Blaen's because 350hp build
Old Apr 12, 2013 | 08:42 PM
  #181
blaen99's Avatar
Remember that at sea level, 100 kpa is the base pressure of the atmosphere.
I'm at like...95 kpa where I live at normal pressure, so it puts 165kpa right at 10ish psi.
Old Apr 12, 2013 | 09:00 PM
  #182
Chiburbian's Avatar
Total Cats: 204
I see this in the Dy'no pages: https://www.miataturbo.net/dynos-tim...-10-psi-23838/
Does this mean that the 4828 compares favorably to a 2860 on a 1.8 S4?
Old Apr 12, 2013 | 11:14 PM
  #183
TurboTim's Avatar
Total Cats: 425
Supposedly mustang dynos read differently than a dynojet.
240rwhp dynojet at 10 psi on a 1.6 with a quickie tune is great. Congrats! Good to see an actual dyno of a precision turbo on our engines.
Old Apr 13, 2013 | 12:41 AM
  #184
RussellT94's Avatar
Total Cats: 24
I think he's done a 1.8 swap. I didn't read through the entire thread, but I thought I saw mentions of 1.8 swap while skimming.
Old Apr 13, 2013 | 12:45 AM
  #185
blaen99's Avatar
Yep, (edit) 94 (/edit) 1.8 swap. All the mods are listed in the thread. I /really/ need to convert over to EBC, it would help everything down low a crap-ton due to my headaches with the stock wastegate.
Old Apr 13, 2013 | 09:19 AM
  #186
not bad at all, now tune it to run 13psi between 3-5K, and keep the same boost level at whatever it's doing above that.
yeah, no 1.6L is going to do that...
Old Apr 15, 2013 | 08:58 AM
  #187
Scrappy Jack's Avatar
Total Cats: 179
Nice start, Blaen.
Old May 9, 2013 | 08:38 PM
  #188
Chiburbian's Avatar
Total Cats: 204
Any updates or news? Have you put many more miles on it?
Old May 9, 2013 | 08:45 PM
  #189
blaen99's Avatar
Everything's working perfect car-wise so far, so nothing to really report.
I'm going to throw in an OBX LSD in the next couple weeks? I've got a (hopefully) dem768 intercooler incoming + already have FM piping waiting for it, and I've got a new fleaBay radiator waiting to go in. TSE studs + inconel bolts are waiting to go in the turbo when I do the LSD swap, and I've got a timing belt kit waiting to go on.
That's where I am more or less. No hiccups, no weird crap, everything's running damn near perfect with it being a DD.
Old Jul 14, 2013 | 11:36 PM
  #190
blaen99's Avatar
Random update:
eBay rad, dem768 intercooler, FM piping are now in.
Overheated the crap out of the engine due to no ducting. If it turns out to not be okay, I'm going to be getting a VVT engine and doing a franken-94 block VVT everything else monstrosity that's built.
Old Jul 15, 2013 | 07:33 AM
  #191
Random update:
Zimmerman found innocent.
Old Jul 15, 2013 | 09:40 AM
  #192
blaen99's Avatar
Random update:
That's both awesome and stupefying at the same time considering FL precedent, Brainy.
Old Jul 15, 2013 | 11:11 AM
  #193
Chiburbian's Avatar
Total Cats: 204
Random Update: Dewey Defeats Truman!
Oh, wait...
Old Jul 15, 2013 | 03:53 PM
  #194
Total Cats: 179
Random update:
Neg props for trolling a man's build thread with political stuff.
Old Jul 16, 2013 | 07:48 AM
  #195
I hold a grudge and he stopped posting drivel in the TM thread so I couldn't rub the verdict in his face otherwise.
Old Jul 16, 2013 | 12:21 PM
  #196
blaen99's Avatar
Dude, if you hold a grudge against everyone who comes into politics and argues to argue, you must have a looooong list of grudges.
(Including yourself. Lulz.)
But seriously, although I'm not really keeping up with whatever the **** is going on (Beyond being completely mindfucked about the DOJ/Civil charge crap, wtf?), I did post pretty clearly the prosecution had no case for murder. Not surprised broski. The manslaughter did surprise me a bit, but the prosecution in that case needs to be disbarred for both incompetence and outright malicious conduct. The **** they pulled with TM's cell is just...disgusting.
Anyways, enough politics, back to build thread.
Does anyone on here by chance know anything about the 949 Pistons? I'm gonna need new pistons by the end of August it appears, and I'm currently leaning towards FMs 'cause the Supertech cause interference with VVT.
Old Jul 16, 2013 | 04:57 PM
  #197
blaen99's Avatar
Update:
949 pistons are no go for this year. Looks like it's FM or bust here.
Looked at Supertech, interference on a VVT engine is no go.
Old Jul 16, 2013 | 10:40 PM
  #198
Chiburbian's Avatar
Total Cats: 204
What are your operating temperatures? You mention overheating.
I am staying between 195-205 in coolant with the fans running constantly and no A/C (dead relay). IATs for me are hovering around 100 degrees. Mind you, it is a heat wave and in the mid to high 80s in a dark colored car.
Interested to hear what you mean by heat.
Old Jul 17, 2013 | 05:04 PM
  #199
I have heard the "Supertech cause interference with VVT" rumor several times. I also think I have seen JasonCSBB post some math about it. I do not think I have ever seen a yes it is, and it will be a problem. I have ran that combo in a motor for 3 years and never had an issue in that department. I certainly would run the same combo in any other motor I am building for boost on pump gas.
Why do you have the fans constantly running? The fans should theoretically be on only at idle or sitting in stop and go traffic.
Old Jul 17, 2013 | 05:13 PM
  #200
Chiburbian's Avatar
Total Cats: 204
I don't want to clutter his thread I apologize. I will answer this in my thread @
https://www.miataturbo.net/build-thr...l-59485/page8/
