2560 on a 99 motor at 14psi with MSPNP 300hp - 241ft/lbs
Old Jan 3, 2008 | 09:20 PM
paul's Avatar
Default 2560 on a 99 motor at 14psi with MSPNP 300hp - 241ft/lbs
details of build in signature
Attached Thumbnails 2560 on a 99 motor at 14psi with MSPNP 300hp - 241ft/lbs-paul_hp-tq-afr.jpg
Old Jan 3, 2008 | 09:33 PM
ArtieParty's Avatar
lol.... ur really upset that no one commented on it in the other thread arent ya. i told you from the start to make it a new topic.
Old Jan 3, 2008 | 09:36 PM
Saml01's Avatar
Holy **** that is some insane power.
Old Jan 3, 2008 | 09:39 PM
paul's Avatar
didn't realize there was a dyno forum so that's why it's posted. Do you even have a turbo?
Old Jan 3, 2008 | 09:43 PM
ArtieParty's Avatar
you know the deal.... getting my MS in about a month... tuning it... larger injectors.... tuning it... turbo kit.... tuning it....tuning it.....
hoping to have it all in and running by like april/may?
Old Jan 3, 2008 | 09:44 PM
paul's Avatar
and I'm Santa Claus
Old Jan 3, 2008 | 09:48 PM
ArtieParty's Avatar
and I'm Santa Claus
you are a HO HO HO
Old Jan 3, 2008 | 09:55 PM
reddroptop's Avatar
Awesome Paul.
Now post some sweet vids.
Old Jan 3, 2008 | 09:57 PM
miataz's Avatar
is that on stock internals?
Old Jan 3, 2008 | 10:00 PM
paul's Avatar
vids soon. i have a pair of tires i really want to burn up so once this cold snap breaks i will try it.
and yes, stock internals.
Old Jan 3, 2008 | 10:08 PM
miataz's Avatar
**** nice man
Old Jan 3, 2008 | 10:12 PM
Total Cats: 4,368
I should have watched you Monday instead of wrecking mine....
Old Jan 3, 2008 | 10:17 PM
Saml01's Avatar
Holy hell, are those 99's special in some way that they can run that much or is this on borrowed time?
Old Jan 3, 2008 | 10:23 PM
paul's Avatar
the 99's are supposed to handle less due to the higher compression pistons. some say with a good tune it'll be fine. we shall see.
Old Jan 3, 2008 | 10:24 PM
Total Cats: 4,368
it's all about AbsurdFlow©®™♥♪♫
Old Jan 4, 2008 | 12:02 AM
TURNS101's Avatar
Good tune and you should be fine..
The tranny should be nervous though..
Rad numbers bro..
Old Jan 4, 2008 | 12:10 AM
Zabac's Avatar
awesome Paul, nice build indeed
i've heared many times that 1.8's can handle that much power on a good tune fairly well, tranny's become the weak link at those levels
good luck paul, i hope to get there soon
Old Jan 4, 2008 | 05:04 PM
that torque curve is sweet
Old Jan 4, 2008 | 06:25 PM
Total Cats: 4,368
I have a similar dip in torque at 4K (as well as other Megasquirted miatas). Did you start with a DIY timing map and work from there? I suspect we need more timing around there.
can you send me that .drf file?
Old Jan 4, 2008 | 06:32 PM
Loki047's Avatar
Total Cats: -5
More Timing STAT!!!
Stock superflow head?
