Astroboy's reliability build (pic intensive)
Old Oct 21, 2011 | 09:55 AM
  #181
Sean's Avatar
I need to make one of these cowl covers and delete my wipers that would solve a whole lot of problems. I like the look a lot this thing looks sweet.
Old Oct 21, 2011 | 10:34 AM
  #182
astroboy's Avatar
I took those two pics of the cowl cover for you, pretty much I just winged it. The wipers will be going back on but the plastic piece needs some more work before I put the wipers back on.
Old Nov 8, 2011 | 02:46 PM
  #183
astroboy's Avatar
Soooooo about two weeks ago we started to tune her, found there's a vacuum leak somewhere and while trying to get the idle down blew the freeze plug out of the front of the head (only moments after Dave walked away from the front of the car and I questioned if we should shut it down). The timing of this event was quite epic.
Then I installed the side splitters, they are quite ****. I was suprised to see they came out and din't look stupid with the rb rear flares (I was expecting to have to modify them to make them flow with the rest of the car)
Shameless plug:
Also I am in the calendar for 2012 so vote for this guy! http://www.r2-limited.com/blog/?page_id=406
Attached Thumbnails Astroboy's reliability build (pic intensive)-386848_258981644149182_100001120466954_735511_987687140_n.jpg   Astroboy's reliability build (pic intensive)-374075_258981524149194_100001120466954_735510_414251063_n.jpg   Astroboy's reliability build (pic intensive)-6324607034_173d37caa1_b.jpg
Old Nov 8, 2011 | 06:41 PM
  #184
Bond's Avatar
Last picture looks like you are 10' tall, lol.
How do you blow out a freeze plug?
Old Nov 8, 2011 | 08:09 PM
  #185
astroboy's Avatar
I used the step ladder technique to get maximum vertical reach.
The freeze plug wasn't in quite perfect and what ended up happening is as the temps went up the pressure also did. The freeze plug was the weak point so it blasted out when the temp got too high.
Old Nov 8, 2011 | 08:19 PM
  #186
240_to_miata's Avatar
Total Cats: 16
LOL at the epic freeze plug. We could have been hurt pretty bad, so id say timing was epic too.
You fix the **** yet? We cant do any more tuning till you get that done. Sry I didnt call you back. I forgot :(
Old Nov 8, 2011 | 08:29 PM
  #187
astroboy's Avatar
Nope, haven't gotten it done. Work has been pretty nuts along with shoots so I haven't had a chance. Also my Sentra needed a new wheel bearing, ball joint, axle, and all the seals. The water pump needs to be replaced so it is next on the chopping block along with timing chain guides, oil pump, and tensioners.
Old Nov 8, 2011 | 11:54 PM
  #188
soviet's Avatar
Total Cats: 269
Can you elaborate? I'm planing on installing a freeze plug for my reroute and I don't want my car spontaneously ejaculating coolant.
Old Nov 9, 2011 | 12:15 AM
  #189
astroboy's Avatar
Yeah, if you don't drive it in perfectly flush with respect to the face of the head (where your driving the freeze plug into) it will weep and eventually, as I found out, blast out of the head like a steam line rupture.
Old Nov 9, 2011 | 06:19 AM
  #190
Total Cats: 16
For the record, his temps just hit about 215*F... so nothing crazy
Old Nov 18, 2011 | 08:54 PM
  #191
astroboy's Avatar
Just finished taking apart my diverter to find the cause of the pressure leak . I was fully expecting to find a ripped diaphragm but actually what happened (no idea how though) is one side of it got pushed down and was allowing air to get by. Set it straight and reassembled it...going to give it a go tomorrow to see if it still leaks. Next I need to figure out what is going on with the idle adjustment screw on the throttle body. Then throw the coolant blockoff plate on (just need to punch holes in it for mounting purposes), refill the system, and try try again.
Attached Thumbnails Astroboy's reliability build (pic intensive)-6360732279_2e73dd0765_b.jpg
Old Nov 19, 2011 | 08:44 AM
  #192
Total Cats: 16
What did you make for a plate? How thick?
Old Nov 19, 2011 | 09:39 AM
  #193
TheDriver's Avatar
Total Cats: -14
Sorry I didnt bother to read through all this, what are your power level goals? Very sick build BTW!
Old Nov 19, 2011 | 09:45 AM
  #194
Total Cats: 4,370
Sorry i didn't bother reading, are you a ******?
Old Nov 19, 2011 | 09:59 AM
  #195
TheDriver's Avatar
Total Cats: -14
Sure, I love stars and would like to think I am one sometimes But seriously, just saw the early build and didnt think it would hurt to ask. Sorry to get you started off on the wrong foot this morning
Old Nov 19, 2011 | 11:15 AM
  #196
Total Cats: 1,411
Oh good, so you got this? Great, I'm off to bed then.
Old Nov 19, 2011 | 11:21 AM
  #197
astroboy's Avatar
1/4" thick aluminum (should expand at about the same rate as the head). I am contemplating buying some hex head fasteners and countersinking the holes so the mount flush but part of me says that will introduce a couple failure points that I don't want in my life.
That's fine. My goal is a reliable 300whp car that I don't have to put a ton of boost into to achieve said power goal. If this setup doesn't get me close a little bw efr should get me the rest of the way there.
Sometimes people think I when I talk about this car
Old Nov 19, 2011 | 11:22 AM
  #198
God damn you turned around that car.
Old Nov 19, 2011 | 11:27 AM
  #199
TheDriver's Avatar
Total Cats: -14
I'm starting a build as well, I dont know much about Borg Warner's turbos but I've heard a lot of good things, hope to get to/be at your level this time next year.
Old Nov 19, 2011 | 05:01 PM
  #200
astroboy's Avatar
Thanks man.
EFR's are good things to have in your life. Hopefuly your build will be running this time next year
The diverter still leaks by :( I'll have to take it apart again to see if I can pinpoint the source of the leak again.
