |
Clubs |
Import |
Domestic |
Other |
