99mx5 EFR build
Old Apr 4, 2016 | 11:38 AM
  #661
not until I see dem thangs proven
Old Apr 4, 2016 | 11:42 AM
  #662
Total Cats: 1,870
I don't need to see a cast stainless manifold proven. Still kicking myself for not picking one up during the group buy.
Old Apr 4, 2016 | 11:45 AM
  #663
well that's a real cool story bro.
I do.
because theory and reality often do not go hand in hand.
Old Apr 4, 2016 | 11:47 AM
  #664
Total Cats: 1,870
Not theory. Other platform cast manifolds, stock cast turbo manifolds, FM cast manifolds, etc.
But sure. This specific one hasn't been fully proven.
Old Apr 4, 2016 | 02:12 PM
  #665
99mx5's Avatar
Total Cats: 526
Me loves long tubey manifolds long time. I found this link interesting... Long tube Vs Short tube runner length Turbo Manifolds
I have ordered the TSE studs and a vibrant turbo flange. Ideas on adding extra supports tot he flange are welcome. I am thinking of putting triangular supports that also act at fins on the flange. Similar to the supports that TurboTim added to the wastegate tubes on the Absurdflow manifolds. Aside from cast vs welded, I think the TSE manifold has the longest runners of the cast manifolds for miatas.
Edit: I'll gladly accept one of the TSE manifolds for testing.
Old Apr 4, 2016 | 02:22 PM
  #666
I am now debating sending you out mine. I know I probably won't actually be driving on it for ages.
Old Apr 5, 2016 | 02:25 AM
  #667
99mx5's Avatar
Total Cats: 526
To mount that manifold, I'd need to build a new downpipe and new hot-side intercooler pipe.
Old Apr 5, 2016 | 03:16 AM
  #668
Mobius's Avatar
Total Cats: 365
FOR SCIENCE
Old Apr 5, 2016 | 04:21 PM
  #669
yank's Avatar
Total Cats: 32
I might be able to help with that.. For science purposes.
Old Apr 5, 2016 | 04:22 PM
  #670
Total Cats: 1,870
I'll do it for science too
Old Apr 5, 2016 | 04:23 PM
  #671
yank's Avatar
Total Cats: 32
I do.
Agreed. I've seen plenty cracked cast manifolds in the past.
Old Apr 5, 2016 | 04:29 PM
  #672
Arca_ex's Avatar
Total Cats: 431
I've seen a fair share of both cast and tubular manifolds that have cracked as well.
Old Apr 5, 2016 | 04:44 PM
  #673
99mx5's Avatar
Total Cats: 526
We can both take a crack at it.
Old Apr 5, 2016 | 05:00 PM
  #674
99mx5's Avatar
Total Cats: 526
Props! If given the opportunity, I'll take you up on that. I can also get a dyno to compare setups (ARTech long-tube vs TSE cast) with everything else being the same.
Old Apr 5, 2016 | 05:07 PM
  #675
My cast manifold has already lasted longer than the first iteration of a Sch40 tubular manifold I ran.
Old Apr 5, 2016 | 05:24 PM
  #676
psyber_0ptix's Avatar
I'm very interested in this and was about to pull the trigger on the TSE stuff to replace the perfectly functioning Artech stuff, but couldn't find justification ergo decided to focus on brakes and oil cooler first.
Old Apr 5, 2016 | 05:37 PM
  #677
thumpetto007's Avatar
Total Cats: -117
I would guess the tse cast mani would make more power earlier in the rpm band, but taper off in power, compared to a long tube header from Abe.
Old Apr 5, 2016 | 06:52 PM
  #678
Girz0r's Avatar
Total Cats: 323
Stock 2002 longblock
Trackspeed EFR6258 turbo system (347SS cast manifold, 3" downpipe)
Stock 2.25" NB2 exhaust
MS3 Basic
Flow Force 610cc injectors
5psi, intercooled
Quick dyno session today. Poor bottom end because I think it's blowing the wastegate open, but this chart is still worth showing.
Run 1 is with the stock 2.25" NB exhaust (peak boost 5psi)
Run 9 is with an Enthuza 3" stainless catted catback (peak boost 7psi)
The intercooler setup is a Precision 350hp with 2" coldside and 2.5" hotside pipes. The production intercooler will be a little smaller.
200whp on a BP05 longblock should take 10-11psi.
I don't have a baseline from my NB2, but Emilio was kind enough to shoot me a DRF file for a stock NB2 to compare.
Old Apr 6, 2016 | 04:04 PM
  #679
turbofan's Avatar
Total Cats: 1,087
These dynos don't really show anything in comparison to a long tube setup....
... but they do show that the power definitely does taper up top, even after they went to the 3" exhaust.
Ed@949Racing/Supermiata
www.949racing.com
Old Apr 6, 2016 | 04:25 PM
  #680
leboeuf's Avatar
Total Cats: 57
At 7psi... The efr is vaguely aware of its metaphysical star child existence at 7psi.
Sorry for the off topic garbage in your thread 99mx5!
