TPS Wires
Old Apr 23, 2007 | 02:42 PM
shuiend's Avatar
mkturbo.com
Total Cats: 1,700
Default TPS Wires
Well I redid all my wiring and I am stuck at the last 2 wires. According to the megamanual 22 is the TPS signal and 26 is the 5vref from the tps. I am in a 94 and I do not know which of the 4 wires coming from the TPS is which.
http://www.madracki.com/miata/images/wiring/94sys.pdf
That is the link for the wiring diagram for the 94. Page 8 and 9 have the wiring for the stock harness. Can any one please figure out which wires coming from thew TPS I am supposed to use.
Old Apr 23, 2007 | 02:58 PM
Total Cats: 4,368
if i read correctly:
RED / BLK - Wiper (TPS)
BLK / BLU - Ground
RED - Switch Idle
LTGRN / WHT - 5vref
Old Apr 23, 2007 | 03:13 PM
mschlang's Avatar
I think Scott is right, but you can double check that with a multimeter on the blk/blu and ltgrn/wht wires. You should see voltage changing when you open the throttle.
Old Apr 23, 2007 | 03:42 PM
ecugrad's Avatar
If its pin 26 from the Megasquirt its not 5vref from the tps, its 5v REFERNCE FOR the tps.
Old Apr 23, 2007 | 03:51 PM
richyvrlimited's Avatar
I didn't use the V/ref at all, I just 'tapped' the signal line. works perfect.
when I cut the signal and 5vref line I got ECU resets every time I let off the throttle.
Old Apr 23, 2007 | 04:01 PM
Total Cats: 4,368
maybe the wot switch ***** stuff up?
Old Apr 23, 2007 | 04:23 PM
I also just tapped my lines for the TPS.
Zaphod
47
Oct 26, 2018 11:00 PM
nick470
7
Jun 16, 2017 01:53 PM
slomiata
Oct 7, 2015 01:11 PM
Trent
Oct 1, 2015 12:15 PM
btabor
ECUs and Tuning
10
Sep 28, 2015 05:33 PM
