IAT wire gauge question
Old Feb 20, 2015 | 11:11 AM
tazswing's Avatar
Default IAT wire gauge question
I feel dumb asking this but so goes my ignorance. I need to create a pigtail for the GM IAT sensor to splice into the stock harness for a MS2 on an 04' MSM.
What gauge wire is that OE line? I am assuming that since it is low voltage I really want to have the same wire diameter and length to keep impedance as close to stock as possible.
Thanks.
Old Feb 20, 2015 | 11:39 AM
Total Cats: 4,370
wire. use wire.
Old Feb 20, 2015 | 11:56 AM
tazswing's Avatar
wire. use wire.
Coming from you, based on the 1000+ responses from you I have read in all my research on here that means:
"If the wire gauge is close to the OE lines it should be fine."
Did I get that right?
Old Feb 20, 2015 | 12:09 PM
cyotani's Avatar
Total Cats: 117
Let's assume there is 10 feet of wire from your iat to the ECU.
using 20 gauge wire that's 0.20 ohm of resistance (2 wires x 10 ft leads *.01 ohms per foot).
your IAT sensor has 560 ohm to 7000 ohms operating range.
at 560 ohm or that .2 ohm increase changes your reading by .03%.
at 70000 ohms it's 0.003% change.
So TLDR wire resistance is relatively negligable in an IAT sensor reading for the usual automotive wiring gauges. Just don't use a 40 gauge wire.
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies and wire breaking strength
Old Feb 20, 2015 | 12:16 PM
pdexta's Avatar
Total Cats: 184
I've always just used whatever similarly sized wire I had laying around, then stuffed it in my bunghole and the readings have seemed to be pretty accurate.
Old Feb 20, 2015 | 12:26 PM
Total Cats: 4,370
plus you calibrate the sensor so it doesn't matter.
you could install a 1K resistor inline...
Old Feb 20, 2015 | 03:46 PM
tazswing's Avatar
Thanks, y'all. The calibration will be fine with the MS2, but I will be needing to put the stock IAT back on every two years to pass emissions so I need things running without CEL prior to turning/calibrating the MS.
All that has been said makes sense. Wiring is a whole new world for me; steep learning curve.
Cheers!
Zaphod
47
Oct 26, 2018 11:00 PM
slomiata
Oct 7, 2015 01:11 PM
JesseTheNoob
Sep 30, 2015 02:44 PM
btabor
ECUs and Tuning
10
Sep 28, 2015 05:33 PM
