MKTurbo Black Friday 2025 Sales Thread
Old Jul 10, 2017 | 03:23 PM
  #1461
even if you don't turn the boost up and keep it as is
Old Jul 10, 2017 | 03:39 PM
  #1462
Ivan's Avatar
Total Cats: -2
Originally Posted by 18psi
clean install/bay. you should re-do the wg signal source to post-ic and add a boost controller, you'll be surprised at how much better your boost onset will get
Thanks for the feedback! I was planning on doing that when I install the EBC. But I might as well do it now
Old Jul 10, 2017 | 03:43 PM
  #1463
if you're doing ebc it's even easier because you don't even need to move the source
Old Jul 17, 2017 | 06:49 AM
  #1464
AliveMX5's Avatar
Started mine up yesterday, its idling pig rich at 10 AFR. Need to get that squared away then hopefully start tuning it. A few photo's.
That heater hose in the last pic has already been shortened/modified.
Old Jul 18, 2017 | 12:48 AM
  #1465
farpolemiddle's Avatar
Total Cats: 95
You should wrap something around the pipe going through the inner fender. It will wear through pretty quick.
Old Jul 21, 2017 | 03:52 PM
  #1466
huesmann's Avatar
Total Cats: -15
What would you use?
Old Jul 21, 2017 | 04:15 PM
  #1467
MotoCARR's Avatar
Originally Posted by huesmann
What would you use?
Get a 6"-12" piece of rubber hose, cut it length wise, and line the hole you cut with it.
Old Jul 21, 2017 | 04:26 PM
  #1468
Total Cats: 146
Bike inner tube works well too.
Old Jul 21, 2017 | 10:53 PM
  #1469
Total Cats: 593
Don't listen to theclit, a piece of inner door jam rubberized trim is best.
Old Jul 27, 2017 | 09:08 AM
  #1470
Gimpster's Avatar
Total Cats: 7
Would anyone be interested in buying out the deposit on my NA 1.8 + oil lines order at a discount? I have $1185 invested, awaiting shipment so $400 would be due to clear that balance.
Suffice it to say life events have come up.
If if you don't want to allow this I understand, and I'll still take delivery of kit and resell. Just seemed wasteful to ship it twice if someone out there wanted one and has been on the fence.
Old Jul 27, 2017 | 09:11 AM
  #1471
You have an email. We will find someone to take your spot.
Old Jul 28, 2017 | 10:42 AM
  #1472
Engi-ninja's Avatar
Total Cats: 40
Whatever you use, make sure to make it's snug enough to eliminate relative movement between the pipe and the fender, otherwise it'll still wear through, it'll just take a little longer. I would round the edges of the hole too.
Old Jul 29, 2017 | 12:56 PM
  #1473
AliveMX5's Avatar
A few passes with the kit installed.
Old Jul 29, 2017 | 01:04 PM
  #1474
Sounds great. I fixed the YT link so it would load in your post.
Old Jul 29, 2017 | 03:59 PM
  #1475
what K&N filter is that?
Old Jul 29, 2017 | 11:10 PM
  #1476
kick-rennedy's Avatar
He called it the K&N RU-1700 in his build thread.
Old Jul 30, 2017 | 01:52 PM
  #1477
AliveMX5's Avatar
This ^
Old Jul 31, 2017 | 02:56 AM
  #1478
miguel.sagal92@gmail.com's Avatar
Sounds amazing man. Cant wait to get mine!
Old Jul 31, 2017 | 08:18 AM
  #1479
Last day of the sale. I think I have one spot left open currently.
Old Aug 2, 2017 | 04:12 PM
  #1480
Sale is over and all 10 spots filled up. I will be driving to Atlanta this weekend to hand deliver a setup to a customer. Then to Jersey the following weekend to deliver 2 more setups, and to stop and pick up parts in MD to build setups for all the rest.
Thanks a ton for all placed orders.
