TURBO AUTO NB
Old Jan 19, 2018 | 08:18 AM
  #201
Total Cats: 3,538
So 204 kilometers per hour is 126.75 miles per hour
Old Jan 19, 2018 | 08:33 AM
  #202
mx5psi's Avatar
Total Cats: 35
No idea the dates are up the **** again too
Old Jan 19, 2018 | 08:58 AM
  #203
mx5psi's Avatar
Total Cats: 35
Old Jan 19, 2018 | 10:22 AM
  #204
Congrats!! Thats fast
Old Jan 19, 2018 | 10:23 AM
  #205
Total Cats: 4,364
ugh yeah it is.
Old Jan 19, 2018 | 10:54 AM
  #206
Total Cats: 588
10's! Way to go, faster than a Hellcat.
Old Jan 19, 2018 | 04:43 PM
  #207
miata2fast's Avatar
Total Cats: 175
Could you tell us about the launch? How much rpm can you get foot braking at the start? Any significant wheel spin?
Old Jan 19, 2018 | 05:24 PM
  #208
mx5psi's Avatar
Total Cats: 35
Im just doing a burnout in second gear and i brake boost it till i feel the front pushing no real wheel spin it scuffed a few times but all up it hooks and launches there were people video-ing at the track so hopefully there may be videos coming
Old Jan 19, 2018 | 06:42 PM
  #209
miata2fast's Avatar
Total Cats: 175
With your mph, the most optimal 60' times would be in the 1.4 range, but it takes pretty much a perfect setup. So I say you are doing pretty good. This is when a transmission brake would really help you.
I have my doubts anyone has gone as fast as you with the turbo size you are using. That right there is bad ***.
Old Jan 20, 2018 | 02:37 AM
  #210
mx5psi's Avatar
Total Cats: 35
Id hate to think of what i need to change to get a 1.4 maybe i strip weight. Im not really sure at the moment
Old Jan 21, 2018 | 05:10 AM
  #211
mx5psi's Avatar
Total Cats: 35
Default Health check
i just comp tested all cylinders within all within 5 psi and check my catch can after 6 or 7 runs and a big drive home on the freeway about 3 or 4 cold starts it only had 120mm 20mm of that looks to be water which i think is good.
my only issue and concern is the comp tester shows
Warm
CYL 1 - 100psi
CYL 2 - 95 psi
CYL 3 - 95 psi
Cyl 4 - 100 psi
Cold
CYL 1 - 95 psi
CYL 2 - 90 psi
CYL 3 - 90 psi
CYL 4 - 95 psi
it runs way too well to be broken it doesn't smoke bugger all blowby considering the boost its on so i am going to get another compression tester from work and check it is turning over very slow maybe thats it or maybe the cams (over lap i dont know ) that are throwing my readings out. it makes the same power so i am only a little worried.
Old Jan 21, 2018 | 08:39 AM
  #212
mx5psi's Avatar
Total Cats: 35
Default worked it out
its 12:36am here in aus but it was bugging me so i went and had another look in the shed and relised the Snap-on comp tester i borrowed had a very strong one way valve ( the wrong one ) so i replaced it with one of the spares from the box and checked one cylinder and boom 165psi.
so the fact that there all consistant i wont bother checking the rest.
Old Jan 21, 2018 | 12:22 PM
  #213
I was just about to suggest that its likely a low reading tester.
Consistency = key
Old Jan 21, 2018 | 04:34 PM
  #214
patsmx5's Avatar
Total Cats: 558
Well that's fast. Nice! What turbo are you running again?
Old Jan 21, 2018 | 06:53 PM
  #215
mx5psi's Avatar
Total Cats: 35
GT2871R
Old Jan 22, 2018 | 03:19 AM
  #216
mx5psi's Avatar
Total Cats: 35
the legends at fullboost did a video Excuse the interview im never good under pressure
Old Jan 22, 2018 | 01:31 PM
  #217
Lexzar's Avatar
Total Cats: 41
Why do I suddenly want an automatic...
Old Jan 22, 2018 | 09:09 PM
  #218
viperormiata's Avatar
Total Cats: 283
Bro, you did just fine in the interview. The car sounds amazing.
Old Jan 22, 2018 | 10:24 PM
  #219
A+ video, would watch again
Old Jan 23, 2018 | 12:28 PM
  #220
miata2fast's Avatar
Total Cats: 175
Agree! This build is A+ too.
