Wrote a fairly detailed engine removal tutorial
Old Feb 24, 2015 | 01:08 PM
jspadaro's Avatar
Total Cats: 22
Default Wrote a fairly detailed engine removal tutorial
I found a couple of writeups on engine removal, and the haynes manual of course, but they all glossed over some things, especially wire and vacuum line locations.
I wrote up my second engine removal and took as many pictures as I could. I know it's old hat for a lot of guys on this forum, but should still help some people out.
Removing a Miata Engine - Did It Myself
Old Feb 24, 2015 | 01:23 PM
cyotani's Avatar
Total Cats: 117
wow that must have taken you a lot of time to write up. And i know how annoying picture taking is and how much it slows you down. Props given!
My method is remove stuff, try to pull and see whats still attached, remove those items and repeat until it's free.
Old Feb 24, 2015 | 02:23 PM
Monk's Avatar
Total Cats: 617
Bookmarked. Good job.
Old Feb 24, 2015 | 02:24 PM
If you are willing to convert it to a forum post, I would be more then willing to sticky it.
Old Feb 24, 2015 | 04:11 PM
schmoo's Avatar
+1
Old Feb 24, 2015 | 04:37 PM
Total Cats: 4,370
here:
remove things attached to engine.
lift engine.
Old Feb 25, 2015 | 09:11 AM
jspadaro's Avatar
Total Cats: 22
Thanks for the feedback guys, glad it was helpful
Old Feb 25, 2015 | 09:15 AM
here:
lift engine.
trololo
Old Feb 25, 2015 | 09:46 AM
Total Cats: 4,370
Originally Posted by 18psi
trololo
amiwrongdoh?
Old Feb 25, 2015 | 10:01 AM
here:
lift engine.
Look not everyone is as experienced as we are. Some people are a bit slower and need some extra help.
Old Feb 25, 2015 | 10:04 AM
Best part was when he cried about there not being basically the same thing as this, but for his subaru
Old Feb 25, 2015 | 10:18 AM
matthewdesigns's Avatar
Total Cats: 55
Nice writeup. I'll be pulling two Miata engines soon and this is a great overview. Props!
Old Feb 25, 2015 | 03:03 PM
Minty's Avatar
One thing you didn't mention that always helps the first couple times you pull a particular engine is to label every connector you take off. I've never pulled a BP, so idunno if each connector is unique, but there's nothing worse than forgetting where some connector/vacuum line/etc goes and having to experiment. BP's are pretty simple and your guide has tons of pictures for reference, but its always good to have a backup. Same goes for putting bolts/nuts in labeled sandwich bags or similar.
That said, I might be pulling my motor this summer for ease of turbo and coolant reroute installation, so this is definitely getting bookmarked . Thanks!
Old Feb 26, 2015 | 07:59 AM
jspadaro's Avatar
Total Cats: 22
here:
lift engine.
amiwrongdoh?
Old Feb 26, 2015 | 11:30 AM
Total Cats: 1,410
Only thing I've noticed is the cruise control switch and power mirror switch are different colors, but identical. Cruise control switch plugged into the power mirror switch will burn out said power mirror switch. Twice. That was fun to find out.
Engine wise, nothing in the bay is the same. Routing/bolting/securing methods is a different story. Especially if you change anything, special care has to be taken to keep wires away from heat and moving parts, and so that they'll actually reach their intended destination.
Ask Ed though, I can identify any plug out of a 1.6 or NB. And 99% of a NA 1.8s. Which, although Mazda made them for one year more than the 1.6s, I surprisingly see very little of them. Two, in my experience, if IIRC.
stoves
Apr 21, 2016 03:00 PM
90 Turbo
19
Oct 19, 2015 03:23 PM
