GT2554R Record??? leads to a run of the mill EFR build
Old Feb 23, 2016 | 10:16 AM
1993z32's Avatar
TheCarPassionChannel
Total Cats: 138
Default GT2554R Record??? leads to a run of the mill EFR build
Hey again everyone, back again with another dyno. So from the very beginning of my build all I wanted was the fattest torque curve possible on a stock motor, so naturally I started with a 1.6 (Just kidding don't Alt+F4 yet). I actually never intended on boosting this car but then I did so... here I am. As much as I loved my Begi churbo, the 135wtq @ 3500 wasn't fun anymore. So I went to a GT2554R. Then E85, LS coils, full 2.5" catless turbo-back, etc. Made 254/231 and 205wtq @ 3500. Then I threw a billet compressor wheel at it because I wanted more, and after the motor had already held up for 30,000+ miles of daily driving and autocross/drag events every 1-2 months, I figured it was healthy. Back on the same dyno in the same 90 degree temps, a little more boost and timing later, and the car is more alive than ever. I will have a full review/analysis/weights/measures video of the billet wheel vs. the stock wheel on my YouTube channel in a few days. Okokok, here it is:
Stuff that matters:
"GTX"2554R 13psi, taper to 15.5psi from 5000-7000 (on purpose)
Begi Cast Manifold
E85
LS2 Truck Coils
7lb Flywheel
MS2PnP
2.5" IC + Piping
Five-0 750cc Injectors (Run Sequentially)
Five-0 340lph Pump
2.5" Catless Turbo Back, DynoMax Race Bullet
5-Speed (4th gear pull)
3.9 Torsen
210K Mile 1.6L, Stock from the valve cover to the oil pan internally
ATI Super Damper
Tuning insight & oversight from the local turbo Miata master Toby @ Advanced Engine Dynamix
Things that make me love this car:
150wtq @ 2750
200wtq @ 3400
200wtq @ 6900
Everything in between.
Attached Thumbnails GT2554R Record??? leads to a run of the mill EFR build-94e5ofb.jpg
Old Feb 23, 2016 | 10:19 AM
Pretty cool, never seen a 2554 upgraded like that. solid setup overall, but you're definitely not touching a 1.8 torque curve
what are the measurements of the cast wheel vs gtx wheel?
creep by default isn't "on purpose" you probably mean taper.
and please post up your trap speeds from the 1/4 mile so we can tell you if that 276 is legit.
either way though congrats on a solid setup
Old Feb 23, 2016 | 10:20 AM
Total Cats: 4,370
My 1.6L $150 T3 had a better tq curve*. and i didnt have all the extra silly fueling mods to support 500hp with a 250rwhp turbo.
thanks for playing.
you lose.
but seriously, all that silly fueling, and good parts, and youre still running a 2.5" exhaust...
*it was actually pretty similar, still just about as good as a 1.8L spooling a GT2871R
Old Feb 23, 2016 | 10:21 AM
Girz0r's Avatar
Total Cats: 323
You should post here moar often.
Plot looks awsome, I bet it's a very fun vehicle.
What kind of exhaust manifold are you using?
Old Feb 23, 2016 | 10:25 AM
cyotani's Avatar
Total Cats: 117
Nice numbers. I wonder what a 3" exhaust upgrade would do for you.
Old Feb 23, 2016 | 10:37 AM
pdexta's Avatar
Total Cats: 184
276/241 seems pretty crazy on a stock 1.6 with 2554, congrats.
Old Feb 23, 2016 | 10:42 AM
1993z32's Avatar
Total Cats: 138
My 1.6L $150 T3 had a better tq curve. and i didnt have all the extra silly fueling mods to support 500hp with a 250rwhp turbo.
thanks for playing.
you lose.
Would like to compare dyno's if you still have yours available, just out of curiosity.
