3d printed intake for N/A NA miatas
Old Feb 8, 2015 | 07:48 PM
  #221
asmasm's Avatar
Can someone smarter than me tell me why my napkin math for hz to RPM doesn't match what I find online? I am messing around with Helmholtz resonator dimensions and I am currently converting between RPM and Hz like this:
Hz=RPM/2
-----60
Sources online just use RPM/60 which doesn't take into account that there are two crankshaft rotations for every time the intake valve opens. Also, would halving a doubling the resonance frequency have a significant effect? For example, half of the peaks at 35hz will fall in line with 70hz.
Old Feb 8, 2015 | 09:47 PM
  #222
has to travel the length of the runner twice, the 2s cancel.
Old Feb 9, 2015 | 11:51 AM
  #223
asmasm's Avatar
If anyone is curious, these are the rough numbers for the stock na8 helmholtz resonator:
I measured the chamber volume by how many grams of water it took to fill. For the neck I took dimensions but with all the curves it won't be as accurate.
It looks like they targeted a twice the ideal frequency in order to make the peak wider.
Old Feb 10, 2015 | 12:07 AM
  #224
cordycord's Avatar
Total Cats: 560
Originally Posted by asmasm
Hah. A little of both.
This was my garage when I moved in:
and then I rented a construction dumpster:
Poobs:
I am still making progress on carbon versions but it is very slow. I have an infant and work deadlines taking up the majority of my time.
Send it to me and I'll make a two part mold. Wet layup with the right resin can easily hold up to the heat, and while covering the part with reflective heat barrier may not seem sexy, it will protect the part and keep the intake air cooler.
Old Feb 10, 2015 | 12:28 AM
  #225
triple88a's Avatar
Total Cats: 1,830
I actually do like the little shelves on the right but they should have been in the back where the 2 big doors are at.
Old Feb 10, 2015 | 12:09 PM
  #226
Can we please has NB version nao plz kthx?
Old Feb 10, 2015 | 06:30 PM
  #227
Total Cats: 2,621
Bonus points for quoting the giant pics
.33 SNR
Old Mar 6, 2015 | 05:55 PM
  #228
jdm slick's Avatar
Total Cats: -3
PM'd ya asmasm.
Old Mar 6, 2015 | 08:00 PM
  #229
Caoboy's Avatar
Total Cats: -1
Still waiting for NB plz.
Old Mar 15, 2015 | 09:13 PM
  #230
asmasm's Avatar
I am making big changes to my work schedule, in part so I have more time for this. My composites oven is wired and ready, and I have finally solved the issues I have had with ABS plugs self destructing. I also registered an LLC, and have done a bunch of work to reduce kit costs as far as possible. One example- For people who need an IACV fitting the best option is a silicone intakes port system but it costs $15. I am having a small steel press bender machined so I can make washers with the correct curve:
That will allow me to install a fitting for $3.40 which means kits that kits with an IACV connection will be $11.60 cheaper.
Old Mar 15, 2015 | 11:45 PM
  #231
jdm slick's Avatar
Total Cats: -3
Wow, this is good news! Awesome!
Old Mar 21, 2015 | 07:08 PM
  #232
asmasm's Avatar
Finding 90 degree elbows with a long bend radius is not easy. If anyone knows of a source please let me know. Silicone intakes sent me a perfect elbow about a year ago but they have more the one supplier and half the time you get one that looks like this.
So far I have ordered about a dozen different 2.5" elbows and these are the standouts:
Also, this is finally close to done.
Old Mar 21, 2015 | 07:17 PM
  #233
If you want a long radius use a mental elbow and just a coupler on the end. I needed the tight radius version from silicone intake to clear everything. The SIs people seem really responsive I bet they would send you a long one if they called.
Old Mar 21, 2015 | 09:00 PM
  #234
good2go's Avatar
Total Cats: 1,237
I'm pretty sure these guys can make you whatever you need, but $$.
Turbohoses Custom Design, Engineering & Manufacturing
http://www.turbohoses.com/technical_assistance.htm
Old Mar 22, 2015 | 03:11 PM
  #235
triple88a's Avatar
Total Cats: 1,830
Perhaps one of these?
Silicone 180 Degree U Shape Bending Hose 2 5" Blue | eBay
http://www.ebay.com/itm/VMS-2-5-90-Degree-Silicone-Elbow-Bend-for-Intercooler-Turbo-4-Ply-RED-/121491058529?pt=Motors_Car_Truck_Parts_Accessories &hash=item1c496e6f61&vxp=mtr
http://www.farapp.com/static/prodimg...esinc/3339.gif for the above.
Old Mar 22, 2015 | 03:20 PM
  #236
Can I buy one of these yet?
Old Mar 22, 2015 | 03:23 PM
  #237
OneTwo's Avatar
Total Cats: 36
What he said ^
It has been really cool watching the development process too. Looks like your getting close!
Old Mar 24, 2015 | 12:06 PM
  #238
poobs's Avatar
Total Cats: -6
Thumbs up
Good work man !!!
Old Mar 28, 2015 | 05:23 PM
  #239
wannafbody's Avatar
Total Cats: -369
Why not cut an elbow to the correct length and then 3d print plastic duplicates?
Old May 8, 2015 | 04:46 PM
  #240
asmasm's Avatar
My plug is now at a pro level of finish. Its hard to believe there are glued together peices of ABS that came out of of a consumer grade printer under there.
Mold production is next. I am going to do a split mold and lay up each piece separately with carbon bending slightly around the flange. In order to trim the parts for a clean join line to insert carefully cut steel shim stock between the part and the mold flange an then sand away the excess material. That should give me the correct dimensions to the tolerance of the shim stock thickness and keep me from ruining each mold.
