3d printed intake for N/A NA miatas
Old Jun 16, 2016 | 09:54 PM
  #401
bbundy's Avatar
Total Cats: 146
Originally Posted by triple88a
Psh thats nothing. On my jeep i fit 3.75 hose on a 4" ID pipe without any lube.
yea I push 2.5 hose on a 2.7XX OD Skunk2 TB without too much difficulty. I like the tight fit and without boost it won't need hose clamps at all.
Old Jun 17, 2016 | 12:13 AM
  #402
bbundy's Avatar
Total Cats: 146
Getting closer.
together
Attached Thumbnails 3d printed intake for N/A NA miatas-20160616_210536.jpg
Old Jun 18, 2016 | 12:37 PM
  #403
triple88a's Avatar
Total Cats: 1,830
I dont know about the no clamps though. Vibration will get it off imo.
Old Jun 27, 2016 | 12:56 PM
  #404
asmasm's Avatar
I sent this helmholtz resonated crossover and the new airfilter setup out to the PNW to get dyno tested.
The helmholtz chamber showed a conclusive improvement in the targeted RPM range. There is quite a bit of per run variation in the dyno results. If you take the two closest a/b runs its about a 5 wtq difference- the two farthest and its a 10 wtq improvement. I'm going to call the result "between 5 and 10 wtq."
A chart- Two with the chamber, two without:
I'm going to make production versions with a male mold I can lay up twice, and bond the halves together. Since its a male tool, the flanges can be kept on the carbon part without altering the internal shape.
Surprisingly the silicone reducer/bellmouth/larger filter part didn't show conclusive improvements. If you sort the results of all 12 dyno runs, there is a trend of the new filter results being at the top, but there is no definitive conclusion from comparing any two runs. I would guess the part is providing minimal (1whp) benefit, which is less than the per run variation, but is responsible for that sorting trend. I might try and force a large bell mouth radius on the side where I have room and see if that helps.
Attached Thumbnails 3d printed intake for N/A NA miatas-80-kjz0nnq_48f5c9f8de1fe8f1cc3495b76247050f5b4f87c9.jpg   3d printed intake for N/A NA miatas-nv5dpht.png
Old Jun 27, 2016 | 03:27 PM
  #405
hi_im_sean's Avatar
SadFab CEO
Total Cats: 1,143
someone owes you something...
good job alec
Attached Thumbnails 3d printed intake for N/A NA miatas-80-10_20dollar_20bill_4be9676a4ed668c8f85ca84b4153b35d8e070692.jpg
Old Jun 27, 2016 | 04:27 PM
  #406
stormin'norman's Avatar
Total Cats: 8
Your prototype was in good hands.
DSC_0021 by stormin'norman3, on Flickr
Attached Thumbnails 3d printed intake for N/A NA miatas-27311034914_0fcc4d482b_b.jpg
Old Jun 27, 2016 | 11:21 PM
  #407
Frenchmanremy's Avatar
Are these for sale yet?
Old Jun 29, 2016 | 11:06 PM
  #408
bbundy's Avatar
Total Cats: 146
Dam now I got to make a helmholtz out of aluminum
Old Jun 30, 2016 | 10:03 AM
  #409
asmasm's Avatar
I will have a supply helmholtz crossovers pretty soon. I don't have to do any significant work to get the molds going and I can have my brother in law churn them out while I am busy with my day job. The intake ducts require a lot more cad work, followed by machining, then making bladders... So they are going a lot slower.
Old Jun 30, 2016 | 01:50 PM
  #410
my97miata's Avatar
Total Cats: -52
How is the fitment behind the radiator? Have you considered selling them via some of the vendors like FM and 949racing?
Old Jun 30, 2016 | 02:09 PM
  #411
asmasm's Avatar
The helmholtz chambers require a coolant reroute to fit. I'm not sure how well it would fit with something like the massive TSE radiator. Maybe Nial can measure clearance on either side + the thickness of his RAD to give an idea.
I don't have one installed on my car since I don't have my new engine with coolant reroute in yet.
Old Jun 30, 2016 | 02:13 PM
  #412
You can put one on my car in a few weeks.
Old Jun 30, 2016 | 02:16 PM
  #413
asmasm's Avatar
Also,
Do people want a helmholtz effect at another RPM? I want to make a few more test parts just to see what happens when you size a Helmholtz for 5k or 7k. I'm also wondering what happens when you put multiple resonators in line. I assume you get some kind of negative wave interactions.
Old Jun 30, 2016 | 02:20 PM
  #414
Arca_ex's Avatar
Total Cats: 431
good job alec
LOL no ten dollars for those shitty graphs. Seriously what is up with that? After my car is warmed up I can lay a bunch of lines right on top of each other.
Old Jul 1, 2016 | 04:58 PM
  #415
Total Cats: 8
Sure, I can try to measure this evening. There wasn't a ton of room with the 37mm Koyo Hypercore. May be problematic with 55's and larger.
Old Jul 1, 2016 | 05:03 PM
  #416
rleete's Avatar
Total Cats: 1,344
good job alec
Shouldn't that be a 3 dollar bill?
Old Jul 23, 2016 | 07:14 PM
  #417
mkrazit's Avatar
asmasm, please don't make me buy a K&N for my VVT swap! I'm in for a copy of your latest intake design if you're up for it.
It was mentioned a couple pages back...since ABS was not offered in 1990, the theory about the ABS washer bottle makes sense. My 11,xxx VIN `90 doesn't have the hole either. Passenger side hole appears to be access to A/C receiver/drier sight glass.
Old Aug 15, 2016 | 01:16 PM
  #418
The Driver's Avatar
Total Cats: -64
Almost a month since the last post, any updates?
Old Aug 15, 2016 | 01:48 PM
  #419
dleavitt's Avatar
Total Cats: 223
I PM'd and emailed him a couple weeks ago, no dice. Maybe on vacation or something?
Old Aug 15, 2016 | 01:55 PM
  #420
Total Cats: 1,870
He has become obsessed with sim racing. He doesn't leave the house anymore.
