Leatherface is back. hide yo keez hide yo wife
Old Mar 16, 2011 | 09:10 AM
  #1001
RotorNutFD3S's Avatar
Total Cats: 36
Sounds like a rematch with a certain Z06 is in order now...
Old Mar 16, 2011 | 09:42 AM
  #1002
leatherface24's Avatar
Total Cats: 10
That is a definite. I all I need is my meth to take me safely to 30psi. And I desperately need new tires also.
Old Mar 16, 2011 | 10:17 AM
  #1003
sixshooter's Avatar
Moderator
Total Cats: 3,588
Originally Posted by 18psi
So wait, you threw in the new motor and ran 30psi on it on the 1st day? holy **** lol
That's how he drives - flat out...
All of it:
Old Mar 16, 2011 | 10:20 AM
  #1004
shlammed's Avatar
Total Cats: 51
when you add meth, you need to add fuel. your AFR will drop from simply adding a meth kit.
from what i read you already maxed those systems out... so you need meth, and a fuel system.
Old Mar 16, 2011 | 10:52 AM
  #1005
Total Cats: 10
All of it:
Thats not all of it....
Old Mar 16, 2011 | 10:59 AM
  #1006
Total Cats: 10
Going with two fuel pumps, a surge tank, FPR and a return setup for fuel. After doing the math on RC's website, I know my injectors are plenty good for 400rwhp.
Thats more like it
Old Mar 16, 2011 | 11:04 AM
  #1007
That is strictly badass
Old Mar 16, 2011 | 11:12 AM
  #1008
shlammed's Avatar
Total Cats: 51
im not saying that you need the WHOLE system by any means... but its something you need to address.
From my research the meth will raise AFR so i was letting you know so you dont go blind into it and blow **** up on the first pull.
apparently the AFR typically raises ~1 point with 75% meth/25% water mix and a properly sized nozzle.
  #1009
Total Cats: 10
im also getting turbo surge now past 27 psi in 6th gear. Any help on how to get rid of this without buying another compressor housing
Old Mar 16, 2011 | 11:14 AM
  #1010
shlammed's Avatar
Total Cats: 51
dont do 6th gear pulls.
Old Mar 16, 2011 | 11:15 AM
  #1011
Total Cats: 10
Fuuucckkk that
Old Mar 16, 2011 | 11:00 PM
  #1012
pusha's Avatar
Total Cats: -29
That car is getting some head and a pretty decent shot soon. Jared needs to step it up.
Please, you know that when I stop being lazy and get DRs, install my nitrous kit and FINALLY order heads, that I'll smoke that piece of **** all day.
Old Mar 16, 2011 | 11:01 PM
  #1013
pusha's Avatar
Total Cats: -29
Originally Posted by revlimiter
Shockwave approves.
I stopped playing with toys when I was 10. I play with **** now. You know, like "bags of sand."
Old Mar 17, 2011 | 12:38 AM
  #1014
so much sexual tension between the two of you
Old Mar 17, 2011 | 09:18 AM
  #1015
Sean's Avatar
Be careful with the RC injectors they are great but if you are planing on running a higher base pressure to compensate they will not flow anymore past 60psi no matter how much rail pressure you have. We just ran into this problem on a set of 750cc in a friends car. We called RC and they confirmed. Not sure exactly what your plan was just a heads up.
Old Mar 17, 2011 | 10:26 AM
  #1016
Oscar's Avatar
Total Cats: 120
Originally Posted by Pusha
I stopped playing with toys when I was 10. I play with my mantits now. You know, like "bags of sand."
OK
Old Mar 17, 2011 | 10:49 AM
  #1017
Total Cats: 10
Quit playing with old lady ****
SO today I logged some detonation on the Hydra peaking at 1.45 and I realized that I am running the MSM pistons which are higher comp ratio then the 94s i had in before which blows. I need to lower the boost, and desperately get the meth going. In the meantime I am going to dump a gallon of toluene in the tank and see if that helps a bit.
Old Mar 17, 2011 | 10:50 AM
  #1018
Total Cats: 10
Thanks for the heads up although Im not using RC injectors but I will be on the look out if I encounter any problems.
Old Mar 17, 2011 | 11:01 AM
  #1019
so you went from 9.1 to 9.5? this explains you holding boost better on the new setup (among other reasons)
Old Mar 17, 2011 | 11:04 AM
  #1020
buffon01's Avatar
Total Cats: 13
Hey ask Tyson if you can borrow his camera. We could mount it on my bike and have good footage.
