View Poll Results: Would you get the BEGi S3 or FM2 system
BEGi S3
29
31.52%
FM2
63
68.48%
Voters: 92. You may not vote on this poll
BEGi S3 vs FM2
Old Oct 25, 2012 | 10:37 AM
  #41
nitrodann's Avatar
Total Cats: 66
Ok dont give opinions lol. Ill just tell you all when its done in a month or 2.
Dann
Old Oct 25, 2012 | 10:40 AM
  #42
I tuned a 94 with a log and 2560 a little while ago made 240wph on 14psi on crappy 91 cali ****
Old Oct 25, 2012 | 10:51 AM
  #43
nitrodann's Avatar
Total Cats: 66
In for turbotims reply, hes been in this thread like 25 minutes so far.
Tim you had better be typing.
Dann
Old Oct 25, 2012 | 10:54 AM
TurboTim's Avatar
Total Cats: 425
did you turn up the boost? I have yet to see a 2560 setup NOT make 220rwhp.
a few examples:
all the above are the 2560. all will make 250rwtq at 3700RPM. 5 different motors/setups. I believe 3 of them are on logs, 2 being BEGi logs.
To the best of my knowledge, all were at 12psi or more.
If that's Jes maggs (Paul's wife), then that's a 2554, begi "log", my downpipe & exhaust. That would be the only graph with a "log" manifold if you want to call BEGI's a log. It's big, it's heavy, but it's not wood.
Paul's machine and Artieparty were my centered/low mount manifold and exhaust, same as Hustlers minus the Vband/EWG glory.
saintfoo was my A/C P/S low mount manifold (like the above with just a little more offset to clear A/C P/S)
The last dyno posted is TurboTim's:
a true log.
That manifold definitely was not a log, or at least my definition of one. It's much more 'directed pulse' than BEGI's claim.
A better view:
Granted, my second did feel better but I don't have a dyno plot of it apparently. This was my favorite BP manifold with my 2560. This had no pipes pointed directly at another pipe, but the collector area is the same between each manifold.
ScottFW has a vband/EWG version of this.
btw, 18psi, the one that hit 310rwhp did not need 18-20psi--it needed 17.
310rwhp @ 17psi, 304rwhp @14psi. The limits of that 2560.
Originally Posted by hustler
I know Paul's old 300whp dyno...I'm not putting that car on the track because it won't make it home.
Probably because it still ran the stock oil pump, not because of the tune or turbo kit. Well, maybe add some inconel hardware.
To answer the OP, I would wait for Trackspeed's turbo kit.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Oct 25, 2012 | 10:58 AM
  #45
TurboTim's Avatar
Total Cats: 425
Dann
buaahwahahahaa you got me!!
Old Oct 25, 2012 | 11:02 AM
  #46
Total Cats: 4,368
i thought magg's curve looked different; thanks for the elaboration on my deficiencies.
Old Oct 25, 2012 | 11:06 AM
  #47
TurboTim's Avatar
Total Cats: 425
And I think mine is the only one with a '94 block/head/intake (sorta). All the others had some sort of '99 head and some ran BEGI's old cast intake manifold with a 70mm TB...Paul's and Saintfoo's. Artie ran various versions of gutted OEM intakes or not so i don't know what his plot was done with.
Old Oct 25, 2012 | 11:13 AM
  #48
nitrodann's Avatar
Total Cats: 66
Either way the findings here show that the flow maps are spot on and that 300-ish is what a 2560 will flow on premium. So Im hoping for 350 on E85.
Would that be some sort of record?
Also we will find out how far the stock 1.6L IM will go with stock TB. 300 so far.
Dann
Old Oct 25, 2012 | 11:16 AM
  #49
I'm pretty sure 350 on a 1.6 and 2560 will be some sort of record. Esp on stock head/im/tb.
Old Oct 25, 2012 | 11:43 AM
  #50
Total Cats: 4,368
i dont see it happening. that turbo is TAPPED out.
Like it got hit with the Tranny Press.
Old Oct 25, 2012 | 11:47 AM
  #51
nitrodann's Avatar
Total Cats: 66
True on gasoline. But E85 has 12% more torque potential and that's 36hp alone at this rate. 310+36 is dangerously close to 350hp.
Dann
Old Oct 25, 2012 | 11:51 AM
  #52
Total Cats: 4,368
but its well outside it's efficency range, e85 be damned.
it's all about the floooooooooooow.
look at the difference between 14psi and 17psi. 10hp, but gobs of midrange torque...the thing is tapppppped out.
unless you fit it in a .86 a/r housing, i dont see it happening; just a lot of hot air.
Old Oct 25, 2012 | 12:19 PM
  #53
lol yeah, I don't think you get how this works man: e85 doesn't magically add flow capacity to your turbo. Once its tapped out, its tapped out. You'll squeeze maybe a couple more hp by running insane timing, but once you're off the maps, you're pretty much done
Old Oct 25, 2012 | 12:42 PM
  #54
Total Cats: 4,368
especially since both the compressor AND turbines are tapped out.
Old Oct 25, 2012 | 02:58 PM
  #55
+1
Old Oct 25, 2012 | 10:33 PM
  #56
nitrodann's Avatar
Total Cats: 66
I think you have forgotten that the energy potential of E85 at stoich is 12% greater than gasoline.
This car went from 255rwhp to 280 just by switching to E85 without adding any more boost.
If 310whp can be done on petrol 340 can definately be done on E85 on the same setup.
Dann
Old Oct 25, 2012 | 10:39 PM
  #57
lol ok try it
lolol
Old Oct 25, 2012 | 10:52 PM
  #58
nitrodann's Avatar
Total Cats: 66
I cannot believe you genuinely dont believe that E85 has a higher energy output than petrol at stoich. You played with E85 before? Come on 18, you are clevererer than this.
Dann
Old Oct 25, 2012 | 11:05 PM
  #59
You serious?
I have been tinkering with e85 for years now. Tuning subarus and evos, and a few miatas too (including my own).
I'm not even discussing its energy output with you, so I'm not denying or agreeing with that statement because frankly it has nothing to do with this.
I'm saying your turbo is TAPPED OUT at 300. This has nothing to do with e85 and everything to do with your turbo and setup. IF you still don't understand what me, brain, and savington are saying, I don't think there's even a point in arguing something so retarded.
if you had a well breathing exhaust, good manifold, and spiked the timing to kingdom come, you'd STILL fall short of a true 350whp on a 1.6 with a 2560.
You can call me an idiot, but I challenge you to prove us wrong.
PS: Sav has tuned more miatas than most of us put together. Ask him if you don't believe me.
Old Oct 25, 2012 | 11:35 PM
  #60
nitrodann's Avatar
Total Cats: 66
I do challenge you and will build it in the coming month or 2.
It doesnt matter what the turbo will make on one fuel if another fuel has a higher energy output. Flow maps are in airflow, not horsepower, and without knowing the efficiency of the cumbustion chamber (lol, rubbish) and the specific energy output of the fuel theres no way to convert flow to power which is what you are trying to do.
Dann
