95m goes kinda fast for kinda cheap
Old 03-01-2017, 09:57 AM
  #141
Depends on weight. 103 might be a little optimistic. I did 101ish at 220hp.
Old 03-01-2017, 10:01 AM
  #142
Forrest95M's Avatar
Total Cats: 21
Car has ps and abs with cc and ac deleted, still . Car is probably 2300lbs?
Maybe reading sonofthehill's thread are getting me too optimistic
Forrest95M is offline
Old 03-01-2017, 12:23 PM
  #143
You can't use launch control because MS1, right?
That'd be a pretty sweet use of ABS! Honestly, I wish I had ABS for only this reason. Well, and the fact that it helps save you from getting flat spots on tires too easily...
Old 03-01-2017, 01:17 PM
  #144
ABS != LC. It can do traction control with extra hardware.
If it's your first trip to the strip then you are probably a bit optimistic. Launches are the most important part.
Old 03-01-2017, 02:18 PM
  #145
Whoops. Thanks for the correction. I thought you could program the abs computer to do other fun stuffs.
Old 03-01-2017, 02:19 PM
  #146
You can use the abs sensors to do traction control things, but the abs computer doesn't do anything but abs
Old 03-01-2017, 02:55 PM
  #147
Yeah, that's what I was getting at I think. Thanks for clearing up the confusion though!
Old 03-01-2017, 04:22 PM
  #148
Total Cats: 3,019
MS1 has launch control. I haven't tried it.
sixshooter is offline
Old 03-01-2017, 10:44 PM
  #149
Forrest95M's Avatar
Total Cats: 21
Really? I'm running the original v3.0 DIY kit, not a pnp, I remember seeing greddygalant running it on his gen 1 pnp along with flatshift.
Old 03-02-2017, 07:25 PM
  #150
Total Cats: 3,019
Brain MS1:
Old 03-02-2017, 07:58 PM
  #151
The_WW's Avatar
Planning on going to new england drag way in april for their street nights, any idea on what my car will run at 10 psi? Friends think it should be around 13.7 @ 101 mph
I'm so down to make the trip up to Epping with you. Let me know when you go! Plus, I'll make you look great I've never dragged before. Would love to get kicked out because of no roll bar
The_WW is offline
Old 03-02-2017, 08:36 PM
  #152
Forrest95M's Avatar
Total Cats: 21
Brain MS1:
I actually wired up launch control tonight, but flat shift doesn't seem to want to work. The only hiccup I had was that I couldn't add another wire through my harness so I had to run a single wire from the ms to the car side of the harness. This thread helped me a lot Megasquirt Support Forum (MSEXTRA) ? Can someone identify mods? Launch control? (View topic)
The only reason I asked is because I have no idea whether you have a 3.0 diy or gen 1 pnp. I don't know if you have to mod the gen 1 pnp to get launch control/ flatshift
Old 03-02-2017, 08:37 PM
  #153
Forrest95M's Avatar
Total Cats: 21
I think you can run no roll bar in epping as long as you don't run anything faster than like a 13 flat
Old 03-02-2017, 08:40 PM
  #154
The_WW's Avatar
Oh thought it was a 13.99. Maybe that's for having a passenger? Either way I'm in
The_WW is offline
Old 03-02-2017, 08:43 PM
  #155
Forrest95M's Avatar
Total Cats: 21
Wednesday Street Night | New England Dragway
13.99 or faster needs a helmet
13.49 convertible or faster needs a rollbar, I doubt either of us will run under a 13.5 being my first time aswell
Old 03-02-2017, 08:47 PM
  #156
The_WW's Avatar
Wednesday Street Night New England Dragway
Well I guess that's the new goal! But yeah I agree not making the power even if we had the skill
The_WW is offline
Old 03-02-2017, 08:53 PM
  #157
Forrest95M's Avatar
Total Cats: 21
I just hope my dump pipe doesn't qualify as an open exhaust
Old 03-02-2017, 09:10 PM
  #158
The_WW's Avatar
Going to assume it won't. They would need to look under the car to see where it ended. Imagine test and tune tech will be fairly straightforward
The_WW is offline
Old 03-03-2017, 12:54 PM
  #159
Colipto's Avatar
Total Cats: 28
I'm in on this, epping is where i always go
Colipto is offline
Old 03-03-2017, 01:24 PM
  #160
adamiata's Avatar
Total Cats: 78
I'm local to Epping but haven't been to the dragway in a while. Would love to get my car out there the same night you guys do, if I can get my car sorted out in time.
adamiata is offline
Quick Reply: 95m goes kinda fast for kinda cheap
