MS Labs - Miata Accessories info@mslabs.gr - Custom Megasquirts for your miata
New Enhanced Megasquirt - Teaser pics
Old Oct 3, 2013 | 12:29 AM
  #221
psyber_0ptix's Avatar
Question about a possible setup. I've PM's you before, but set up has changed a bit.
I have a 92 miata, about to get a BP4W.
Is it possible to reassign the CAS wiring to function with a 36-1 crank trigger wheel and use the original 99 cam angle sensor?
I hope to run sequential ignition and injection
Old Oct 3, 2013 | 03:18 AM
  #222
Reverant's Avatar
Total Cats: 369
Yes.
Old Oct 8, 2013 | 11:34 PM
  #223
k24madness's Avatar
Total Cats: 95
Edit....Posted in wrong thread.
Old Feb 24, 2014 | 01:25 PM
  #224
mrmonk7663's Avatar
Updates?
Old Feb 25, 2014 | 05:23 AM
  #225
Reverant's Avatar
Total Cats: 369
Its on my car undergoing long term testing. This is going to be a top notch (and mind you, expensive) ECU, so I want it to be 100% perfect in every single way.
Old Feb 25, 2014 | 06:41 PM
  #226
mrmonk7663's Avatar
Fair enough. Do you have an estimate on a release date at least? And will VVT control be integrated for the 01-05s? One other thing...do you have a website that details all the stuff you sell. I couldn't find it if you do. Thanks.
Old Feb 25, 2014 | 07:14 PM
  #227
joyrider's Avatar
http://www.mslabs.gr/mslc.html
From ms3 basic thread, which by the way is really impressive for the low price tag.
I really love SD card logging and RTC, so much win in a little box!
Old Sep 22, 2015 | 02:51 AM
  #228
Barton's Avatar
Total Cats: 58
Hey Rev will this module read the data from an Innovate TC-4 daisy chained with a LC-2 wideband?
Old Sep 22, 2015 | 02:53 AM
  #229
Reverant's Avatar
Total Cats: 369
No, although the ECU does have 1 EGT port on it. If you want to input 4 EGTs, you can use our 4 channel EGT expander.
Old Nov 27, 2015 | 05:44 PM
  #230
pmhellings's Avatar
Total Cats: 18
Any updates on the newest MS3 Enhanced?
Old Dec 12, 2015 | 01:15 PM
  #231
Reverant's Avatar
Total Cats: 369
Long time, no update.
The Enhanced MS3 "core" ECU has been running on my car for a comfortably long time now.
The latest update added the holy grail: Electrical load idle-up. Switch on the headlights at idle, set the heater fan to 4, switch on the rear defroster? No idle droop.
I've also added the iMFD output. Hookup a PLX iMFD gauge (DM-6, DM-100, DM-200), and you can watch any of these variables on your gauge(s):
- RPM
- AFR
- MAP
- CLT
- IAT
- TPS
- VSS
- Timing
- Knock input (scaled from 0-100% in the ECU, to 0-5V that the DM-6 expects to see)
- Short Term Fuel Trim
- Volts
- EGT *
- Oil pressure *
- Oil temperature *
- One more fluid pressure (fuel pressure or coolant pressue) *
* Additional sensors required of course!
Leave a poscat 5 Leave a negcat
Old Dec 12, 2015 | 01:29 PM
  #232
Total Cats: 1,924
So much awesome.
Old Dec 14, 2015 | 04:02 AM
  #233
Zaphod's Avatar
Total Cats: 106
Originally Posted by EO2K
So much awesome.
+1 --> 1000 virtual props ---> wait we got the props back - real prop given... ;-)
Old May 8, 2016 | 11:54 PM
  #234
Ivan's Avatar
Total Cats: -2
Will the MS3 Basic still not be upgradable to the MS3 Enhanced?
Old May 9, 2016 | 09:01 AM
  #235
Reverant's Avatar
Total Cats: 369
It's upgradeable by changing motherboards.
Old May 9, 2016 | 10:02 AM
  #236
Is this using a custom firmware?
Old May 9, 2016 | 10:03 AM
  #237
Reverant's Avatar
Total Cats: 369
No, stock firmware.
Old May 11, 2016 | 02:19 AM
  #238
Zaphod's Avatar
Total Cats: 106
... and will be available when..? not available = no
Old May 11, 2016 | 04:03 AM
  #239
Reverant's Avatar
Total Cats: 369
Selective availability for the 01-05, upcoming for the 90-93/94-95.
Old May 11, 2016 | 06:28 AM
  #240
Zaphod's Avatar
Total Cats: 106
the moment when you realize that you have got a 99-00...
