New Cheap Aluminum wing option
Old Mar 20, 2018 | 01:29 PM
  #61
Originally Posted by Uncle Humjaba
Aero merits of said big **** aside, 160mph at road Atlanta in a Miata is insane.
Got to love that LS motor.
Old Mar 23, 2018 | 12:26 PM
  #62
Morello's Avatar
Total Cats: 45
Yep, I've been passed many a time by that car between turn 7 and 10...
Old Mar 26, 2018 | 03:58 PM
  #63
UrbanSoot's Avatar
Total Cats: 18
Results are available - Nine Lives Racing: The "Big ****" test
Old Mar 26, 2018 | 04:17 PM
  #64
matrussell122's Avatar
Total Cats: 517
How long is the pre order discount going to last?
Old Mar 26, 2018 | 08:25 PM
  #65
Wingman703's Avatar
Total Cats: 659
Originally Posted by UrbanSoot
You mean this bigger 2D wing was less draggy and faster then a smaller 3D wing used incorrectly and mounted to high? Shocking.
Not knocking 9LR, I would have picked up one of these myself if I had not completed building my own wing literally a week before these were announced. But I still want to see real CFD/wind tunnel testing for numbers and lift/drag, not skewed tests vs a 3D wing before I sing their praises.
Old Mar 27, 2018 | 05:31 PM
  #66
OGRacing's Avatar
Total Cats: 33
I wave, every single time.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
Old Mar 30, 2018 | 11:41 AM
  #67
soot's Avatar
Total Cats: 81
So I posted on 9LR's facebook saying they should provide some data we could use to compare to the APR wings, and they just tagged me back this morning. Here's the free air data they just added to their site. Looks pretty damn good actually. Compare to the charts in my post #53.
Old Mar 30, 2018 | 02:51 PM
  #68
Wingman703's Avatar
Total Cats: 659
Those are pretty impressive numbers and look like they could be improved considering the lack of a gurney. Can't help but notice this was on a 70" wing, not the 64"/68" that are legal for most miatas in various classes. Still 200lb of downforce @100mph with only 20lb of drag sounds pretty dam noticeable.
Old Mar 30, 2018 | 03:16 PM
  #69
soot's Avatar
Total Cats: 81
My thoughts exactly. I'm trying really hard to resist picking one up now...
Also, yes 9LR's CFD is on a 70" wing, but APR does not list the size they tested the GT-250 with. Since the largest size they offer is a 71", I'd assume that APR's numbers are based off of their biggest ****.
73lbs at 60MPH and 10° without a flap sounds pretty decent too...
Old Apr 4, 2018 | 04:54 PM
  #70
ChrisLol's Avatar
Total Cats: 75
So I did a thing... and I'm very happy with it.
The endplates were just to center the airfoil in the box for shipping. I'll be fabricating my own uprights and endplates. I'll also be getting a range of gurney flap sizes to test/tune that aspect.
Old Apr 6, 2018 | 04:22 PM
  #71
G3ML1NGZ's Avatar
Total Cats: 109
I'll most likely be going with that wing too. please keep us updated and enjoy
Old May 22, 2018 | 09:43 AM
  #72
ChrisLol's Avatar
Total Cats: 75
Quick update.
Disclaimer: I am not a professional. I'm not sure how this is normally done but this is how I did it.
Old May 22, 2018 | 12:54 PM
  #73
icantlearn's Avatar
Total Cats: 118
Now THAT, is awesome. Props to you sir. Just an idea, if you have time to burn, you can grind the forward facing edges of the stands down so they look more like a knife blade if that makes sense. I hear it helps with drag slightly.
Old May 22, 2018 | 01:05 PM
  #74
acedeuce802's Avatar
Total Cats: 175
You'd actually want to knife blade the rear, and teardrop the front!
Old May 22, 2018 | 03:19 PM
  #75
ChrisLol's Avatar
Total Cats: 75
Front edges are rounded, rear edges are clipped 45º (Best I could do with my handheld router)
That's right. The uprights were HAND routed from 3/8" plate. Mounts and endplates were cut with a laser. Shoutout to Paco Motorsports.
Old May 22, 2018 | 03:24 PM
  #76
ryansmoneypit's Avatar
Total Cats: 458
Dont worry, everyone who was never into airplanes thinks this too.
Old May 22, 2018 | 04:04 PM
  #77
icantlearn's Avatar
Total Cats: 118
Like I said, I know nothing about aero. Im the guy with cables holding his wing on after all. Proceed.
Old May 22, 2018 | 06:34 PM
  #78
Junkwhale's Avatar
Any easy options for a gurney flap?
The wing profile has a slot to allow one to slide in one from the sides...but would require the right profile / the right extruded piece:
Old May 22, 2018 | 07:30 PM
  #79
psyber_0ptix's Avatar
1-3% of chord length according to https://www.sciencedirect.com/science/article/pii/S136988699800010X
Nlr states ~9.5" chord length ergo 0.095-.285" for the flap length. The channel embedded in the wing is about 0.285" already.
Maybe find some aluminum or carbon fiber angle stock to fit?
I measured the width of the channel at 0.086" so that's the approximate limit to how thick the gurney can be to utilize that spot.
Old May 22, 2018 | 10:45 PM
  #80
Junkwhale's Avatar
Maybe find some aluminum or carbon fiber angle stock to fit?.
It looks like it's designed with something specific in mind which was why I was asking. Using some 90 degree aluminium angle stock it looks like your gurney flap will stick at an odd angle. Could just be the picture that looks like though I guess...
