Old 08-24-2017, 02:29 PM
  #1081
psyber_0ptix's Avatar
Yea, this weekend I'll take some time to simplify the fuel stuff and get rid of a bunch of intersecting lines. Re plumb the vacuum things and run everything off the back end. I hope this solves the oscillation.
I'll relocate the sensor to the frame or firewall, but it says in it's specs that it's able to withstand vibration from 100-20,000Hz, 20g sinusoidal.
psyber_0ptix is offline
Old 08-24-2017, 04:05 PM
  #1082
send new logs once everything is fixed so we're not putting a bandaid on a bandaid
Old 08-24-2017, 04:10 PM
  #1083
Total Cats: 1,899
FWIW I was on a MAC valve, we couldn't get the one that came with the EFR to work at all IIRC.
I'm following along closely here. I'm going to tap 18psi when it comes time to get the 4 port valve/2 port actuator working, hopefully with something other than the 1.3.x or 1.4.x I'm running now.
EO2K is offline
Old 08-24-2017, 04:14 PM
  #1084
yes your efr came with a dead valve. and you're on 1.3.x iirc
I have a strange feeling once OP fixes the leaks and re-locates his line it should be ok
tuning 2 other EFR Miata's aside from his right now and no one else seems to have this funkiness
Old 08-24-2017, 05:38 PM
  #1085
Total Cats: 1,899
Humm... I need to dig back through my pics and see if I can figure out what I was using for a source.
EO2K is offline
Old 08-27-2017, 02:19 PM
  #1086
So... The plenum was siliconed gross. Probably when the shop sent the injectors out for cleaning. Stuffed the runners and cleaned the surfaces and laid out a new gasket. Thank God I have so many spares.
Mounted the MAP sensor to the firewall and tee's off the back port per Mt.Net SOP.
The busted *** fpr hose was too tight of a fit to use the same reference so I ran a skinnywinny hose to the top mini port of the intake manifold behind the throttle body
So far, log looks a lot better and seems to have cured the oscillation. From a 4th-5th-6th pull, things looked great but there was a surprising rpm blip which freaked me out so I shut down. In the forthcoming log, it'll be apparent in the end.
Thanks Miataturbo!
Will post up soon, but for now some hipster ****:
edit: log attached
File Type: msl
Old 08-27-2017, 05:25 PM
  #1087
don't want to speak too soon, but the boost oscillation definitely looks to be cured
and that ramen looks tasty
Revision sent, with notes/comments.
Old 08-27-2017, 08:11 PM
  #1088
miataman04's Avatar
*Fingers crossed*
I'd make fun of you for posting your dinner, but man that looks tasty.
miataman04 is offline
Old 08-27-2017, 08:24 PM
  #1089
its hard to diagnose boost leak with a powerful/capable turbo and speed density, because often those two things will just mask the leak. on mass airflow cars, a leak like that would cause the car to flip out entirely
that, sir, is called overboost protection/boost cut
as I explained in the email, looks like the car's making more boost now that you fixed a leak
Old 08-27-2017, 10:54 PM
  #1090
bloop
File Type: msl
File Type: msl
Old 08-27-2017, 11:44 PM
  #1091
yup, no more oscillation
Old 08-28-2017, 12:02 AM
  #1092
Yay boost cut!
Old 08-28-2017, 12:05 AM
  #1093
raise it from 260 to 280 and call it a day. or we can bump down the boost duty. your call
on e85 is where we'll shoot for the stars
Old 08-31-2017, 09:08 AM
  #1094
Raised the boost cut and now it's pretty cozy. Feels great.
I've been sick the past two days. In that time, I got my car inspected yesterday, had to fix my horn on the spot which I totally forgot about. I'm not sure why I didn't take the 10 minutes to do this before. Among other 'interestingly missing' equipment, I passed.
Picked up 12 gallons of e85 to help flush and change over whenever that time comes.
Today I'm off to Seattle for the Labor Day weekend before I head out again for 2-3 weeks later in September.
Future projects:
Oil cooler hoses (why did I wait so long?)
Revisit oil drain scheme (Thanks Aidan)
Flanges for brake ducts
Weld on that 4th hanger Shuiend gave me a year ago
New catch can setup (Vibrant 2 port happy face can)
Fix A/C (will need new condenser)
Radiator ducting
Splitter (kmo25 ?)
MAC EBC/2 port Wastegate?
Old 08-31-2017, 01:35 PM
  #1095
Total Cats: 1,899
This makes me feel like I might have had a leak somewhere...
EO2K is offline
Old 08-31-2017, 01:51 PM
  #1096
Definitely check. I'm surprised the VE table didn't need any other adjusting with how jank the FPR hose was. (Or maybe it did as Vlad was mentioning it was a little too lean up top)
Old 08-31-2017, 01:52 PM
  #1097
Umm, yes I actually did add fuel to your VE table. As well as enabled CL fueling in boost which now makes adjustments here and there to keep it safe.
Old 08-31-2017, 06:06 PM
  #1098
That was before the vacuum fixes right? Either way, I am hoping it's on to see some happier days soon
Old 08-31-2017, 06:38 PM
  #1099
It was after You went almost a full point leaner in AFR with the fix.
Which means you're flowing more air. which means you're making more power. which is expected after you fix a leak. which is good
Old 09-01-2017, 12:38 AM
  #1100
kmo25's Avatar
Total Cats: 41
I might be able to help you with more than a splitter. I have an A/C condenser from a 99 sitting in my garage right now.
kmo25 is offline
Quick Reply: Turbo Smurfette - Build in progress (slow)
