Brain MS3X Idle 'Issues' (Idles at 3k)
#185
Total Cats: 4,080
there's a lot less timing on my NB map in low loads than my NA map (first knock complaint ive heard in hundreds of installs)
the NA map I load is what I actually ran on my car for years.
the NB map is based of Y8s map, which is based of the Hydra map.
Listened to both on a few setups using detcans, never knock.
I just don't see you really knocking with this map...
#186
Total Cats: 74
You're running about 3º more (~33º) than I do (~30º) at 5500rpm and 99kpa. My tune is fairly conservative too. Brains standard NA map also runs a little less timing at 5500rpm and 99kpa when compared to his NB map. I really, really doubt you're knocking there, but if you want to be absolutely sure, just reduce timing by 3º, as Aidan already suggested, and run it again.
#187
I'm not certain I'm knocking, but I have that 25% spike in all the logs I've looked at where I'm in WOT. My fueling there isn't the best, but it's been getting better. I'm just trying to figure out what's going on and if this is something to worry about.
Stefanst, I'll try that next time I'm in the car and see what happens during a WOT pull.
#188
Total Cats: 4,080
your knock threshold is 60% btw, you're seeing about 25% on some noise spikes. I dont think you're close to the % needed to think that youre close to knock. and those numbers are typical from what ive seen on logs.
looking at, i would say that map is actually a little aggressive for n/a. I'd prefer the 110 row to be the 99 row.
what i dont understand is your AFR in your logs as you approach redline... at 6800 on every log, your AFR goes full lean -- despite having same pw and spark advance. that is your soft limiter number, but im not seeing in the logs the timing or fuel being pulled.
#191
Brain, the rev limit is set at 7200 with a 400 rpm hysteresis. So it's 'soft' cutting as far as I know. It definitely doesn't feel like railing into the limiter with the stop ecu.
The image you posted also captures the 'knock spike'.
#192
Total Cats: 4,080
yeha i know it starts to cut fuel to each clyinder until you hit the redline, im just surpised it didnt show up in the logs...
still, i dont think youre seeing knock. you see 25% "knock" on decel with no load.
#193
Total Cats: 74
It's the progressive fuel-cut feature if I understand it properly. It starts cutting of fueling events as soon as you hit the soft-land limit. So PW is unaffected, spark is fine, but we're still getting air int he exhaust.
#195
Also, that means that any 'real' knock I'll see will be closer to or past the 60% threshold, correct?
#196
Total Cats: 4,080
when you add boost your youll see a rise in the noise. when you get real knock, youll see it spike up pretty significantly. you want the threshold to be high enough it filters out noise, but low enough it'll catch real knock.
#198
Total Cats: 857
Were these developed for 93 Octane fueling?
Why the step at 35kPa and 4800 RPM?
#199
I think he does the step at 35 and 4800 since those are usually low load states that you'll see during vacuum when you let off the gas. You're going to be there for less than a split second if you're giving it any gas at that point and you'd jump way up in load right away.
#200
Update!
Got my car running on the mustang injectors with the FF kit. Things run pretty well!
Except at idle...
It idles totally fine off the bat, but tries to die at every stop light. At times at start up, it'll settle into an rpm, then jump up and come back down again with no throttle input.
The good log I have was too big, but this log is similar. It leans out around value 350 and tries to stall. I've tried adding more fuel to the VE cells in the lower ranges, but it didn't seem to help things much. I'm going to try adding even more tomorrow. Any advice would be much appreciated.
Re: installing injectors
I changed the dead time to 1.1 and scaled reqfuel by using 630 for the new injector size. I want to set a new dead time curve, but the values on the force flow site are in absolute numbers and TS is in percents. Does one just covert and go from there?
And brain. still haven't figured out the noise. Its been happening intermittently now. I keep forgetting to change the idle valve setting.
Except at idle...
