Donkey-MZR swapped NA
Old 11-14-2016, 12:08 PM
  #81
OGRacing's Avatar
Total Cats: 33
Originally Posted by unk577
Don't you worry about it buddy. TTU 17' is slipping away from you as we speak
I think you said the same thing about 2016...
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
OGRacing is offline
Old 11-14-2016, 03:50 PM
  #82
unk577's Avatar
Total Cats: 34
Optimism on my part. My bad
unk577 is offline
Old 04-18-2017, 05:23 PM
  #83
unk577's Avatar
Total Cats: 34
Been a couple busy months finishing other projects but the new motor is coming together and some more new parts are going on the car. I'll post some pics and more info after we get back from The Mitty
unk577 is offline
Old 07-19-2017, 03:44 PM
  #84
Red_5's Avatar
Anything new with this project?
Red_5 is offline
Old 07-19-2017, 03:47 PM
  #85
Total Cats: 3,013
I believe so. Last time I saw it there were parts removed and upgrades occurring.
sixshooter is offline
Old 07-20-2017, 04:49 PM
  #86
unk577's Avatar
Total Cats: 34
Yes, the newest motor is in. Need to make new lines for the dry sump as they need to be rerouted due to Goodwin's header being a tight fit in the NA chassis. Singular hood vents have been added along with some suspension and brake upgrades that are in progress.
Other projects are consuming our time but Donkey should be back on track for the Nationals at Sebring. I'll post some more updates and pictures after we get back from MATG.
unk577 is offline
Old 07-20-2017, 04:50 PM
  #87
unk577's Avatar
Total Cats: 34
Damn, just read my previous post. I'm slacking. My apologies to anyone who cares
unk577 is offline
Old 07-20-2017, 04:53 PM
  #88
Total Cats: 2,201
I'm going to want to talk to you dudes about this thing at MATG. Just forewarning.
concealer404 is offline
Old 07-20-2017, 10:21 PM
  #89
unk577's Avatar
Total Cats: 34
Hit us up, we won't be hard to find.
unk577 is offline
Old 07-21-2017, 06:27 AM
  #90
NiklasFalk's Avatar
Total Cats: 63
I have som lurking ideas for placing a MZR in my NB when I get tired of my BP6D. A 6sp+2.0 with thrown rod is lurking under the bench. 2025 seems far enough away to seem reasonable...
As for MRZ in a NA I thought I'd share some pics from a racing college build, this was done back in 2015, three sets of bearings were consumed until the Dry Sump system worked correctly, seems to be the norm when doing things from scratch
Yes, its a Duratec, not a MZR, but that would not change much of the installation.
And the huge battery is needed to balance a porky driver in a RHD.
NiklasFalk is offline
Old 07-24-2017, 08:56 PM
  #91
Total Cats: 104
duratec is an MZR.
What valve springs are you guys using? The factory 2.5 ones proved insufficient at even 7psi. I'm installing a set of crowers with steel subaru retainers, the rate appears significantly higher but the seat pressure is within the measurement error of my calibrated arm.
Leafy is offline
Old 08-23-2017, 11:48 AM
  #92
unk577's Avatar
Total Cats: 34
Motor is together, in, and running. Finsihing up assembling the suspension and brakes, we'll be running StopTech front and rear. Should have the car on the alignment rack and scales next week, then onto the dyno.
I need to find a new host for pictures, which one is easiest to work with?
unk577 is offline
Old 08-23-2017, 07:10 PM
  #93
Junkwhale's Avatar
imgur.com seems pretty hassle free and has worked fine with mt.net for me so far...
Junkwhale is offline
Old 08-24-2017, 06:57 AM
  #94
unk577's Avatar
Total Cats: 34
Dry sump plumbed
unk577 is offline
Old 09-29-2017, 04:31 PM
  #95
unk577's Avatar
Total Cats: 34
Headed to Sebring this weekend, I'll post as many pics as I can. V8Roadsters instagram page has some recent pics. Upgraded the wing, running our StopTech brake kit on all 4 corners. This will be a shake down for Nationals next month
unk577 is offline
Old 09-29-2017, 04:39 PM
  #96
asmasm's Avatar
Maybe I missed it earlier in the thread but, any details on the new motor? Is it another 2.0 or a 2.5 this time?
asmasm is offline
Old 10-01-2017, 02:05 PM
  #97
unk577's Avatar
Total Cats: 34
Forged bottom end 2.3, motoeast cams, Good-win max power (1.8" I believe) header, etc. Believe we had a oil pump failure early in the weekend, so there is not a lot to update at this time.
But..... big plans are in the works for this ol thing.
On a positive note, the StopTech brakes were phenomenal
unk577 is offline
Old 03-02-2018, 07:13 PM
  #98
unk577's Avatar
Total Cats: 34
Finally took the Donk out of the trailer. We'll work on it between projects so progress won't be fast.
View this post on Instagram
unk577 is offline
bawward
08-08-2017 02:29 AM
FocusTI
08-05-2016 10:44 PM
2000SE
06-09-2016 02:04 PM
graexodus
05-24-2016 01:24 PM
akbloom
05-02-2016 07:55 PM
Quick Reply: Donkey-MZR swapped NA
