MTX-L with cross referenced non-Bosch sensor?
Has anybody successfully used a cross-referenced wideband O2 sensor with the MTX-L? Advance Auto shows part number 17014 as being superseded and no longer available. They do have cross-referenced sensors--all are significantly more money--but maybe one would be worth it. For example, the Denso was three times as much, but if it lasts...
Thanks,
Thanks,
Not really what I was thinking of.
The sensor seems to be the weak link, but I didn't really have any recurring problems with it until I got the Rotrex and was running richer AFRs. The sensors from Advance were considerably cheaper than the ones from Innovate. Upgrading to the 4.9 requires a new cable and reprogramming the gauge, which means I have to take some things apart, and the initial outlay is more than the cost of two 4.2 sensors. I don't know that the 4.9 sensor is any more robust. Changing to a different vendor, like AEM, is a larger outlay and a bigger effort.
I may try the Denso in the future. I'm surprised no one here has experimented with this already.
Total Cats: 4,080
The MTX-L uses the LSU 4.9. Where as the LC-1 used the LSU 4.2.
LSU 4.9 controllers like the MTX-L are backwards compatible with the LSU 4.2.* Where as the LC-1 is not compatible with the LSU 4.9.
Part 17014 should still be available because it's a part for some car models, but it's not even compatible with your MTX-L unless you chop off the connector and re-pin it:
*given the correct connector.
did you ever think the problem was just your tune?
Brain,
When I purchased my MTX-L a few years ago, it came with, and was set up for, the 4.2 sensor. As I said, I can upgrade to the 4.9 sensor if I get the new cable and reprogram the controller.
The 17014 is no longer available at Advance. As I said, it has been superseded by a new, and more expensive, part. It worked fine with my MTX-L. I have one in there now.
Of course it's the tune...
Total Cats: 4,080
lucky me!
looks like you cant order anymore form advance, but other places have it. you just lose out on the 30% discount. this p/n wont be superseded, it's a replacement part for specific model cars.
autozone has it for $49.99 and has coupon codes too -- there's a 20% $100 order right now.
Why are we arguing about this? How's about just answering the original question?
Total Cats: 4,080
not really arguing. trying to help.
what's the superseded part numbers? Denso 234-5117 ($115)? or 234-5115 ($220)? or NTK 24321 ($250)?
I'd just buy 17014 at autozone instead at $49.99 (who have a military discount) vs. the $115 for the Denso at advance.
looking at Bosch's site, seems like 17351 is the replacement part. still $$$$.
My Friend,
You have always been helpful beyond words. I apologize if I came across as ungrateful. I also apologize for making the lead-in story more interesting than the question.
I don't really need search help. I have a couple of under worked, overpaid govies in my office who spend their days looking for the end of the internet. They're giddy and fascinated when I ask them to find something for me. "Hey Googler, what's the radar cross section of a '56 Ford F100?" It gets quiet and I can actually get some **** done for a couple of hours.
All I wanted to know was if anyone had paired up a non-Bosch 4.2 sensor to the MTX-L. The Googler doesn't like answering Miata questions.
Thanks for all the inputs,
