Old 02-20-2018, 05:43 PM
  #1341
mrmonk7663's Avatar
Stock front tophats and rear extended...that definitely cuts down on the cost factor. I’ll measure and see if I can get away with it. Thank you. I read all 67 pages yesterday. It was great info but everything is so scattered it gets overwhelming.
mrmonk7663 is offline
Old 02-20-2018, 05:49 PM
  #1342
acedeuce802's Avatar
Total Cats: 175
Rear top hats are also really easy to modify (fronts are easy too, but require widening the chassis hole). I used a 2.5" (I think) hole saw and made a little guide that fits in the top hat hole and has a hole the diameter of the drill bit. Cuts the top hat in two pieces, then weld some 2.5" tube in between. This 2.5" tube is too large to fit in the front chassis hole, but fits in the rear no problem.
acedeuce802 is offline
Old 02-20-2018, 05:58 PM
  #1343
mrmonk7663's Avatar
Yah I saw your posts with that. Unfortunately my flux core welder isn’t up to the task, nor are my welding skills. On a different note will the 7” front spring allow me to get to the 12.5” ride height with the msm bilsteins? I know the 7” rear will...but would an 8” rear?
Old 02-20-2018, 08:57 PM
  #1344
Thucydides's Avatar
Total Cats: -7
JoetheZoe. I'm glad to hear you're developing a spreadsheet to facilitate suspension design. The first thing you'll want to do is make sure you're applying the correct load on the springs. In this case, and I could be completely wrong, but it appears you've missed the correct weight by the motion ratio. In other words, while the measured load on the tire may be 600 lbs, the load on the front spring is the tire load times the motion ratio, or 600 x 1.52 = 912 lbs. I think you'll find this changes the results a bit.
Also, having no shocks to measure, and therefore having nothing to attach my 5Xracing sleeves to, I've assumed numbers (wild *** guessed them) for the purposes of checking to see if my spreadsheet works. Now you have parts, and I have what I believe to be a working spreadsheet, so if you're interested PM me your email address and I'll send you my Excel spreadsheet to checkout. Then you can plug in what you know works and you can tell me whether the model is viable or if it's ****. Fun for everyone!
Thucydides is offline
Old 02-21-2018, 08:39 AM
  #1345
JoeTheZoe's Avatar
Total Cats: 12
DOH! As an engineer, I should be ashamed of myself...ΣM = 0
I'll do exactly that and mess with the spreadsheet. Thanks for catching that!
JoeTheZoe is offline
Old 02-21-2018, 02:03 PM
  #1346
mrmonk7663's Avatar
Have y’all seen or used these? They use both stock rubber bushings. Looks like a good product. Not sure if this would be advantageous over the FEAL unit with built in rubber bushing. DifTech Extended tophats And here is the FEAL unit. FEAL extended tophats Both look to be a better alternative, albeit, more expensive, than the ISC, Two Six or Garage Star Offerings.
Old 02-21-2018, 02:26 PM
  #1347
Bronson M's Avatar
Total Cats: 217
Functionality there is no difference between any of them, just pretty. And it'll be hidden for the most part.
Bronson M is offline
Old 02-21-2018, 02:41 PM
  #1348
mrmonk7663's Avatar
I was under the impression that the two I linked would assure proper centering of the spring. I read many accounts where the isc had problems with the springs shifting. I wonder why no one offers a 1/2” nb front extension. Seems off data here tat would be perfect for msm bilsteins.
Old 02-21-2018, 02:45 PM
  #1349
Total Cats: 2,201
Any of them with a protruding ring on the bottom is good.
concealer404 is offline
Old 02-21-2018, 02:46 PM
  #1350
JoeTheZoe's Avatar
Total Cats: 12
Probably because it would be just as easy to buy 1” extensions and just stick 1/2” packers/spacers above the bumpstops.
Old 02-21-2018, 02:47 PM
  #1351
Total Cats: 2,201
I run 1" in front with MSM bilsteins.
Old 02-21-2018, 03:06 PM
  #1352
mrmonk7663's Avatar
Thanks guys.
Old 02-21-2018, 04:01 PM
  #1353
HarryB's Avatar
Total Cats: 140
Best ones I've seen so far are the ones I have coming on the post; Maruha. Same design as OEM NB2 ones (stamped steel), albeit 20mm extended.
HarryB is offline
Old 02-21-2018, 05:31 PM
  #1354
Marioshi's Avatar
Total Cats: 38
I am running a very similar set to the diftech, made by a local miata enthusiast who was unhappy with the quality of the ISC tophats. Sold me all 4 for $225. 1.5"R/1"F
Marioshi is offline
Old 02-21-2018, 07:09 PM
  #1355
mrmonk7663's Avatar
Very nice looking piece and great price. I just got off the phone with 26Motorsports and their design includes the extended tube for the spring and comes with isolators, and also is able to use readily available energy suspension bushings. $230 shipped for all 4. I pulled the trigger. For what it’s worth the company was super responsive today and generated tracking with fedex literally within 10 minutes of paying. I will use these in the rear and check my front. If fronts are ok stock then I’ll use these in the rear of the other Miata. Thanks for the help everyone.
Old 02-21-2018, 07:22 PM
  #1356
Marioshi's Avatar
Total Cats: 38
Wow, very cool. Is there a website with info on them? Everytime I look around, I find a new solution to a miata Problem. I love it!
Marioshi is offline
Old 02-21-2018, 08:31 PM
  #1357
mrmonk7663's Avatar
Type in two-six motorsports on Facebook. They have a website but it’s down at the moment and is being fixed they said. I simply messaged them via Facebook and they replied back very fast.
Old 02-22-2018, 02:43 PM
  #1358
calteg's Avatar
Total Cats: 40
Speaking of ISC, this is the install photo that's on their website:
Am I taking crazy pills? I've always installed the top hats with bushings + washer on both top and bottom. Are they literally saying just drop the top hat onto the spring?
calteg is offline
Old 02-22-2018, 03:15 PM
  #1359
Total Cats: 3,020
You need one top and bottom. I'm sure it's just an oversight when they were shooting the pictures.
sixshooter is offline
Old 02-22-2018, 03:31 PM
  #1360
Marioshi's Avatar
Total Cats: 38
Yep, the isc top hats don't come with much, just one rubber bushing and one washer...
Mine didn't even come with 4 of the same bushing...
Marioshi is offline
Quick Reply: The Better Bilstein Ebay Coilover Thread
