pdexta's build: round 3
Old Sep 12, 2012 | 03:27 PM
  #41
soviet's Avatar
Total Cats: 269
I still had a hard time idling at sub-1000rpm :(
I'd like to see any other ECU do that with my setup though, hah.
Old Sep 12, 2012 | 03:32 PM
  #42
what's so special about your setup that would make it hard to idle below 1000rpm?
get faster/smaller injectors and lower airflow.
Old Sep 12, 2012 | 04:13 PM
  #43
soviet's Avatar
Total Cats: 269
Sometimes it just overshoots and stalls when coming off throttle. I'm sure I can tune out of it.
Old Sep 12, 2012 | 05:59 PM
triple88a's Avatar
Total Cats: 1,830
Mine idles fine... mods in sig.
Old Sep 13, 2012 | 10:34 AM
  #45
pdexta's Avatar
Total Cats: 184
I made a couple little changes last night.
I managed to acquire a stock NA catback and swap it on in place of the chopped of muffler the previous owner had. The car is a 1000 times better to drive now, so quiet.
Then I hardwired my 9500i radar detector.
Also found an almost empty can of R134 in the garage. The gauge showed it was low on freon so I added what was left in the car, it could still use a little more but the AC blows cold enough I had to turn it down on my drive to work.
Old Sep 16, 2012 | 04:58 PM
  #46
pdexta's Avatar
Total Cats: 184
I was hoping to swap out my 6 speed, clutch, and flywheel this weekend but couldn't find any 70w-90 gear gl4 gear oil locally so I ended up swapping out the rearend instead. The 3.90 rearend is now in the car so it's even slower than it was before. I got 2 new RPF1s put them on with the 2 good ones off my old car, swapped out the stock motor mounts for a MMR and a mazdacomp mount, and swapped the stock clutch line for a braided line.
mmr and mazdacomp
stock
I also received my MSPNP from DIYAutotune and picked up a slightly damaged '99 head to go on my spare block after I build it. Can't wait to get the megasquirt in and running, hopefully I can get it swapped over this week.
Attached Thumbnails pdexta's build: round 3-dsc00076.jpg   pdexta's build: round 3-dsc00061.jpg   pdexta's build: round 3-dsc00067.jpg
Old Sep 17, 2012 | 01:37 AM
  #47
Fireindc's Avatar
Total Cats: 915
Woot, in for more sexy parts.
Old Sep 17, 2012 | 06:48 AM
  #48
Boris's Avatar
Bannisheded
Total Cats: 10
Let the motor build begin ?!
Old Sep 17, 2012 | 08:09 AM
  #49
Geez speedy progress indeed. Good stuff
Old Sep 17, 2012 | 09:27 AM
  #50
youll hate those mounts.
Old Sep 17, 2012 | 12:38 PM
  #51
Fireindc's Avatar
Total Cats: 915
I've got the mazdacomp ones and they are the ****.
Not sure about that MMR poly mount though, although he obviously is aware of the rigidity of those and is trying to offset it by using only 1 of them. Which side do you put the MMR mount on?
Old Sep 17, 2012 | 01:42 PM
  #52
oh i see what he did.
Old Sep 17, 2012 | 06:10 PM
  #53
pdexta's Avatar
Total Cats: 184
I started out running 2 MMR mounts which is pretty brutal and makes your rearview mirror useless. I switched to mazdacomp mounts and while they're a great improvement, I didn't feel like they were stiff enough. With one of each you still get some decent vibration but it's nothing ridiculous. I run the MMR on the driver's side, assuming that one is going to see the most stress and flex.
Old Sep 17, 2012 | 06:14 PM
  #54
pusha's Avatar
Total Cats: -29
hi bro I've been banging some chick who goes to FGCU, wanna meet up one day when I'm over there? :-)
Old Sep 17, 2012 | 06:26 PM
  #55
Fireindc's Avatar
Total Cats: 915
This threads talking about MMR mounts, not MMF mounting.
Old Sep 17, 2012 | 06:39 PM
  #56
By bang he means felch and by chick he means dude
Old Sep 17, 2012 | 06:52 PM
  #57
pusha's Avatar
Total Cats: -29
look, you don't need to comment with something gay on every single one of my posts. We get it, you are a homosex.
Old Sep 17, 2012 | 10:10 PM
  #58
triple88a's Avatar
Total Cats: 1,830
Man you 2 fight more than a married couple,
Wwassuuppp withat?
Attached Thumbnails pdexta's build: round 3-helms.jpg
Old Sep 20, 2012 | 11:30 AM
  #59
pdexta's Avatar
Total Cats: 184
Let me know when you're heading over this way.
I mounted and wired my gauges (wideband, boost, water temp) last night. I was going to swap the wideband into the secondary o2 sensor location when I realized there isn't a secondary o2 sensor, lol.
I'm hoping to get the megasquirt in tonight, but a little nervous I'll screw something up and not have a car to drive to work tomorrow. I guess I'll see what happens.
Old Sep 20, 2012 | 11:31 AM
  #60
Does the motor not squat to the passenger side? would it not be "best" then to put the solid mount on that side?
