Post your DIY aero pics
Old May 15, 2015 | 05:54 AM
  #841
ThePass's Avatar
Total Cats: 1,237
Noticed this when browsing through photos recently. Shot with a zoom lens from far off. Endplates making the most of the wing; bowing inwards at the lower tips - higher pressure on outside of endplate, low pressure on the inside under the wing.
-Ryan
Ryan Passey
Old May 15, 2015 | 12:40 PM
  #842
Hpprose's Avatar
Total Cats: -2
Wow, that's pretty stout
Old May 15, 2015 | 04:35 PM
  #843
mx5autoxer's Avatar
Total Cats: 57
Wow.
So spam.
Such truck.
Wow.
Old May 15, 2015 | 04:38 PM
  #844
mx5autoxer's Avatar
Total Cats: 57
Ryan, I thought the endplates were part of the support? How are they bowing in? Also, I still cant get over how good your front end paint looks.
Old May 15, 2015 | 05:02 PM
  #845
ThePass's Avatar
Total Cats: 1,237
Why thank you
Nope the wing has standard upgrights, the endplates are just endplates, just very effective ones (these were my test units that lead to the development of our high-efficiency endplates).
The endplates are bowing in due to the pressure differential between the outside of the endplate and the inside.
Faster moving air = low pressure and vice versa. The air on the outer side of the endplate is basically at atmospheric pressure, so for the endplates to be bowing inwards indicates that the air inwards of the endplate under the wing is being significantly accelerated and thus at a lower pressure. (i.e. more downforce). With small/basic endplates the wing loses much more effectiveness on the outer sides of the wing as the air mixes much more with the stationary air outwards of the endplate. Well designed/larger endplates isolate the air under the wing much more so the wing can get its groove on.
-Ryan
Ryan Passey
Old May 16, 2015 | 05:51 AM
  #846
mx5-kiwi's Avatar
Total Cats: 57
This leads to a question i have always wondered...
So why does bigger not always mean better.....?
Old May 16, 2015 | 08:37 AM
  #847
Total Cats: 3,591
Because drag becomes a limiting factor. Needs more power to overcome greater drag or the car will be slower on the long straights. If it is a slow, curvy course the bigger wing is a plus, but if it is a course like many of the F1 tracks that are just long straights punctuated by slow, tight corners and then another long straight, too much wing could yield a slower time. It's always a balancing act.
Old May 16, 2015 | 03:11 PM
  #848
ThePass's Avatar
Total Cats: 1,237
Any obstacle in the airstream creates drag, and that increases with size. So with endplates, the largest/most basic priority is just to know where material is important for the performance of the wing and where to remove material so that you're getting the most performance you can for the cost in drag. Just going large without that knowledge usually results in excess surface area where it is not best utilized.
However, as a broad statement, the cost in drag from endplates is lower than the cost in drag from aggressive AOA, so 10 out of 10 times I would choose larger endplates and less AOA rather than small endplates and more AOA.
The significance of endplates is why endplate surface area is limited by the rules in almost all professional racing.
-Ryan
Ryan Passey
Old May 16, 2015 | 06:54 PM
  #849
mx5-kiwi's Avatar
Total Cats: 57
Yep sorry was talking about endplates only....does the side surface area have much drag or is it mostly the edge facing the air flow that is the factor....
I could only ever come up with cross wind instability or an increased resistance to turn as being the biggest possible reason but rules is something didn't think about....
For most of us running in track days and non sanctioned (in an aero manner anyway) events, larger end plates would likely be beneficial?
Old May 16, 2015 | 07:35 PM
  #850
ThePass's Avatar
Total Cats: 1,237
The total surface area is a factor due to surface friction drag.
Yep.
And while I would even say that as a blanket statement for very basic oversized endplates, cleverly designed endplates can further reduce drag by manipulating the vortex that is shed at the ends of the wing (this is a large portion of the drag created by the wing). This can more than offset the additional drag from the increased surface area of the endplate itself.
-Ryan
Ryan Passey
Old May 16, 2015 | 08:02 PM
  #851
Total Cats: 3,591
This technology is above my pay grade.
Read the plaque:
Attached Thumbnails Post your DIY aero pics-screen-shot-2012-07-18-01.52.38.png   Post your DIY aero pics-atwinglets_diagram.jpg
Old May 16, 2015 | 09:33 PM
  #852
mx5-kiwi's Avatar
Total Cats: 57
That plane stuff is interesting, i was trying to compare the loss in the middle with the gain outside thinking the winglet area might be less but it would have less drag and (i think) higher leverage of lift.....maybe. Drag probably the biggest thing as it relates to fuel cost.
Anyway, the new slats in F1 versus the old slots caught my eye the other day and the pass's info made me remember to look it up....its probably not especially relelvant to us (too subtle for our heavy cars and we don't have a huge rear tyre messing with our wing aero zone) but interesting none the less.
The top forward part (slots) of the end plate might have some relevance....
Analysis: Rear Wing Endplates | theWPTformula
Old May 16, 2015 | 10:00 PM
  #853
ThePass's Avatar
Total Cats: 1,237
I've actually played with applying most of the endplate features covered in that article to production car applications. Some only apply to an open wheel car or need fine tuning in CFD.. But interestingly, not all of them are wasted on the cars owned by us mere mortals.
We applied some of those elements with success to a set of custom endplates for a special project on a C6R wing recently.
Speaking of F1, I had the wing from the 2010 Williams car - specifically Hulkenberg's - in front of me this morning. Very cool:
Attached Thumbnails Post your DIY aero pics-kognition%2520-%25202010%2520williams%2520f1%2520haulkenberg%25201_zpsccpkqcvo.jpg
Ryan Passey
Old May 18, 2015 | 10:00 AM
  #854
OGRacing's Avatar
Total Cats: 33
neet!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
Old Jun 9, 2015 | 11:00 AM
  #855
that7guy's Avatar
Total Cats: 9
Hey Guys, trying to design a splitter for my GV lip on the NB. I'm going toward a form follows function approach but I still want the splitter to be athletically pleasing toward the lines of the car. Any suggestions on the options I came up with?
Attached Thumbnails Post your DIY aero pics-80-splitterdesgindwg_2cde292b69605b8126e947b38f335c53530cc259.jpg
Old Jun 9, 2015 | 11:03 AM
  #856
M.Adamovits's Avatar
Total Cats: 23
<p>Option 2.</p>
Old Jun 9, 2015 | 03:56 PM
  #857
motormechanic's Avatar
Old Jun 9, 2015 | 05:09 PM
  #858
mx5-kiwi's Avatar
Total Cats: 57
I can help with grammar but as all those options look okay to me, i'll let people better than me work on the aero!
"Aesthetically" ......
Old Jun 9, 2015 | 05:35 PM
  #859
ThePass's Avatar
Total Cats: 1,237
Mo' surface area, mo' betta.
-Ryan
Ryan Passey
Old Jun 14, 2015 | 11:46 PM
  #860
boomer's Avatar
Apologies, double post.
