highish exhaust backpressure but cat looks fine
Old 10-04-2008, 12:46 AM
JasonC SBB's Avatar
Total Cats: 84
Default highish exhaust backpressure but cat looks fine
Setup: GT2560, ETD manifold, TDR i/c, custom BEGI divorced downpipe
exhaust: 2.5" custom, 2.5" Maremont 200-cell metal cat, 16" resonator, 5x8x22" Magnaflow muffler.
The cat rattles a bit when I pound its body. I disconnected the downpipe, shone a light, and peeked at the brick with a mirror. The brick looks OK; it's brown, not broken up, and doesn't look clogged. I poked at it with a jack handle and the brick is slightly loose in the casing, but the brick seems whole.
So with 10 psi of turbo boost, data is below. I used to get 4-4.5 psi at 6500 RPM. (Admittedly that was with the car making less power due to a smaller turbo).
4000 2.5
4500 3
5000 3.75
5500 4.5
6000 5.25
6500 6
7000 6.75
7250 7.5
If I could get 4.5 psi at 6500 RPM with a new cat, well, 1.5 psi seems like not a huge amount ...
Thoughts?
JasonC SBB is offline
Old 10-04-2008, 12:57 AM
TURNS101's Avatar
Jason, do you have to run a cat?
If not I would just delete it.
If you do have to use the cat, what do you use the car for? Daily, track?
I just ask because that difference in boost may or may not be worth your effort.
TURNS101 is offline
Old 10-04-2008, 09:18 AM
maybe there's some sort of resonance in the rattly core at high gas flows that causes extra turbulence as it wobbles back and forth.
maybe high time to try one of those spun metal cats the kids all like.
Old 10-04-2008, 11:13 AM
JimAtFSU's Avatar
You're still running 8 psi? I thought you built your engine up?
JimAtFSU is offline
Old 10-04-2008, 11:31 AM
Zabac's Avatar
if the brick is loose, then the cat is not fine
if you must have a cat, get a 100 cell metal core one
Zabac is offline
Old 10-04-2008, 02:00 PM
TURNS101's Avatar
Y8s makes alot of sense.
With that moving around it may def be making the exhaust flow less efficient.
TURNS101 is offline
Old 10-04-2008, 11:55 PM
JasonC SBB's Avatar
Total Cats: 84
y8s, it IS a metal cat. I'm an early adopter. In my OP I wrote 200-cell Maremont metal cat. I installed it before Magnaflow came up with theirs. Or is a "spun metal" cat something newer?
Would oil burning cause the brick to go loose? I thought oil burning would clog some of the "pores". (I didn't see any).
Zabac, 100-cell? I thought the lowest was 200-cell? (what I have)
Turns101, car is a DD. I also like a quiet exhaust. And I enjoy breathing clean air...
JimFSU, I've been running 10 psi for the longest time. You may be confusing me with someone else. I do plan to dyno tune it and see if I can run an efficient 12 or 14 psi.
Old 10-05-2008, 10:23 PM
JasonC SBB's Avatar
Total Cats: 84
LOL is there a resonator that looks like a cat from the outside and is quiet?
Old 10-06-2008, 06:59 PM
bryantaylor's Avatar
magnaflow has some
bryantaylor is offline
Old 10-07-2008, 01:41 AM
JasonC SBB's Avatar
Total Cats: 84
.. that looks like a cat??
Old 10-07-2008, 02:09 AM
JimAtFSU's Avatar
Why not
1) take a dead cat from a junkyard car or from behind a muffler shop
2) drill out a 3.0x diameter hole in the center or just bash out the innards with a hammer and chisel)
3) place a 3" diameter pipe through the center,
4) weld it in place
5) grind the welds to hide, paint as necessary to look correct
6) install in vehicle for great justice
JimAtFSU is offline
Old 10-07-2008, 02:11 AM
JimAtFSU's Avatar
Alternatively,
1) saw old cat in half.
2) Weld outer shell around test pipe.
3) install in vehicle
I suspect it is illegal to sell things that imitate the appearance of a cat without being one.
JimAtFSU is offline
Old 10-07-2008, 02:57 AM
icantthink4155's Avatar
Total Cats: 13
You sir, have never been on eBay
http://cgi.ebay.com/ebaymotors/90-93...mZ380068444031
http://cgi.ebay.com/ebaymotors/Mazda...mZ250304628430
There are several more.
icantthink4155 is offline
Old 10-07-2008, 02:17 PM
fmowry's Avatar
http://www.siliconeintakes.com/produ...7d0875e6dae1f2
Not any quieter than any other test pipe though.
If you're looking for a cheap metallic cat for testing:
http://performance-curve.com/index.a...&Category=1414
Frank
fmowry is offline
bigmackloud
01-08-2021 11:24 AM
Corky Bell
Prefabbed Turbo Kits
11-22-2016 09:01 PM
Goldwar
09-29-2015 09:20 AM
Greasyman
General Miata Chat
09-28-2015 10:44 AM
Quick Reply: highish exhaust backpressure but cat looks fine
