Trackspeed's '02SE "Acamas" - EFR6758, TSE motor, 500whp or bust
Old May 18, 2016 | 09:19 PM
  #221
Total Cats: 1,870
Make sure to set the baseline ethanol percentage. Its in the flex sensor menu. If you leave it at zero then your baseline pump will be read as E10(ish) and will have some of the blending happening.
Old May 18, 2016 | 09:29 PM
  #222
I set up my blending curve so that everything below 10% uses VE1 exclusively before I retuned the car with the flex system active. I'm going to set it up so that everything above 70% uses the alternate tables exclusively.
Actually, when I was getting the error, I had it set up to only use the alternate tables exclusively if the sensor read above 100%. I wonder if VEAL will tweak on VE3 with a 75% blend if I set the blending table up so that 70% Ethanol = 100% VE3?
Old May 18, 2016 | 10:13 PM
  #223
Nope. It won't even tweak on VE1 - it gives me an Overrun condition exclusion even during steady cruise. I remember reading something about that on MSExtra...
Old May 19, 2016 | 01:47 AM
  #224
Total Cats: 1,870
Interesting. I would just tune VE1 with a modified req fuel. Them copy paste.
Old May 19, 2016 | 03:27 AM
  #225
Might be easier to just set Baseline Ethanol % to 80% instead of dicking with req.fuel.
Old May 19, 2016 | 05:24 PM
  #226
Filled the tank completely with E85 this afternoon and ethanol content is up to ~78%. Pretty happy with that for unaltered pump E85. I will try the other "local" station next time I need a fillup to see what their blend is like.
The Overrun issue from last night must have been something else. I was able to simply turn the table switching for fuel and AFR targets off and autotune happily cranked away on VE1 without a care in the world. I will get the tune dialed in fairly close, set my blending curve to switch to VE3 fully by 70%EC (ethanol content), then drop this map into VE3, drop my old gas map into VE1, and I'll be done. At the same gasoline AFRs, VE3 wants to be about 5% lower above 90kpa, ~10% leaner between 40kpa and 90kpa, and 15-20% leaner at idle. That makes sense from what I remember about fuel multipliers for E85.
Hey @18psi, where do coldstarts on E85 really start to become an issue? I ran Theseus on E85 for a while, but I was never forced to coldstart that car. The '02 cranked for a few more seconds than normal this morning, but it did fire up on the first hit. I have my cranking fuel maps loaded into the E85 position for now, so it's just running cranking/warmup/enrichments off of my gas numbers with a flat ~143% multiplier across the board for now.
All in all, this has been a really easy process.
Old May 19, 2016 | 05:47 PM
  #227
Total Cats: 888
...until you need to bring a pair of 55 gallon drums of the stuff to Laguna with you in October.
Old May 19, 2016 | 05:49 PM
  #228
Total Cats: 1,924
That's why he has that big *** gold chebby.
Monterey County needs some god damn E85 before I'm willing to make the leap. I've got all the hardware and none of the motivation.
Old May 19, 2016 | 06:01 PM
  #229
That event is special, though. I'll probably bring 30 gallons in jugs and just switch back to gas on Sunday if I run out. My plan is to run track days on a pump/race blend so I don't have to hassle with E85. The flex fuel is just for general daily debauchery.
Old May 19, 2016 | 06:16 PM
  #230
If I had to guesstimate, I'd say anything below 60F starts needing some fiddling to dial in.
Old May 19, 2016 | 08:20 PM
  #231
Total Cats: 593
Marin County needs some god damn E85 before I'm willing to make the leap. I've got all the hardware and none of the motivation.
Sorry for the edit but,
This.
Old Aug 25, 2016 | 02:02 AM
  #232
Total Cats: 1,870
Did the 6758 ever get installed?
Old Sep 5, 2016 | 10:26 PM
  #233
I finally got it in this weekend (along with a forged longblock, ID1000s, squaretop, and new proto clutch parts).
Initial impressions are that it is a tiny bit laggier and a tiny bit less responsive. Essentially exactly what I was expecting. It's hard to pin down exactly how much of that is the turbo (5mm larger compressor, same turbine) and how much is the motor (8.6:1 instead of 10:1). I will say that it's far, far more responsive than something like an FM2R setup. The turbo noises are about a million times better when broadcast through the larger inlet. It sounds like a big-turbo Supra or something equally crazy.
I still need to swap in a Fuelab FPR, DW300, and D585 coils before I'm ready to turn up the power, but I need to get the motor fully broken in first. The next 500 miles are going to be agonizing
Old Sep 6, 2016 | 01:28 AM
  #234
Total Cats: 1,870
Ooooh. Videos plz. I want to hear the noises. I cannot wait to get mine up and running.
What is your break in procedure?
Need any LS coil brackets?
Old Sep 6, 2016 | 02:56 AM
  #235
99mx5's Avatar
Total Cats: 526
The cooling system was also on the ragged edge of acceptable. This is my first attempt at making a 200whp turbo car work on track with a full air conditioning system, and it's proving to be quite the challenge. Adding a reroute, dedicated radiator duct, and 14" SPAL fan helped substantially, but I was still limited to 3 laps before a full cool-down lap was required. I think the next steps are a fully shrouded SPAL fan setup, converting to E85, and swapping the tired old A/C condensor with either a new OEM unit or potentially a smaller custom unit that doesn't block so much of the airflow to the radiator. I've never been a fan of shrouds on race cars, but for a street car with an A/C condensor...
