93' Miata stolen and flipped build thread
Old Mar 31, 2015 | 11:16 PM
  #3641
Jeffbucc's Avatar
Total Cats: 951
I'd do it if I didn't know the cops watch these things like hawks for stupid shenanigans...
Old Mar 31, 2015 | 11:20 PM
  #3642
Total Cats: 1,870
Totally worth it
Old Mar 31, 2015 | 11:34 PM
  #3643
soviet's Avatar
Total Cats: 269
yay efr! vroom vroom. are you using the stock damper? cause it will shear off eventually.
Originally Posted by EO2K
I want to see him use the 4 port valve and 2 port actuator. 12~14psi on a 3lb spring with boost by gear
I have both a 2 port actuator and 4 port valve but haven't had time to do anything. I really want to do 30psi on a 3lb spring.
Old Mar 31, 2015 | 11:47 PM
  #3644
Jeffbucc's Avatar
Total Cats: 951
I'll eventually go with an ATI once my bank account recovers from being raped. Changed the boost lines. T'd off the turbo compressor and lower ewg port and ran the other side of the EBC to the upper. Venting the middle port.
Old Apr 1, 2015 | 12:45 AM
  #3645
Total Cats: 1,924
WAT. What 2 port actuator are you using? This is highly relevant to my interests.
Old Apr 1, 2015 | 12:49 AM
  #3646
Jeffbucc's Avatar
Total Cats: 951
Only 10 psi till my AFR looks better but Jesus it spools fast. Like, no discernable lag
Old Apr 1, 2015 | 12:50 AM
  #3647
Jeffbucc's Avatar
Total Cats: 951
Been a while Mister Double Post.
Old Apr 1, 2015 | 12:53 AM
  #3648
Jeffbucc's Avatar
Total Cats: 951
Sorry about the sound only YouTube videos. I have no wifi in this new house so my phone data would face plant if it had any data on the video besides sound.
Old Apr 1, 2015 | 01:10 AM
  #3649
Mobius's Avatar
Total Cats: 365
Your excuses bore me. I want to see your boost ***** tach needle swinging like I know it does
Old Apr 1, 2015 | 01:28 AM
  #3650
soviet's Avatar
Total Cats: 269
Forge wastegate actuator sold by Full Race. It has two ports, with lower one usually being blocked off. The ports are M6 threads.
I also bought m6 to 3an adapters (like this) but haven't plumbed it fully yet.
Old Apr 1, 2015 | 12:28 PM
  #3651
Jeffbucc's Avatar
Total Cats: 951
And just to make sure my solenoid is plumbed correctly by you guys who sleep and understand this better than I. This is the diagram I used to plumb mine. Better way to do it besides the 4 port method(long term solution)?
Attached Thumbnails 93' Miata stolen and flipped build thread-boost-solenoid-install1290836267.jpg
Old Apr 1, 2015 | 12:32 PM
  #3652
Total Cats: 1,870
Hey jeff can you confirm you only used about 36 inches of braided line for the oil cooler?
Old Apr 1, 2015 | 01:02 PM
  #3653
Jeffbucc's Avatar
Total Cats: 951
Apologies I meant to reply but turbo giddiness. Yes, 36 will be plenty if youount it as I did.
4=90° 10-an fittings
2=22mm x 1.5 male to -10an male adapter
If using Setrab you need the 22mm coupler otherwise you gonna be angry when you go to install it.
As for the sandwich plate, you only need.to cut the length off the threaded pipe if you are only using the sandwich plate. If using the stock cooler as a spacer you shouldn't have issues. My Mocal+stock plate was to thick to have anything left to thread on the oil filter. If you have an angle grinder it takes 5 seconds to zip it off and another minute to grind it flat. Just make sure I'd you cut it that you thread on the but a couple times to clean up the abrupt thread cut. The nuts threads are way stronger than the pipe so it is like using a die to recut the threads.
That make sense? Been a long morning.
Old Apr 1, 2015 | 01:10 PM
  #3654
man oh man am I getting excited about this car.
it is hereby nearing perfection. My only gripe with it before was that the log mani was not on par with the level of the rest of the car, and now you're running big baller stuff.
P-E-R-F-E-C-T-I-O-N
  #3655
Total Cats: 1,870
My oil cooler came with the adapters so I'm set there. The AN 90* fittings are stupid expensive, not happy about that.
I have a 1.6 so no cooler, I have a sandwich plate for gauges, which has its own threaded tube. I'm still a bit confused but I think that after I see the sandwich plate and mock it up it will make more sense.
Old Apr 1, 2015 | 01:21 PM
  #3656
Jeffbucc's Avatar
Total Cats: 951
P-E-R-F-E-C-T-I-O-N
You and me both comrade Vlad. The log manifold was tried and true with the exception of the aids ridden flange(being machined to sell properly).
Is it sad I'm just happy I can't for the life of me thing of anything else I really want to do that aren't errant "that'd be cool but unnecessary" mods? After the tune and some street tires, so I don't prematurely wear out the RC1s, I'm done, I'm finally ******* done. This time I'm not just saying that too. I'm physically and mentally tired of working on this and just want to get in, turn the key, and go ***** out with a smile on my face.
It is honestly much more intimidating thinking about it than just getting your hands dirty and start ripping it apart. Once you get in there you'll realize how easy it is.
You don't have to do this, but I'm really glad I removed the intake.Mani to install it. Would have been a lot more frustrating reaching in from beneath the car than staring at it above your car. That probably took the longest just removing that and reinstalling it.
Old Apr 1, 2015 | 01:22 PM
  #3657
Total Cats: 1,870
Alright, thanks for the info, I'll play with it when I get it. The an connectors is what I'm still on the hunt for. I just can't justify paying that much right now. So I'll be on the lookout for deals until I inevitably say **** it and just buy them new.
Old Apr 1, 2015 | 01:56 PM
  #3658
hornetball's Avatar
Total Cats: 697
So . . . when is your first track day exactly? BWAHAHAHAHAHAHA!!!!!
Old Apr 1, 2015 | 02:02 PM
  #3659
Jeffbucc's Avatar
Total Cats: 951
Fine Print
***with the exception of repairs and maintenance when impacting a tire wall***
Old Apr 1, 2015 | 06:29 PM
  #3660
Jeffbucc's Avatar
Total Cats: 951
Exhaust all finished up. AFRs look good, I know I was in the 20ish psi range but I was concentrating on keeping the car straight. Sound only again till I have a proper network connection. Me Gusta
