Craigslist Unique Finds Thread (pls scrape)
You always wanted silent and fast.
Congratulations!
On an unrelated note, I thought some of you guys might want this. I think he is only asking $80, looks black in the pictures but it's hard to tell.
https://sfbay.craigslist.org/eby/pts/6137486679.html
Congratulations!
Toterhome:
International cab over - $4000
https://dayton.craigslist.org/cto/6127063194.html
Mid eighties, 350 big cam 3. Roadranger 9 speed. Clear RV title. Previous owner hauled a pulling tractor in it. We planned to haul our race car but life got in the way and haven't had time to finish. Box is 28' long, needs help inside. Couple leaks, pretty much gutted. Cab dirty, but useable. Tires dry but hold air. Runs very well. Drove about 50 miles to get it to my shop.
Total Cats: 1,091
Trade 1988 Lotus Esprit Turbo for boat - $15000 (Hudson)
Will trade 1988 Lotus Esprit Turbo for 21' to 23' pwr or center console boat. This car has new clutch, brakes, gaskets, rt angle drive, new clutch drive at tranny, new relays, lights all work, windows and locks work, rebuilt calipers, new rotors, new tires, new and much more! Front and rear engine has been entirely rewired, new otter switch, new shift linkage bushings, great condition.https://tampa.craigslist.org/psc/boa/6142801073.html
Quick Google: "The original fan controller switch used by Jaguar, and a host of other manufacturers in the 1960′s and 70′s, was known as an Otter Switch. In its day this unit functioned adequately but technology has moved on and more reliable, solid state alternatives now exist."
Not sure if Lotus was using 1960's era Jaguar technology in 1988, but I guess it is possible.
I'd like to have a Lotus turbo and get a silk shirt and gold chain, rent a modernistic mansion and pretend like I was some sleazoid kingpin in an old Miami Vice episode. I'd invite a dozen strippers to lay around by the pool and snort coke off each other's asses just as extras to fill in the background.
He posted a Previa:
Total Cats: 7,532
https://fayar.craigslist.org/cto/6145375301.html
Moderator edit because unscraped posts in this thread are worthless
Miata With J32A2 - $12000
I'm just curious If anyone would buy my Miata. My car is loaded with goodies.
It's a special Miata as the title states. The only Honda J Swapped Miata in Arkansas. My Miata is swapped with a v6 j32a2 out of a Acura TL Type S. It's rated at 260hp from factory and has dyno 230whp stock/no tune. The swap is done with a kit from SuperFastMiata J series swap kit. For more info look up on the internet please. (No it is not fwd) lol
This is a daily street car that goes racing.
** clutch slips a little at high rpms**
Clutch is 300 bucks
DRIVABLE! I daily it.
J32a2 with 110k
6 speed Miata Transmission
Miata Roadster 6 speed short Shifter kit
Mono deep dish steering wheel
Custom spoiler (because racecar)
Torsen LSD 3.9 rear end
Solid Garage Star Diff Bushings
Flatout Suspension Coilovers adjustable for rebound and compression (2000 dollars new)
11.75" V8Roadster Big Brake Kit.
Wilwood DynaPro Calipers
APRacing J Hook Rotors fronts
949 11" Rear Big Brake Kit
949 front extended ball joints
ARP extended wheel studs
Drag DR53 16x8.25 et25
225/50r16 General GMax AS-03 80% all 4 corners
Wiring done by RPM Systems.
Miata OEM Black Hardtop with Defroster
Mishimoto Radiator
HAS AC AND HEAT!!!!!
Will come with New Sparco Sprint FIA rated racing seat not installed
Comes with NEW front Brake Hawk DTC-60 for racing at the track
There is a lot of money poured into this car and it is capable of destroying cars in autocross and road courses. This is my daily for 2 years and has been reliable since I had it. I do not want to let it go and I don't need too. My price stands at 12k. It's worth every penny. This is a Car you can daily and beat it at the track and drive it home without any worry after clutch is done of course. Driven it all over Arkansas and to autocross events and even Hallett. I trust this car to go anywhere. Even with the clutch slipping at high Rpms right now. I still drive it every day.
Txt me or call me.
Not interested in any trades. Cash talks and no joy rides and not meeting anyone up anywhere. To many people kicking rocks. If you are serious you will drive to me and have money in hand.
Clutch is 300 bucks
J32a2 with 110k
Mishimoto Radiator
Txt me or call me.
Not on CL, but a good thing to post here. Found on Car-part.com:
Hard Dog Double Hoop Roll Bar $250
Fleetwood Motors Company VARA USA-VA(King-William)1-800-800-6826
Looks like some other nice parts from the same car for somebody, too.
https://cpprohomeoh.car-part.com/ima...ck%23%20SB134#
Edit: looking at the date on the pics, it may be cannibalized by now.
