Trackspeed build plan
Old 10-23-2016, 01:00 PM
  #101
wackbards's Avatar
Total Cats: 266
If you're having difficulty with hex keys/fastener tolerances, spend a few bucks and buy an aerospace grade hex key. SAE hex tolerances are sloppy in comparison. SAE hex keys can cause a ton of grief if they're used on aerospace grade fasteners.
wackbards is offline
Old 10-30-2016, 09:53 PM
  #102
farpolemiddle's Avatar
Total Cats: 95
Originally Posted by 18psi
inb4trannypresscrew
​​​​​​​I didn't get this until I literally bench pressed in the tranny today.
farpolemiddle is offline
Old 10-30-2016, 10:04 PM
  #103
icantlearn's Avatar
Total Cats: 117
#gainz #swoll
icantlearn is offline
Old 11-01-2016, 01:19 AM
  #104
Total Cats: 95
Made some progress. Clutch is done and the tranny is back in. Downpipe is in. V band for the win. I don't know who invented the V band but I hope they became rich. There is about 1/8 inch clearance between the back shelf.
A couple of stupid questions.
Does the turbo oil feed looked right? The instructions describe it this way but I want to make sure there is not too much angle.
What orientation does the lower downpipes need to be?
Any advice on how I am going to deal with the getting the intercooler pipping through this mess?
Old 11-01-2016, 03:56 AM
  #105
Total Cats: 95
Something like this?
Old 11-01-2016, 04:36 AM
  #106
Total Cats: 1,681
Put on the rest of your exhaust to figure out DP orientation.
As for cold side IC piping. You pull off that line going to the idle valve, then run a 90 couple straight down. Cut the idle valve line short and hook it up to the IC pipe.
shuiend is offline
Old 11-01-2016, 08:46 AM
  #107
A reroute helps a ton with fitting I intercooler piping too
Old 11-01-2016, 09:12 AM
  #108
Onyxyth's Avatar
Total Cats: 62
Just curious, could snap a pic of your chassis to downpipe to transmission clearance? I want to compare it to mine.
Onyxyth is offline
Old 11-01-2016, 12:52 PM
  #109
Total Cats: 95
​​​​​​​Yeah I figured as much but I am not putting the reroute on yet.
Old 11-01-2016, 09:43 PM
  #110
Total Cats: 95
​​​​​​​best I could do.
Old 11-01-2016, 09:46 PM
  #111
Total Cats: 95
Used grease to mark where I need to cut the hood for the wastage actuator.
Nevermind. I just nutted up and cut it. Somehow my hood got tweaked sitting on the side of the house so of course it fits like **** now. I am glad this is not a show car because I swear the metal is so thin it is impossible not to **** it up when you get near it.
Old 11-01-2016, 11:03 PM
  #112
icantlearn's Avatar
Total Cats: 117
I had to cut my package tray and bend some brake lines to fit mine. You have to keep in mind that you need to leave enough clerance for everything to move when the motor is shifting.
Old 11-01-2016, 11:06 PM
  #113
Total Cats: 95
Yours is a lot farther back than mine. Have you checked your PPF alignment?
Originally Posted by MiataMan00
I had to cut my package tray and bend some brake lines to fit mine. You have to keep in mind that you need to leave enough cleanse for everything to move when the motor is shifting.
Old 11-01-2016, 11:12 PM
  #114
icantlearn's Avatar
Total Cats: 117
no, how would that effect anything? the motor is bolted to the subframe.
Old 11-01-2016, 11:15 PM
  #115
Total Cats: 95
The motor mounts have a lot of front to back deflection. The PPF bolts to the rear of the tranny and ties in to the rear end. If you have the PPF set too low the engine can lean further back. If the PPF is set higher it tilts the motor further forward. At least thats what I just experienced a few days ago when I put my tranny back in. I could be wrong though.
Old 11-01-2016, 11:26 PM
  #116
icantlearn's Avatar
Total Cats: 117
hmm. I did swap my diff so that possibly could have done something weird but I doubt it. I never touched the tranny side.
Old 11-02-2016, 01:07 AM
  #117
Total Cats: 2,100
There is so much tolerance stacking in that location. The unibody to the subframe tabs, the subframe itself, the dimensions on the motor mount, the exact location of the cylinder head manifold studs, the exact location of the manifold fasteners, and the bend dimensions on the downpipe itself will all alter that clearance. The range is from "fits by 1/8 inch" to "needs 1/8" trim on package shelf".
Savington is offline
Old 11-02-2016, 01:13 AM
  #118
icantlearn's Avatar
Total Cats: 117
you also have an NA and I have a NB so that might have something to do with it
Old 11-02-2016, 09:34 AM
  #119
Total Cats: 1,148
Might also help to change to a NB throttle body and IAC.
curly is offline
Old 11-02-2016, 11:40 PM
  #120
Total Cats: 95
I don't get why people have such a hard time with the hot side pipping? Mine has plenty of room. Here is the mock up. Cold side will still be the bitch.
Quick Reply: Trackspeed build plan
