HornetBall's Build #2: Meet Red
Old May 12, 2014 | 01:25 AM
  #161
TheProfessor's Avatar
Interesting trick with the RTV/fiberglass mix. Any reason you didn't go use fiberglass in the "traditional" manner with epoxy or polyester resin?
Old May 12, 2014 | 08:51 AM
  #162
hornetball's Avatar
Total Cats: 697
LOL. Time to 'fess up.
I had a fiberglass kit that had been sitting on the shelf for a while. When I opened it, the hardener had evaporated. I also had a several-years-old, mostly used up tube of red RTV on hand. Then I remembered the fiberglass/RTV trick (another aviation thing -- you can make cowl seals this way) and decided to skip the trip to the store and use up my old junk.
I think the RTV actually works better than epoxy in this application. The RTV is sticky and helps the fiberglass mold to shapes better. RTV doesn't run and cures faster. I also control when it starts curing by when I pull off the plastic wrap. If I change my mind at some point down the road, I can pull the fiberglass/RTV off the spoiler and it will all clean up.
Another tool for the toolbox.
Old May 12, 2014 | 10:29 AM
  #163
Total Cats: 1,410
That's pretty cool. Plus I have all the tools and supplies in the garage to do it myself.
I'd be interested to see how it holds up on track.
Old May 12, 2014 | 10:57 AM
  #164
hornetball's Avatar
Total Cats: 697
I don't "expect" any issues (famous last words!). In the aviation world, I've seen this used for cowl seals and inter-cylinder baffling. Both applications are similar to what we are doing here. Airplanes are going faster and generating higher pressures than what we'll see with our cars -- although there are fewer rubber marbles at 10,000 feet. I'll report any issues if they crop up.
Old May 12, 2014 | 11:37 AM
  #165
byunique's Avatar
Originally Posted by kenzo42
Looks great.
Why ABS and not aluminum for radiator cover? Can ABS handle the heat?
FYI, ABS Maximum Temperature: 176°F 80°C
re: Acrylonitrile Butadiene Styrene Properties | Technical Information (ABS)
Old May 12, 2014 | 11:58 AM
  #166
For sure! I'll have to remember this one. I'm sure the application will come up that it will be appropriate for one of these days.
Old May 12, 2014 | 12:06 PM
  #167
hornetball's Avatar
Total Cats: 697
Originally Posted by byunique
Ooooh. Good catch! (This, boys and girls, is why you should have a build thread). I wonder where I got that 350F number? OOMA?
More info: Thermoplastics - Physical Properties.
So, I would say ABS is marginal for that cover. I'll keep an eye on it. Jeffbucc, if you're reading this, the material on your air box (even with the reflective stuff) should be changed, STAT!
I'm guessing the OEM radiator material is PVDF?
Old May 12, 2014 | 12:08 PM
  #168
I don't know that I would worry about it. Worst case scenario, it deforms slightly. You're not going to go anywhere near a flashpoint in an airbox or ducting setup so run it and see how it holds.
Old May 12, 2014 | 12:13 PM
  #169
hornetball's Avatar
Total Cats: 697
Found the source of my confusion. I was looking at the MELTING temperature, not the working temperature.
Melt Temps
Digging in a bit more, it seems thermoplastics have a glass temperature where their stiffness plateaus until reaching the real melting temperature (called the rubber plateau because the thermoplastic feels rubbery in this temperature range).
For ABS, the glass temperature (Tg) is ~220°F. The melting temperature (Tm) is much higher, up in the 400's °F.
Thought this was cool. I never studied plastics back in the day.
Now, back to your regularly scheduled programming.
Attached Thumbnails HornetBall's Build #2:  Meet Red-400px-rubber_plateau_svg.png
Old May 12, 2014 | 10:46 PM
  #170
hornetball's Avatar
Total Cats: 697
Default Seatback Braces
Built the seat back braces.
Started with the part that bolts to the seat. 3x11 (33 square inches) bent to fit the seatback. Note the location, you want them below the harness holes (the harness holes introduce a weak point). As with the seat brackets, these mounting bolts will get welded to the brace.
Next was to mockup the passenger's side. This was the easy side because the seat has a fixed position. Ended up connecting to a diagonal.
Mockup of the driver's side. This one needs a long mounting arm that is parallel to the seat brackets to accomadate the adjustable positions. The parallel arm connects to the harness bar that I added.
Comparison shot before welding.
Finished passenger's brace with u-bolt holes drilled and ready to go.
