11's on the Motor, 9's on the Nitrous
Old Feb 25, 2018 | 12:47 PM
  #481
by the time the carburetors are running on this car, electronic fuel injection will be outdated and retired
....at which point he'll switch to fuel injection and we'll continue to poke fun of him
Old Feb 25, 2018 | 01:03 PM
  #482
Full_Tilt_Boogie's Avatar
Total Cats: 409
Nitrous setup looks great. Ive always been a fan of using those nylon lines with ferrules. Also, those distribution blocks look like they will actually give good equal distribution unlike those little blocks that make the nitrous make 90 degree turns.
Im sure it was probably mentioned at some point, but what is the plan for ignition?
Old Feb 25, 2018 | 01:20 PM
  #483
Total Cats: 3,591
Steam powered electric generator. And the timing is controlled by a series of pulleys and weights that detect load by acceleration forces effecting a ball moving through a curved tube of viscous fluid. It's state of the art for turn of the century internal combustion locomotives but it is well suited to competition horseless carriages utilizing nitrous well into the 1910's.
Old Feb 25, 2018 | 01:40 PM
  #484
miata2fast's Avatar
Total Cats: 175
I have always and will continue to use Electromotive ignition. Not making any changes until the car is finished.
Old Feb 25, 2018 | 02:47 PM
  #485
Total Cats: 409
I was thinking more like a centrifugal govenor, but instead using its linkage to advance the distributor
Old Feb 25, 2018 | 03:44 PM
  #486
Total Cats: 593
You guys know I'm about to invent fuel transportation technology right?
Perfectly atomized compressed fuel, instantly in the combustion chamber at the moment of ignition, already lit. You just need to get the orientation of the tank and each cylinder to the ECU exactly right, then account for any engine movement
Old Feb 25, 2018 | 04:19 PM
  #487
miata2fast's Avatar
Total Cats: 175
You guys are so ridiculous. How is all that going to work with my weight reduction goals?
Old Feb 25, 2018 | 08:07 PM
  #488
Total Cats: 409
Were thinking about this all wrong. Lose the engine. Solid rocket booster. 60ft wont be great but trap speed should be insane.
Old Feb 25, 2018 | 09:31 PM
  #489
Total Cats: 3,591
Hydrogen is lighter than gasoline, just saying. Figure out how.
Old Feb 25, 2018 | 09:32 PM
  #490
Total Cats: 146
I mean, he's going to fill his tires with it right?
Spoiler
Old Feb 26, 2018 | 06:47 PM
  #491
miata2fast's Avatar
Total Cats: 175
To support the nitrous solenoid and keep the whole thing from drooping, I made this bracket.
Old Feb 26, 2018 | 07:57 PM
  #492
miata2fast's Avatar
Total Cats: 175
Here it is installed. It could use a little whittling, but I can get to all the fittings and fasteners to tighten them properly.
Old Feb 27, 2018 | 05:57 PM
  #493
miata2fast's Avatar
Total Cats: 175
Nitrous? What Nitrous?
its just an ole spec Miata with granddaddies carbs off his Austin Healy. How much money you want to race for?
Old Feb 27, 2018 | 07:15 PM
  #494
patsmx5's Avatar
Total Cats: 559
Looking really good. What nitrous kit is that? Asking for a friend.
Old Feb 27, 2018 | 08:12 PM
  #495
thumpetto007's Avatar
Total Cats: -117
Old Feb 27, 2018 | 08:16 PM
  #496
Total Cats: 593
Sleepers are the best!
Although the super nice fueling stuff kinda gives you away. Are there specific Miatas that look like that?
Old Feb 27, 2018 | 08:20 PM
  #497
Total Cats: 593
And those look more like high end porsh carbs than Austin Healy ones to me. I only got $20 on my car.
  #498
miata2fast's Avatar
Total Cats: 175
It started out as a Wilson Manifold fogger kit, but because the starter was in the way, I Frankenstiened it with parts from NOS and Speedtech.
Old Feb 27, 2018 | 08:23 PM
  #499
Total Cats: 593
It's the M2F NoskTowPuss kit
Old Feb 27, 2018 | 08:33 PM
  #500
miata2fast's Avatar
Total Cats: 175
I doubt this kind of system has ever been done on Miata.
My ruse would likely only work on the most naive and ego driven meatheads.
