Chiburbian's 01' Lots of potential, no follow-through build
Old Feb 20, 2017 | 03:17 PM
  #601
Total Cats: 861
OD = OK
Where: Re: sloping idle. Your Settings:
Mine, as an example:
The confusing part: I'm saying that whether you choose to use MAT or CLT to set initial values, your values are presently all the same regardless of CLT. Thus, the rows mean nothing. You are not getting the benefit of a 3D control.
Old Feb 20, 2017 | 03:25 PM
  #602
Chiburbian's Avatar
Total Cats: 204
Ahh, that makes sense. The reason why it's all the same is because prior to the other day I thought that the "y" axis on that table was load not temperature. I am guessing originally the map pre loaded in the numbers in celcius which is why I thought they were load not temperature.
And, I never noticed any difference in required VE based on very very small changes in load.
Old Feb 21, 2017 | 09:01 PM
  #603
Chiburbian's Avatar
Total Cats: 204
Ok, made a bunch of adjustments based on advice. I bedded my brakes tonight and on my "cool down" I did a log. Some pulls were done when I got behind an STI with an exhaust. He didn't pull on me.
WHEN my EGO is running it seems to be doing a good job. For some reason though it doesn't seem to run when running "idle VE". I did almost stall out a couple times. I need to do some logs early on in my driving so as to catch those issues in a log for you all to see.
I will post more logs tomorrow, but for now here is my current tune and log from tonight.
Again, the log is too big to post:
https://www.dropbox.com/s/m5m2onv5hf...19.11.msl?dl=0
File Type: msq
Old Feb 23, 2017 | 06:23 PM
  #604
Chiburbian's Avatar
Total Cats: 204
eek! I need to turn the boost down.
Old Feb 23, 2017 | 09:53 PM
  #605
Chiburbian's Avatar
Total Cats: 204
Time to post some weird idle issues:
#185 is just sitting in traffic I believe? You can see my idle varying quite a bit to the point of almost stalling.
#186 is a few miles down the road pulling into my subdivision and parking. I notice that the power steering pump will almost stall the car. That makes for a dangerous situation.
File Type: msl
File Type: msl
Old Feb 24, 2017 | 10:27 PM
  #606
Total Cats: 861
https://www.miataturbo.net/megasquir...d-91932/page4/ See post 91. I think Curly makes a good recommendation to go back to the basics.
The other general truth, especially regarding the power steering, is that Timing, not IAC control is what drives good idle on Miatas.
Old Mar 4, 2017 | 10:12 PM
  #607
Chiburbian's Avatar
Total Cats: 204
So, unrelated to the last post I decided to look at my tune a bit since it was a little too cold to drive on my tires today. I remembered noting that the Flyin' Miata Hydra ignition base map looked a lot more aggressive than I remembered my map to be.
Here is what I started with:
And looking at that map and comparing it to even the DIYautotune BASE map I saw that I was pretty far retarded all over. Now, I don't want to throw my tune into chaos by just copy/pasting especially considering that this tune has been safe for my rods thus far, but at the same time I seem to getting quite hot and my fuel economy isn't very good. I am figuring that perhaps the retarded timing is causing my engine to run hotter than it otherwise would, so I copied the DIYautotune base map to all cells below 100kpa and kept my boost ignition timing.
When I do the engine build I will go to the dyno and get a proper cell by cell MBT calibration, but this should be an improvement.
Here is my result:
I do notice that my 20, 25/40 load cells are the same all the way across the RPM band, so I will probably re-scale my map at some point when I decide where I want some extra resolution.
Old Mar 5, 2017 | 10:22 AM
  #608
yossi126's Avatar
Total Cats: -13
seems a bit aggressive idle in my opinion. Is it stable and knock free?
I found that my engine likes the 30's in low everyday rpm's.
Old Mar 5, 2017 | 10:24 AM
  #609
Chiburbian's Avatar
Total Cats: 204
From 100kpa and below it's the DIY Autotune map. It is a tiny bit more aggressive in the idle regions than what I was running previously.
Old Mar 5, 2017 | 06:57 PM
  #610
Chiburbian's Avatar
Total Cats: 204
I went out for a drive today with the new ignition map. It APPEARS that I am using quite a bit less fuel. My Tunerstudio fuel economy gauge spent a bunch of time in the high 20's to mid 30's. I need to figure out how to set it up to average out the economy over a certain distance.
Also, I set my boost control to "basic" closed loop and set sensitivity to about 480 before it seemed to do anything. That seems awfully high.
Aside from it being terribly sensitive to power steering and even power window electrical loads (stalling) it's running pretty damn good.
Old Mar 5, 2017 | 06:59 PM
  #611
Total Cats: 1,870
Idle timing correction goes a long ways with electrical loads.
Did you tune your bias duty table?
Old Mar 5, 2017 | 07:21 PM
  #612
Chiburbian's Avatar
Total Cats: 204
Bias duty for idle valve? Not well enough. I think the biggest issue with tuning for me is that I take such long drives. By the time I get home or somewhere I can fiddle with stuff I am so tired of being in the car that I just pull the logs and walk away. When I come back to it later I have forgotten enough about what I was actually looking for.
My methodology sucks.
Old Mar 5, 2017 | 07:29 PM
  #613
Total Cats: 1,870
Bias duty for boost control.
Old Mar 5, 2017 | 07:37 PM
  #614
Chiburbian's Avatar
Total Cats: 204
Oh yeah, that is going well.
I was a bit high on duty (2-4%) in the 170kpa area and by setting the slider and delta I was able to let the MS give me some better bias duty values. I know I am kinda cheating but it's working. 180-185kpa bias duty seems to be spot on. Unfortunately though 185kpa is a little higher than I would like, so until I got the closed loop stuff working I was progressively lowering my duty to try and hit 170kpa.
Old Mar 22, 2017 | 08:27 PM
  #615
Chiburbian's Avatar
Total Cats: 204
My newest addition to my build:
Old Apr 15, 2017 | 01:18 PM
  #616
Chiburbian's Avatar
Total Cats: 204
Old Apr 15, 2017 | 02:32 PM
  #617
HHammerly's Avatar
Total Cats: 63
you have a clicking noice when this happens? I had something similar with a clicking noise and it ened up being the main relay (green one in the engine bay , passenger side)
changed it and the problem came back a few weeks later, turned out to be the connector was a bit open and would loose contact after a while, snug it up a little with needle nose pliers and it has been fine for over a year
Old Apr 15, 2017 | 04:49 PM
  #618
Chiburbian's Avatar
Total Cats: 204
That was it, thanks. Wiggled the relay (almost pulled it out) and the fans turned off and I could hear my fuel pump prime. Car started right up.
Old Apr 15, 2017 | 04:57 PM
  #619
HHammerly's Avatar
Total Cats: 63
Glad that it was that, i spent many hours trying to figure that one out!
Old Apr 27, 2017 | 07:44 AM
  #620
Chiburbian's Avatar
Total Cats: 204
I upgraded my heater hoses last night:
