Miata Flat Underbody
Old Jan 13, 2013 | 07:12 PM
1993ka24det's Avatar
Total Cats: 62
What I want to know is how you ship something like that.
It came on a pallet with a wood bottom, (2) 12 foot long steel C channel on the length and cardboard top and bottom of the sheet.
Im guessing what I have cut is about 30 lbs.
Here it is mostly finished, next up is the splitter/front diffuser
Attached Thumbnails Miata Flat Underbody-321979_534775583207677_374496063_o_zpsb7d91981.jpg   Miata Flat Underbody-740833_534775526541016_625187510_o_zpsd7911d50.jpg   Miata Flat Underbody-740850_534775639874338_1583592501_o_zpsd4cd2f75.jpg
Old Jan 13, 2013 | 08:04 PM
ctdrftna's Avatar
Total Cats: 56
Wow, that is a flat bottom !!
Old Jan 13, 2013 | 10:58 PM
Mobius's Avatar
Total Cats: 365
So ... where does the heat go?
Old Jan 13, 2013 | 11:51 PM
wannafbody's Avatar
Total Cats: -369
Wouldn't air coming in the front grill still get trapped above the flat bottom?
Old Jan 14, 2013 | 01:20 AM
Total Cats: 62
The heat goes out the back above the diffuser.
There is a about a 1" gap between the panel and the steering box, which will have a opening in the front air dam to channel the air into this space.
The air trapped under the hood will be going out vents in the hood, I haven't got to working on yet due to the cold temps outside. I will be mocking it up to match the vents on the German Touring Car. I also have a 1" hood spacer with the rear hood seal removed.
To give an idea of how much air is going through the channel (4 inch space between the frame rails) I will put wind speed guage in there then drive to 60, 80, then 100 mph. I'm guessing 5 to 1 would be a goal for now(100 mph speed with 20 mph air speed)
Old Jan 14, 2013 | 02:11 AM
ThePass's Avatar
Total Cats: 1,237
Assuming you are intending to use the car competetively, it's key to make things as light as possible. 30+ lbs is a lot for the flat panel, before even adding brackets and hardware.
For reference, my flat underbody is 11 lbs including all hardware and brackets.
(I just did a redesign for the brackets and hardware to save weight - now <200 grams total)
Not trying to detract at all from what you're doing, I'm really encouraged to see people getting deep into aero development for miatas. Just trying to inspire you/everyone to try to make the best pieces they can.
-Ryan
Ryan Passey
Old Jan 14, 2013 | 02:46 AM
Total Cats: 62
Originally Posted by ThePass
If you are going through the trouble to make a flat bottom, you're doing so to go fast in a competetive environment. If you want to go fast in a competetive environment, weight is the enemy. Therefore, it's key to make things as light as possible. 30+ lbs is a lot for the flat panel, before even adding brackets and hardware.
-Ryan
That is darn light. At lest it is at the lowest point. My goal is 2100 lbs w/driver. I will be making dry carbon wide body panels and a possible V8 swap, if you wanta know more click here ( https://www.miataturbo.net/general-m...her-car-61236/ ) for the specs I'm going with
Old Jan 14, 2013 | 07:08 AM
StarletRick's Avatar
This is a very bad idea that will hinder more than help. if you remove the rubber strip, the hood actually sucks air in and hinders flow through the rad.
All you need is a vent just in front of the engine.
Old Jan 14, 2013 | 09:38 AM
Dot3's Avatar
Total Cats: -14
Since the topic of aluminum is going on. Has anyone heard of 3003? I don't have much knowledge on metals. I bought a sheet of 3003 that I need bent and every fabrication shop I talk to has no clue what I'm talking about.
Old Jan 14, 2013 | 10:34 AM
sterVin's Avatar
http://www.metalsuppliersonline.com/...metals/411.asp
Not nearly as popular as the 50xx, 60xx, and 70xx aluminums. "Applications: cooking utensils, decorative trim, awnings, siding, storage tanks, chemical equipment."
Old Jan 14, 2013 | 11:57 AM
Total Cats: 3,593
Originally Posted by StarletRick
This is a very bad idea that will hinder more than help. if you remove the rubber strip, the hook actually sucks air in and hinders flow through the rad.
+1 The air at the base of the windshield is very high pressure and will enter through the rear of the hood and into the engine bay. Look at race cars for inspiration and their outlets through the hood just behind the radiator. Ricer fanbois do many things wrong and lifting the rear of the hood is one of them. Don't use them for inspiration.
Old Jan 14, 2013 | 09:19 PM
Vilko's Avatar
Total Cats: 8
Some people have them to lower their engine bay temps when they are having trouble melting ****. Not useful on a grip car, but maybe on a drift car.
Old Jan 14, 2013 | 09:31 PM
rharris19's Avatar
Then they need to properly isolate the parts that are melting from the heat source. By raising the rear of the hood, you increase pressure under the hood and decrease the amount of heat that can escape. Unless your firewall directly underneath the hood is the issue, it will hurt things.
Old Jan 14, 2013 | 09:45 PM
plucas's Avatar
Total Cats: 45
This. Higher pressure builds at the top of the hood at the windshield. Higher pressure areas are not where you should try to exit air; it is where you should have inlets. Looking below you can see the science...
Old Jan 14, 2013 | 10:36 PM
Total Cats: 62
Good CAD model, do you have any more models or do you have the program
Old Jan 14, 2013 | 10:50 PM
plucas's Avatar
Total Cats: 45
It is my CAD model of the miata. I have more models of other vehicles. I use them for cfd.
Old Jan 15, 2013 | 01:29 AM
ThePass's Avatar
Total Cats: 1,237
How do so many aero theads divert into trying to explain to someone that hood risers are utterly useless? By how many times its been gone over by now, I'm surprised it even comes up any more.
-Ryan
Ryan Passey
Old Jan 15, 2013 | 02:08 AM
Full_Tilt_Boogie's Avatar
Total Cats: 409
Ban. Just ban.
Old Jan 15, 2013 | 02:55 AM
Total Cats: 62
I guessing its a 3D flow model. Do you have any CAD models of any Dive Planes (Canards). One other thing I was wondering is, If the Dive Plane is to low. Will the vortices shove more air under the car or will it do its job better by keeping the air from going under the car from the side?
Old Jan 15, 2013 | 12:25 PM
plucas's Avatar
Total Cats: 45
I consider them cfd models since they are simplified models. I have not analyzed canards on a miata because I have never been ask to help design aero for a miata that wanted to use canards. I have done them before on another project.
"Will the vortices shove more air under the car or will it do its job better by keeping the air from going under the car from the side?"
It depends like all generic aerodynamic questions lol. You can design aero bits that can cause vortices that "seal" the sides to prevent air from spilling under the car. The vortices will act like skirts to seal the bottom If you have an actual design you are thinking of, I might be able to give you a better answer than depends.