Finished driver's brace with multiple holes to accomodate seat adjustment drilled. You can tell where the welder ran out of wire and I had to change spools. Oh well, cover it up with black paint.
Installed driver's brace. The added harness bar worked out well for getting things centered and for getting the seat back brace into the desired position on the seat without resorting to crazy angles. This is the rearmost seating position.
Installed passenger's brace.
Used socket screws located under the padding for comfort. 3 per seat.
Seats are solid. They feel like structure now.
Attached Thumbnails HornetBall's Build #2:  Meet Red-img_0255.jpg   HornetBall's Build #2:  Meet Red-img_0257.jpg   HornetBall's Build #2:  Meet Red-img_0259.jpg   HornetBall's Build #2:  Meet Red-img_0260.jpg   HornetBall's Build #2:  Meet Red-img_0262.jpg
HornetBall's Build #2:  Meet Red-img_0263.jpg   HornetBall's Build #2:  Meet Red-img_0264.jpg   HornetBall's Build #2:  Meet Red-img_0265.jpg   HornetBall's Build #2:  Meet Red-img_0266.jpg   HornetBall's Build #2:  Meet Red-img_0267.jpg
Old May 13, 2014 | 10:28 AM
  #171
ScottyP3821's Avatar
Total Cats: 50
Did you choose to mount it on the harness bar so you wouldnt have a longer piece of metal more prone to flexing?
Old May 13, 2014 | 10:33 AM
  #172
Jeffbucc's Avatar
Total Cats: 951
So, I would say ABS is marginal for that cover. I'll keep an eye on it. Jeffbucc, if you're reading this, the material on your air box.
It has 2,000 degree wrap on it, I think I'm safe from it deforming!
Good progress and I really like the bracing for the seats!
Old May 13, 2014 | 10:37 AM
  #173
hornetball's Avatar
Total Cats: 697
Yes. And it also kept the angle more level. Honestly, that cold-rolled C-channel isn't prone to flexing, it's like an I-beam. Much better than flat stock. And you'll note that I gussetted the bend.
As for why I added the harness bar:
1. See earlier pictures that showed the harness/seatback brace centering issue using the roll cage seatback bar.
2. I'm using a HANS device. Normally, shoulder harnesses are OK if they are +/-20 degrees from level with your shoulders. However, with a HANS you want to bias that towards 0 to -20 degrees. Harness bar being lower took care of both the centering issue and lowering the harness.
3. Lower position also helps deconflict the seatback brace from the harnesses (avoids chaffing).
4. On the passenger side, the harness bar gives room to get the buckles away from the seat.
Anyway, car has plenty of side bracing now. LOL.
Old May 13, 2014 | 10:41 AM
  #174
hornetball's Avatar
Total Cats: 697
Time will tell. That 2000 degree rating just means that the wrap itself won't degrade when exposed to 2000 degree heat sources. It doesn't mean that it will drop 2000 degrees on one side to less than 200 degrees on the other.
Just keep an eye on it please. We all love your car!
Old May 13, 2014 | 10:49 AM
  #175
Jeffbucc's Avatar
Total Cats: 951
True, if it deforms I know who to call to make one for me! I think I'm safe from my car burning down till I have time to mess with the tuning and fix the idle issues.
I just wish you weren't all the way down in Texas so I could get a ride in this beast on the track once its done.
Old May 13, 2014 | 03:43 PM
  #176
hornetball's Avatar
Total Cats: 697
If you go to that Miata meet in CA, maybe you can snag a ride in Emilio's 95R. Should be similar.
SLC to DFW. How hard can it be? I'm sure your small business runs itself, right?
Old May 13, 2014 | 07:36 PM
  #177
Jeffbucc's Avatar
Total Cats: 951
I'll have to take Emilio up on that one of these days.
It is about 18 hours from Cedar City. Sometimes the bakery is autonomous, sometimes it needs my constant presence to bitch slap employees. Depends on the season...
Old May 14, 2014 | 10:22 AM
  #178
hornetball's Avatar
Total Cats: 697
IN for vid.
Old May 14, 2014 | 12:20 PM
  #179
Jeffbucc's Avatar
Total Cats: 951
IN for vid.
I need my plausible deniability...
Old May 14, 2014 | 02:03 PM
  #180
turbofan's Avatar
Total Cats: 1,091
Did you ever sign up for a track spot at Miatas at MRLS? You better be there, I MUST see this car in person.
Ed@949Racing/Supermiata
www.949racing.com
