TPS wiring
Old 04-07-2008, 10:43 PM
Miotta FTW!
Splitime's Avatar
Default TPS wiring
I'm using a Nissan TB with TPS. It is a simple 3wire. I figured out its ground, and got it setup to output a signal to MS. I get a nice TPS reading now.
EXCEPT.
It is only reading 131 (closed) and 228 (open). I calibrate the TPS with those (it asks if I really want them, since it is so far off... I say yes). It then shows as like 40% to 88% throttle, instead of scaling it to 0-100%
Thoughts?
-Dave
Working on tps/ebc wiring tonight. Out in car... so any help asap is awesome.
Splitime is offline
Old 04-07-2008, 10:51 PM
patsmx5's Avatar
Total Cats: 480
Dunno. Someone else posted a very similar thread like this a few days ago. Your 100% sure it's wired up correctly?
patsmx5 is offline
Old 04-07-2008, 10:53 PM
Miotta FTW!
Splitime's Avatar
If i swap the 2 "power" wires, I get it in reverse. That should be right?....
Splitime is offline
Old 04-07-2008, 10:57 PM
patsmx5's Avatar
Total Cats: 480
http://www.autoshop101.com/forms/h33.pdf
patsmx5 is offline
Old 04-07-2008, 10:59 PM
Miotta FTW!
Splitime's Avatar
Signal line is outputing 2.5v to 4.5v (closed/open)
4.9v between gnd and 5v ref line.
I'm using the 18" DIY harness to wire into stock ecu plug setup.
Blue (tps signal) is going to Red in 1N
Grey (vref 5v) is going to light green/white in 2L
Splitime is offline
Old 04-07-2008, 11:02 PM
patsmx5's Avatar
Total Cats: 480
Weird. I think the normal is 1-4.5V, that's what I see on most Fords. Still, you should be able to calibrate it in MT and the scaling be right, even if it's 4-4.5 it seems. You had the pedal released, hit calibrate, floored it, hit calibrate?
patsmx5 is offline
Old 04-07-2008, 11:03 PM
patsmx5's Avatar
Total Cats: 480
And what year miata do you have?
patsmx5 is offline
Old 04-07-2008, 11:06 PM
patsmx5's Avatar
Total Cats: 480
Will you help me pass Physics II if I help you? Crap sucks. Lets see, if I toss a proton with mass m at magnetic field B, with acceleration a, velocity v, what's magnitude and direction of the of the field.....
Hopefully someone that knows MS better than I will chime in.
patsmx5 is offline
Old 04-07-2008, 11:09 PM
Miotta FTW!
Splitime's Avatar
It's a 93.
I can get it to read linear with the throttle being opened. So I guess the wiring is right. It is just outputting wierd values (instead of 1-4.5ish stuff).
I calibrated, but it still kept showing the skewed values, it didn't "port" them into 0-255
Splitime is offline
Old 04-07-2008, 11:22 PM
patsmx5's Avatar
Total Cats: 480
Stab in the dark, but try calibrating it, then saving, then burning, then power cycling MS and removing the serial cable to MS. I've had weird stuff happen or changes not take effect and that solved it.
patsmx5 is offline
Old 04-07-2008, 11:43 PM
Miotta FTW!
Splitime's Avatar
You nailed it.
So now car has working TPS, EBC and clutch switch is bypassed.
Now to do my other ic/rad duct side and figure out how to mount them in place.
GRATZIE!
Splitime is offline
Old 04-07-2008, 11:46 PM
patsmx5's Avatar
Total Cats: 480
Wow. Damn I'm good.
patsmx5 is offline
Old 04-07-2008, 11:48 PM
Miotta FTW!
Splitime's Avatar
Wow. Damn I'm good.
Now back to your Physics II... e=mc^2 and all that jazz.
Splitime is offline
Old 04-07-2008, 11:57 PM
patsmx5's Avatar
Total Cats: 480
Oh yea.. I don't mind statics, dynamics, stuff like that. It's this proton/electron/bullshit-tron stuff that sucks. Oh well, guess it's important (Probably not). Still can't believe that's all that was wrong. You could have just gave up and tried again tomorrow and it would have probably worked. And to think of all the times I've read someone couldn't get (insert EBC or something) on their MS to work and now it's all of a sudden working for no reason.
patsmx5 is offline
Old 04-08-2008, 12:17 AM
Miotta FTW!
Splitime's Avatar
At this point my adapter harness for the TPS is done, EBC is done. Wiring other than full throttle/water injection/map switching is done. Those can wait
Man... i love finishing things.
Splitime is offline
Old 04-08-2008, 01:13 AM
thesnowboarder's Avatar
Originally Posted by Splitime
GRATZIE!
Are you Italian?
thesnowboarder is offline
Old 04-08-2008, 03:34 AM
Oscar's Avatar
Total Cats: 120
you could've at least spelled it right
Oscar is offline
nick470
7
06-16-2017 01:53 PM
slomiata
10-07-2015 01:11 PM
Trent
10-01-2015 12:15 PM
btabor
ECUs and Tuning
10
09-28-2015 05:33 PM
Quick Reply: TPS wiring
