The AI-generated cat pictures thread
Old Mar 25, 2013 | 09:01 PM
  #16441
Joe Perez's Avatar
Boost Pope
Total Cats: 7,532
As much as multi-link designs bother me (why so many moo-ving parts), and as much as it pains me to say something nice about Audi, I do kind of like the design that 2GR posted.
Old Mar 25, 2013 | 09:11 PM
  #16442
Full_Tilt_Boogie's Avatar
Total Cats: 409
errybody so jelly of mah rear suspensions:
Attached Thumbnails The AI-generated cat pictures thread-mustangirs_lead.jpg
Old Mar 25, 2013 | 10:11 PM
  #16443
Joe Perez's Avatar
Boost Pope
Total Cats: 7,532
Pt 1:
Pt 2:
Here is a typical rear suspension from a common pickup truck:
One of the shock absorbers is mounted (at the bottom) to the rear of the axle tube, and the other is mounted to the front of the axle tube.
Can someone please explain to me why this is? It bothers me every time I see this on the road.
Old Mar 25, 2013 | 11:41 PM
  #16444
Total Cats: 1,410
I believe that's a 3-link setup, and they're used to help keep it from rotating, something a 4-link does a better job of. I could be completely wrong though.
Old Mar 25, 2013 | 11:45 PM
  #16445
Bryce's Avatar
Total Cats: 35
Axle wrap would be my guess.
Attached Thumbnails The AI-generated cat pictures thread-17-e1329341861160-640x228.jpg
Old Mar 26, 2013 | 12:06 AM
  #16446
Joe Perez's Avatar
Boost Pope
Total Cats: 7,532
Axle wrap. Makes perfect sense.
Old Mar 26, 2013 | 04:41 AM
  #16447
triple88a's Avatar
Total Cats: 1,830
Thats a torsion bar setup. Biggest garbage system out there since you get a mile of bump steer. This is a 3 link. As you see the top link is solid, usually they are in a triangle like the bottom pic. In my opinion that is better than the 4 link setup.
Attached Thumbnails The AI-generated cat pictures thread-11538166420.jpg   The AI-generated cat pictures thread-rearsuspen.jpg
Old Mar 26, 2013 | 06:28 AM
  #16448
oilstain's Avatar
Total Cats: 76
Originally Posted by 2ndGearRubber
Positive camber gain is inherent in the strut design. Personally, I don't think it can be designed out. However, based on the way the steering-angle inclination is designed, and the new lower mount attachment in relation to the knuckle, I would be swaying towards saying positive camber gain would be less than a traditional Mc-strut. Again, I have nothing to prove this, just my take on the new design.
Audi is using the below suspension now, multi-link front. Finding and replacing ball joints in that mess will be a pain in the ***.
You don't replace ball joints, you replace all control arms and inner and outer tierods at once. God help you if you don't do them all at once because that sonofabitch will start to clunk again in a month or so. Have fun with the pinch bolt, it's an adventure.
Old Mar 26, 2013 | 12:34 PM
  #16449
2ndGearRubber's Avatar
Total Cats: 18
Except most customers refuse to do that. Otherwise I'd be putting in a water pump with almost every timing belt. They fix what's broken, wait for the rest to fail. Timing belt snaps, they skip the WP, they come in 20k later bitching about a failed water pump nose bearing.
Although with the system having so many moving parts, I would no be surprised if one failure leads to subsequent failures in a domino effect. I'm sure slop in one ball joint will lead to wiping out everything else in short order.
I was more referring to the difficulty of determining which ball joint is bad, with both being located so close together. I'll probably just lift the the car up a 1/4 inch, stick a pry-bar under the tire, and do the wiggle test, just like on a pickup.
Attached Thumbnails The AI-generated cat pictures thread-431112d1331412150-w124-front-suspension-safety-critical-bentmerc.jpg
Old Mar 26, 2013 | 01:27 PM
  #16450
Total Cats: 4,370
this is for joe:
http://www.smbc-comics.com/comics/20110423.gif
Attached Thumbnails The AI-generated cat pictures thread-20110423.jpg   The AI-generated cat pictures thread-20110423.jpg   The AI-generated cat pictures thread-20110423.jpg   The AI-generated cat pictures thread-20110423.jpg   The AI-generated cat pictures thread-20110423.jpg
Old Mar 26, 2013 | 01:31 PM
  #16451
Total Cats: 4,370
you got to be kidding me.
Old Mar 26, 2013 | 01:37 PM
  #16452
mx5autoxer's Avatar
Total Cats: 57
What is this, a comic strip for ants?!
Attached Thumbnails The AI-generated cat pictures thread-579077_10200963023825703_1008948365_n.jpg
Old Mar 26, 2013 | 02:12 PM
  #16453
Total Cats: 4,370
Old Mar 26, 2013 | 05:36 PM
  #16454
Total Cats: 409
fixed, maybe? i dont even know the rulez
Attached Thumbnails The AI-generated cat pictures thread-src_1340506006268.jpg   The AI-generated cat pictures thread-src_1340506006268_zpsec0f18ad.jpg
Old Mar 26, 2013 | 07:23 PM
  #16455
viperormiata's Avatar
Total Cats: 283
DR's, full body weight and still IRS. lol
Dat wheel lift. Perfect carry, good lord.
Old Mar 26, 2013 | 09:11 PM
  #16456
Total Cats: 18
Old Mar 26, 2013 | 09:27 PM
  #16457
Total Cats: 18
Old Mar 26, 2013 | 09:40 PM
  #16458
Total Cats: 18
Old Mar 26, 2013 | 09:49 PM
  #16459
mgeoffriau's Avatar
Total Cats: 474
I cried.
Old Mar 26, 2013 | 09:58 PM
  #16460
Enginerd's Avatar
Total Cats: 77
Got a new toy in the mail today:
