Post your DIY aero pics
Old Mar 23, 2018 | 10:00 PM
  #1621
soot's Avatar
Total Cats: 81
Originally Posted by moocow
I don't see a problem with that, though it would increase drag. But why wouldn't just you make a wider or longer spoiler?
I was just curious if it had been done, and if not why? To me that's like saying why not just get a bigger wing instead of adding endplates to one. Endplates make a wing much more effective, so I was wondering if the same would happen with a spoiler.
Also a wider or longer spoiler will add more drag as well. If I add 'endplates' to this one I don't have to make a new spoiler, and maybe those endplates have an improved down force to drag ratio compared to making a larger spoiler.
guess I'll just try it myself!
Old Mar 24, 2018 | 07:25 AM
  #1622
hector's Avatar
Total Cats: 218
Google Jeff Keisel and his EM car. Must be worth something for him to do it.
Old Mar 26, 2018 | 06:01 AM
  #1623
HarryB's Avatar
Total Cats: 155
Endplates have also another interesting effect if you think the car when cornering (or even sliding). Downforce in straight line does not matter much.
Old Mar 26, 2018 | 01:11 PM
  #1624
icantlearn's Avatar
Total Cats: 118
What is this, "interesting effect"?
Old Mar 26, 2018 | 01:18 PM
  #1625
ryansmoneypit's Avatar
Total Cats: 458
thrust vectoring.
  #1626
Total Cats: 2,621
Until you get to the braking zone, then it's critical to lap times.
.33 SNR
Old Mar 26, 2018 | 01:33 PM
  #1627
icantlearn's Avatar
Total Cats: 118
Originally Posted by ryansmoneypit
thrust vectoring.
enlighten me? Unless the high pressure region on top of the wing is lower than the "thrust" trying to enter, I dont see how this is a thing, especially with larger endplates. Or am I missing something?
Old Mar 26, 2018 | 03:40 PM
  #1628
Total Cats: 458
I was half kidding with that but... if you consider how hard the end-plates might try to straighten the car out when its sideways, then maybe that term loosely applies.
Old Mar 27, 2018 | 06:22 AM
  #1629
HarryB's Avatar
Total Cats: 155
That. Depends on the relative size of endplates of course (and their stiffness), but it can be pretty significant. Also, Emilio is (as usual) right, I should have said "excluding braking"
Old Mar 27, 2018 | 12:06 PM
  #1630
Blackbird's Avatar
Total Cats: 415
That's half the picture, big end plates also turn the car as you turn the steering wheel.
Old Mar 27, 2018 | 03:42 PM
  #1631
lightyear's Avatar
Total Cats: 93
Big end plates do look like a rudder.
Old Mar 27, 2018 | 06:06 PM
  #1632
OGRacing's Avatar
Total Cats: 33
i like that ^
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
Old Mar 27, 2018 | 06:27 PM
  #1633
Full_Tilt_Boogie's Avatar
Total Cats: 409
Originally Posted by lightyear
*coming up to a right hand turn*
"Avast! Reverse engines! Broach to starboard!"
Old Mar 28, 2018 | 03:45 AM
  #1634
HarryB's Avatar
Total Cats: 155
Speaking of...who said active aero should be limited on the horizontal plane of the wing anyways? That's something my ex-FSAE team is actually experimenting with.
Old Mar 28, 2018 | 08:43 AM
  #1635
Blackbird's Avatar
Total Cats: 415
IIRC both Porsche and Audi had some cheater end plates on their LMP1 a few years ago where there was some amount of "deflection".
Old Mar 28, 2018 | 10:04 AM
  #1636
Midtenn's Avatar
Total Cats: 311
Toyota and Porsche both had rear body work that flexed down at high speed to reduce the wing angle. Porsche's got caught before the race and they had to fix the issue, Toyota did not get caught and ran the 24hrs of LeMan with it.
http://www.mulsannescorner.com/RCELeMans2014.html
Old Mar 28, 2018 | 10:26 AM
  #1637
Blackbird's Avatar
Total Cats: 415
Yes, there was that, but also this -
Porsche 919 (9R9 MY15-MY17) - Racecar Engineering
Old Mar 28, 2018 | 07:37 PM
  #1638
M2Ken's Avatar
NASCAR COT end plates are mini wings (not flat). Granted, these only turn left, but the end plates definitely are part of the steering mechanism.
Old Mar 29, 2018 | 07:05 AM
  #1639
lightyear's Avatar
Total Cats: 93
The car finally is on its wheels, so I had to wheel it out for some pics.
Leave a poscat 10 Leave a negcat
Old Mar 29, 2018 | 07:19 AM
  #1640
Total Cats: 3,591
Really professional looking. The fastback really helps the lines of the car.
