Carbontrix extractor scoop
Old 04-12-2010, 09:34 AM
ZX-Tex's Avatar
Total Cats: 27
Default Carbontrix extractor scoop
So I just added one of these this weekend in preparation for the inevitable South Texas summer heat. This is the Carbontrix 18x10 Hood Scoop
http://www.carbontrix.com/store/inde...products_id=91
There was a thread about this way back when
https://www.miataturbo.net/showthrea...highlight=hood
It only took about two hours start to finish so it is a pretty easy job. I am going to add a few more rivets eventually but it will work fine as-is. The part that take the longest is taping and measuring everything very carefully to make sure it goes on straight and centered. I also made a pattern from cardboard to mark the hole in the hood where I would be cutting. I used a sabre saw and a fine tooth (32 TPI) Bosch metal cutting blade. Pretty easy overall.
ZX-Tex is offline
Old 04-12-2010, 09:39 AM
thagr81 us's Avatar
Looks pretty good... Make sure to report temperature differences upon running it at the track.
thagr81 us is offline
Old 04-12-2010, 09:50 AM
m2cupcar's Avatar
Total Cats: 372
Don't you wish somebody just sold a normal flat miata hood w/o that bubble?
m2cupcar is offline
Old 04-12-2010, 09:54 AM
thagr81 us's Avatar
I think the main thing about this is that it is proven to be functional and is quite cheap. Ideally I would want a wider vent with a small raised lip at the front. Similar to what Matt was running on his car... But for the money, you can't beat this setup.
Old 04-12-2010, 10:11 AM
Don't park your hood next to my hood, lol.
hustler is offline
Old 04-12-2010, 10:26 AM
m2cupcar's Avatar
Total Cats: 372
Given the dramatic improvements I saw with the mini cooper scoop, I can't imagine this one won't exceed that. Cheap? I think you're get better performance and carbonfiber for the cost over fiberglass/plastic.
m2cupcar is offline
Old 04-12-2010, 10:32 AM
thagr81 us's Avatar
True... This should perform as well as the Mini scoop since it is basically a composite replica of the same part IIRC.
Old 04-12-2010, 11:13 AM
ZX-Tex's Avatar
Total Cats: 27
I'll try to do that. As usual though there are a lot of variables involved here that will also impact the coolant/oil temperatures: Addition of a splitter, weather may be a few degrees warmer, new radiator (old one had a leak), etc. etc.
Word. That hump really gets in the way sometimes. I like a good hump as much as the next guy but not in this case.
Yes it will certainly improve radiator air flow and should drop the pressure under the car a bit.
Maybe mine will impregnate yours and they will have babies. Cheap extractor hoods for everyone.
I think it is actually bigger than the cooper scoop.
ZX-Tex is offline
Old 04-12-2010, 11:17 AM
thagr81 us's Avatar
Actually you are correct... I was going from memory of the thread about this a LONG time ago.
Old 04-12-2010, 11:27 AM
alik's Avatar
Don't park your hood IN my hood, lol.
ftfy
alik is offline
Old 04-12-2010, 11:34 AM
turotufas's Avatar
Total Cats: 7
Thats what I was thinking when I saw the scoops location. I want this now.
I want a bunch of ****. No money.
turotufas is offline
Old 04-12-2010, 12:06 PM
chpmnsws6's Avatar
Can you post a picture of the underside? As you know, we are kind of limited on room, and I'm even more so with the taurus fan.
I have this scoop sitting here with the hood in the loft.
chpmnsws6 is offline
Old 04-12-2010, 12:26 PM
ZX-Tex's Avatar
Total Cats: 27
I'll snap some pictures this evening and post them up. I looked at that clearance briefly and the underside of the scoop only protrudes down just a bit below the hood braces, like less than 1/2" IIRC.
ZX-Tex is offline
Old 04-12-2010, 08:16 PM
ZX-Tex's Avatar
Total Cats: 27
So I looked at it this evening. The bottom edge of the scoop, the part that protrudes into the engine bay, is no deeper than the ribs on the hood frame.
ZX-Tex is offline
Old 04-18-2010, 01:21 AM
jacob300zx's Avatar
Total Cats: 147
We have 3 on the way here in Corpus. Might try to do a write up, but its pretty easy IMO.
jacob300zx is offline
Old 04-18-2010, 08:11 AM
ZX-Tex's Avatar
Total Cats: 27
Yes not bad at all. I think the big tip on this one is, if you use a sabre saw, to be sure to get a fine tooth metal cutting blade. A wood blade will not work well at all and would probably just trash your hood. Obvious, but worth mentioning.
ZX-Tex is offline
Old 04-18-2010, 11:46 AM
chicksdigmiatas's Avatar
I might be doing this... Good post.
chicksdigmiatas is offline
Old 04-18-2010, 04:55 PM
tyson87's Avatar
this is what phil had and gave me
tyson87 is offline
Old 04-20-2010, 01:13 PM
jacob300zx's Avatar
Total Cats: 147
Mine is for sale here on the board for a loss. My hood is coming in for TWS and I don't need it now.
MechE
09-12-2015 03:20 PM
SnakeKP
Meet and Greet
08-12-2010 01:08 PM
levnubhin
08-11-2010 07:39 PM
jacob300zx
05-05-2010 03:34 PM
dustinb
26
06-18-2009 02:11 PM
Quick Reply: Carbontrix extractor scoop