I would add a heater core shut-off valve and turbine heat shield to the mix. The only way I can control temps is distilled water with water wetter and less coolant in a bigger radiator, radiator ducting, oil cooler, coolant reroute, heater core shut-off valve and heat shields on the hot stuff.
Old Sep 9, 2016 | 06:43 PM
  #236
Total Cats: 1,870
A quick change of direction, and a peek into the future. One of the many things we'll use this chassis to develop is a T5 swap kit, and this is the beginning of that development. The box is a -238 code from a 1996 3.8L Mustang, which is desirable for a few reasons:
  • It's a World-Class box
  • It has a 3.35 1st gear which means that you can swap the input shaft from a 3.35 V8 box into it with ease.
  • The 0.75 overdrive is a big step down from the .843 in the car now, but not as deep as the .63 ODs in all the V8 boxes
  • It has an electronic speedo sender, and with a Dakota box and a little work, it should talk nicely to the NB speedometer and MS3
  • It was $130 at the junkyard, not $800 like all the V8 boxes are
I snagged this after confirming with G-Force that it's a suitable candidate to build later on. They actually said it's more desirable than an older V8 box as the basis for a built gearbox, since the newer V6 boxes are typically in much better shape.
For people who want a 100% bolt-in solution, you'll have to shell out $1100 for a new T5z box, but converting the V6 box to V8 spec is easy. You need the input shaft, bearing, bearing cover plate, and a shim kit, all of which can be had for ~$140 or so, which means you can put the gearbox itself together for well under $300 without any special one-time deals or hard to find parts.
The clutch disc was $110 and it's a performance organic disc with a 10-spline T5 center. It will get swapped for a 26-spline piece when I do a G-Force gearset next year. All the G-Force boxes are set up around 7.18" input shafts (V8), not the ~7.8" shafts that came in the V6s, so in order to accomodate built gearboxes, we'll build around the 7.18" length.
The bellhousing is cut off a blown 5-speed (everyone considering this swap probably has a blown 5-speed in their garage) and it will be milled down to the correct length and welded to an adapter plate which will be done in a few weeks. Using a chopped-up OEM bellhousing means I can retain the stock TOB, stock clutch fork, and stock hydraulics, so from the front, it will look like a Miata transmission with a 10-spline input shaft sticking through, and there are no issues with reliability or fitment on any of those critical items.
So that's the trans>engine attachment all sorted out. Next big puzzle is the shifter extension. The PPF bracket should be a little easier.
Necro post. My research shows that the 94-98 boxes were from the 6-232, and the 99-04 were from the 6-238. And thats when the electronic speedo switchover happened. Am I totally off base?
Correct me if I'm wrong.
90-93 V8 box = correct length input shaft, bad overdrive. More $$$ because mustangs like em.
94-98 V6 box = Longer input shaft. But good overdrive. Uses 3.35 first gear so we can use a v8 input shaft. Mechanical speedo
99-04 V6 box = Longer input shaft. Good overdrive. 3.35 first gear, but with electronic speedo.
94-95 V8 box = Longer input shaft, bad overdrive, 3.35 first gear
Old Sep 9, 2016 | 06:56 PM
  #237
232 is a GM box. 238 is the 95-97 V6 Ford box.
Identification Key to Borg-Warner T5 transmission ID Tags
Ford World Class Transmisson identification
Old Sep 9, 2016 | 06:57 PM
  #238
Total Cats: 1,870
Thats confusing lol. Because the mustang had a 3.8 and 3.9. And their engine codes were 6-232 and 6-238 lol.
According to this the electronic speedo started in 99. http://www.moderndriveline.com/Techn...t5_history.htm
But it looks like any 3.8 v6 box should work. 94-04.
Old Sep 9, 2016 | 07:01 PM
  #239
Total Cats: 1,870
That second link shows a .68 overdrive for the 95-97 t5. Only the 94-94.5? had the .73. It also says nothing about 98+
Old Sep 9, 2016 | 07:09 PM
  #240
Total Cats: 1,870
Wow there is all sorts of conflicting information out there.
Going to edit this post instead of continuing to fill up your thread.
http://themustangsource.com/forums/f...4/#post4489118
'94-98 V6 T5 ... 1st: 3.35:1, 2nd: 1.93:1, 3rd: 1.29:1, 4th: 1.00:1, 5th: 0.73:1
'99-04 V6 T5 ... 1st: 3.35:1, 2nd: 1.99:1, 3rd: 1.33:1, 4th: 1.00:1, 5th: 0.68:1
But then according to this: http://www.mongosgarage.com/tech/t5/T5Numbers.PDF the 98-99 had a .73 overdrive. and the 99-01 doesnt have ratios listed.
I guess unless I can find some real info the 94-98 is the safe one to go with. And I guess the 96-98 had the electronic speedo?
I wish other platforms had a version of mt.net, with actual fact checking instead of just numbers.
