DIY Miata hood vents?
Old Dec 19, 2011 | 10:47 PM
  #61
chpmnsws6's Avatar
You might need to add more pins behind the headlights, dzus fasteners at least.
http://streetperformanceusa.com/i-72...r-10-pack.html
Old Dec 19, 2011 | 10:53 PM
  #62
orion4096's Avatar
Total Cats: 19
Originally Posted by pusha
Those vents are like $54 from the Ford dealer, right?
That sounds right. I paid just under $70 shipped.
Old Dec 20, 2011 | 05:25 PM
  #63
chpmnsws6's Avatar
http://forum.miata.net/vb/showpost.p...0&postcount=80
2nd picture for an idea. It looks clean and would only cost 10-15 dollars from the hardware store.
Old Dec 20, 2011 | 05:40 PM
  #64
240_to_miata's Avatar
Total Cats: 16
shameless plug.
I have an R56 MINI scoop up FS in the classifieds.
I will probably do a vent when my car begins to see more track time.
Old Jan 9, 2012 | 10:00 PM
  #65
orion4096's Avatar
Total Cats: 19
Someone asked for underhood shots. I forgot to peel off that red tape before riveting it down... I have some TB clearance issues up front so the vent is pretty far forward. It looks like a good spot for airflow with it being right behind the radiator. The hood is stiff enough that I'll probably not reinforce it, but it flexes a bit when raising and lowering. You can shave off some of the honeycomb area if you want another 1/4" of clearance. I might do that if the hose clamp on the TB coupler rubs.
Attached Thumbnails DIY Miata hood vents?-fa2fda4d.jpg   DIY Miata hood vents?-89cf3b3a.jpg   DIY Miata hood vents?-a921edc4.jpg
Old Jan 10, 2012 | 01:27 AM
  #66
vehicular's Avatar
Total Cats: 47
Can you post a more direct under hood shot, like perpendicular to the vent?
Old Jan 10, 2012 | 10:54 PM
  #67
orion4096's Avatar
Total Cats: 19
Like dat?
Old Jan 10, 2012 | 11:38 PM
  #68
vehicular's Avatar
Total Cats: 47
Perfect. Expect pics of mine... as soon as I can get this damn exhaust project finished up.
Old Jan 11, 2012 | 01:21 AM
  #69
miatamike203's Avatar
Here is a pic of what i had, it help keep the air going into my turbo cold.
Its hard to see but its that piece of aluminum on the hood. Its on the dip of the hood so that it wouldn't stick out into the air stream so much.
Old May 28, 2012 | 04:26 AM
  #70
Sentry's Avatar
Ha, I had one of those Ford vents on my Civic.
http://www.d-series.org/forums/diy-f...r-install.html
I didn't put a whole ton of thought behind my choosing of the location for it, I just ballparked where the low pressure zone on the hood "should" be and stuck it there. Plus with it being FWD, it was also ventilating the hell out of the turbo that was cooking my hood.
Ignore the dryer duct, it was temporary. Car was my DD and had to drive it to work while I finished the actual 4" intake.
Old May 28, 2012 | 07:44 AM
  #71
TNTUBA's Avatar
Total Cats: 283
I don't know if you consider this DIY since I installed a pre made set of louvers but here is my hood.
The louvers are made by this company.
http://www.hoodlouvers.com/
Attached Thumbnails DIY Miata hood vents?-431699_10150574098164242_500104241_8848179_24136851_n.jpg   DIY Miata hood vents?-393857_10150572904339242_500104241_8844043_1514386159_n.jpg
Old May 28, 2012 | 07:32 PM
  #72
oscargarza88's Avatar
Originally Posted by chpmnsws6
Thanks guys. Through a PM from a fellow swap member, I think a Carbontrix hood vent might be the solution after seeing the thread Levnubbin posted. Apparently, "extraction hood" brings up a better idea of what I was after.
Hoping the hood will come out about like this. The bump in the vent should intensify the venturi effect, helping to pull the air out of the radiator.
Is there more pictures of his car?
Im really liking his hood louvers. and bumper naca duct intake thing. ive been looking into ways to cut up the bumper but make it look good too.
I already have the mini scoop reversed just want to get some more air in/out on the driver (supercharger) side.
By oscargarza88 at 2012-04-15\
Also want to get more air flowing thru the intercooler which it seems like a hole in the bumper will be the best solution to doing so...
Uploaded with ImageShack.us
Old May 29, 2012 | 09:15 AM
  #73
njn63's Avatar
Total Cats: 15
Just as a public service announcement: don't use fasteners like that on a hood. Nothing worse than watching a car burn while people try to find a dzus wrench... nevermind if something happens on track when your tool is in the pits.
They make ones that look like wing nuts that will create a tiny amount of aero drag but at least a corner worker can open the hood. Always need to plan for the worst case scenario.
Old May 29, 2012 | 07:05 PM
  #74
Total Cats: 1,924
Where are you guys getting these GT500 vents? I keep seeing references to a $32 or $54 price on other forums, but best price I can find is closer to $64. PN is AR3Z-16C630-AA if that helps anyone.
For refrence, my local Ford stealership parts dept wants $128
Old May 29, 2012 | 11:18 PM
  #75
573's Avatar
573
Total Cats: 17
I'll play.
Old May 30, 2012 | 11:46 AM
  #76
vehicular's Avatar
Total Cats: 47
Ford quadrupled the price over the last few years. I paid a little under $80 for mine after shipping, which was the best price I could find at the time.
Old May 30, 2012 | 01:23 PM
  #77
Total Cats: 1,924
Originally Posted by 573
I'll play.
Ooo, very nice! Props for posting pics and datalogging with airflow indication filament
Last image appears to be a screencap from a video, possible its posted somewhere?
DAMN YOU FORD! DAAAAMN YOUUUUU!!!!
I've been thinking about picking up an extra hood and a '500 vent, mostly for the funsies. My car needs a 3rd panel of a different color before anyone will take it seriously anyway.
Old Jun 2, 2012 | 01:57 AM
  #78
elesjuan's Avatar
Total Cats: 43
http://www.tousleyfordparts.com/part...&siteid=214771
$63.32 + shipping.
Old Jan 28, 2013 | 06:29 PM
  #79
MatosMiata's Avatar
This thread and others like it on other Miata sites and the S2000 forums led me to doing some hood vents. I did one large one right behind the radiator and before the engine block and some triangular venting on the driver's side. They will be painted black so they don't look so ghetto. Disregard the black stripes, we did a vent on my buddy's AE86 hood and he painted them on while forgetting my hood is aluminum and will not rust. My whole car is being painted soon so that will be gone. So far we have both noticed a reduction in fumes in our cars and watched the heat pour out of there while we drive. My buddy reports reduced drag, but I think that's all in his head
Attached Thumbnails DIY Miata hood vents?-391280_10151485164587868_1087107279_n.jpg   DIY Miata hood vents?-74131_10151472197402868_334023628_n.jpg
Old Mar 11, 2013 | 06:43 PM
  #80
sonelane's Avatar
Total Cats: -2
Originally Posted by GeneSplicer
I didn't pay attention to all the low/high pressure ****... mine works - maybe not the MOST effecient but works none the less... it always lets me know when I have a loose (likely missing) flange bolt as I puff smoke out the vent during decel - sucking oil through bad exhaust valve stems - or the journal bearing.
So rain wise would this be bad to do if I get a lot of rain where I live?
Attached Thumbnails DIY Miata hood vents?-033.jpg   DIY Miata hood vents?-img00256.jpg   DIY Miata hood vents?-img00386.jpg