Begi Cast
Sorry, fixed the terminology, haha. The core of the wheel is much more slim so the blades measure longer. (13.2mm "primary" blades, 11.2mm (secondary" blades vs 14.8mm "primary" and "secondary" on the billet.) The billet wheel is also 34g compared to 44g so I'm sure that helps with response. I mostly made the 1.8 comment to bring in all the 1.8-heads to prove me wrong, and I couldn't find a dyno on here of a stock 1.8 that looked any better than mine. No doubt they have more potential. I haven't run it yet since I only did this Saturday, but I ran 87.54mph in the 1/8 when I was at 254whp, I want to run her again soon and will post up.
Me too. Not that I want to make a drop more than 240wtq, but maybe a little extra up top? I still think this turbo is so close to being out of air that it wouldn't help much, but who knows, maybe I'll find out. My 2.5" exhaust is straight back from the downpipe all the way out, no silly double 90 degree bends like factory.
Old Feb 23, 2016 | 10:47 AM
JasonC SBB's Avatar
Total Cats: 84
240 torqz at 13 psi on a 1.6 = 80 ft-lbs/atmo/L
I call bullz. Dyno calibration is off.
Old Feb 23, 2016 | 10:50 AM
1993z32's Avatar
Total Cats: 138
It made the 240 @ 14-15psi and corn timing, still not believable? Serious question
Old Feb 23, 2016 | 10:53 AM
Begi Cast
there are a bunch of 2560's, ill dig up some 2554's later if I'm bored
but to start,
1/4 trap speed will tell the story
You can only advance spark so much on a tiny turbo that supposedly chokes after 5500rpm
Attached Thumbnails GT2554R Record??? leads to a run of the mill EFR build-torque_rape.png
Old Feb 23, 2016 | 10:57 AM
but to start,
I just want to point out that my torque in that dyno was done on a MS1, a stock exhaust, MBC, and I have not clue what the boost level was. It was from the first time I ever had the car on a dyno with next to no tuning. So it definitely is not the best showing of what the turbo can do on a 1.8.
1993z32's Avatar
Total Cats: 138
but to start,
Oooh I like the pretty blue one. Red... 280+wtq on a stock block?
Girz0r's Avatar
Total Cats: 323
BEGi Cast
I think a vband ARTech + EWG + 3" dp & full exhaust is in your future.
You'll know then for sure if your turbo is running out of puff
Here, have a dounut
Old Feb 23, 2016 | 10:59 AM
Blue one might have been a 2560. The red one I believe was a stock motor. There have been a few people who have ran more then 250ft/lbs on stock motors, I think a lot of it is luck.
Old Feb 23, 2016 | 11:02 AM
Jason should chime in w/ his dyno plot since he ran a 2554 on his 99 iirc
cant find it now, but most 1.8's with 2554 make 200 at or before 3k
Old Feb 23, 2016 | 11:03 AM
1993z32's Avatar
Total Cats: 138
It has to be, right? I mean I even think my motor running so good for so long is a little luck as well, considering people have lost motors at lower levels with supposed "good tunes." At any rate, that makes me feel better, haha.
Old Feb 23, 2016 | 11:13 AM
the tuning is not the issue on most of these cars. it's not like we have ringland or weak poston problems. we have rod problems. this is from making too much torque, or cylinder pressure, depending on how you look at it.
the higher up you make your torque and the more mechanical empathy you have the longer it usually lasts.
there's a local making 350 on his Miata for a while. stock bp. it was a giant snail that made power/torque in the last 1500rpm of the powerband
Old Feb 23, 2016 | 11:20 AM
1993z32's Avatar
Total Cats: 138
Which is exactly why I added the boost taper and some extra timing up top, I want to stay at 240wtq, but would love to make more horsepower up top as long as I can stay under that. I'm thinking of swapping to a 60R cold side to help accomplish it.
Old Feb 23, 2016 | 11:25 AM
In my opinion you need to upsize the turbine/hotside/exhaust to keep gaining power the correct way. Upsizing the cold side cover will likely not gain anything at this point.
I'd start with exhaust
Old Feb 23, 2016 | 11:33 AM
JasonC SBB's Avatar
Total Cats: 84
15 psi -> 75 ft-lbs/atmo/L still too high. Highest numbers I've seen are closer to 70.
