Fabulous Fabrication Post all your custom fabrication projects here; impress all your friends.
The custom fabrication thread! (Post pics of stuff you have made)
Old Jul 14, 2014 | 11:47 AM
  #801
HHammerly's Avatar
Total Cats: 63
Originally Posted by shuiend
I made my friend some extended tophats for his rear shocks. I spent zero time at all actually prepping the metal in a good fashion. Used a big hole saw to cut off the top of the tophat, welded a pipe in its place, then welded the top back on the pipe.
I have been making these for a while, spherical bearings on them, that extra suspension travel sure makes NA's much happier on rough tracks
Old Jul 24, 2014 | 12:06 PM
  #802
I got a huge muffler for an upcoming project.
Old Jul 24, 2014 | 12:37 PM
  #803
m2cupcar's Avatar
Total Cats: 372
I made my friend some extended top hats...
how much time does it take you to make those? they're perfect imo
Old Jul 24, 2014 | 12:40 PM
  #804
The actual welding of the tophats took about an hour, letting them cool off was the longest part. Getting the to that point was a pita because we did not have the proper tools. No clue how much time my friend actually spent cutting off the top of the stock tophat.
Old Jul 24, 2014 | 12:48 PM
  #805
I figure it wouldnt take much time at all if you had a drill press and a hole saw.
Old Jul 24, 2014 | 02:11 PM
  #806
m2cupcar's Avatar
Total Cats: 372
I feel inspired to try this with plasma cutter and welder in hand.
Old Jul 24, 2014 | 02:41 PM
  #807
shlammed's Avatar
Total Cats: 51
If you have a drill press, a hole saw and a welder, it would be super easy.
Drilling the caps out would take 10 minutes, prepping for weld would be about 15-20 minutes and welding them up would take about 20 minutes
Old Jul 24, 2014 | 03:05 PM
  #808
Schuyler's Avatar
Total Cats: 87
That thing is enormous.
Old Jul 27, 2014 | 02:18 PM
  #809
hornetball's Avatar
Total Cats: 697
Default Flywheel Locking SST for Cheap!
Having 2 Miatas and being a track addict, I seem to be assembling more engines than I used to. One part of assembly that was always a bit of a pain was torqueing the flywheel and crankshalf pulley bolts. Mazda has a SST (Special Service Tool) that locks the flywheel for this purpose. So, made my own out of some 1.25" angle iron. Pictures speak for themselves. I did the rivets and then went ahead and hit it with a welder. I don't know if rivets alone would have been sturdy enough.
Works great!
Attached Thumbnails The custom fabrication thread! (Post pics of stuff you have made)-img_0348.jpg   The custom fabrication thread! (Post pics of stuff you have made)-img_0349.jpg   The custom fabrication thread! (Post pics of stuff you have made)-img_0350.jpg
Old Jul 27, 2014 | 02:25 PM
  #810
Total Cats: 1,410
Just use two of the tranny bolts, thread one in to that top hole, and jam another against the bolt and a flywheel tooth. Works like a charm, and you don't have to find or have your tool.
Old Jul 27, 2014 | 02:53 PM
  #811
hornetball's Avatar
Total Cats: 697
Seriously? Arrrggghhh!!!
Old Jul 27, 2014 | 03:14 PM
  #812
Total Cats: 1,410
Yup, your tool is nice though.
Just have a socket for the pressure plate bolts ready, hold the bolt with one hand, and turn the flywheel with the socket on one of the pp bolts until the bolt is jammed against the other.
Old Jul 27, 2014 | 09:03 PM
  #813
I feel like the only person that just uses a second person the crank pulley bolt with a breaker bar to torque the flywheel or pp bolts (and of course impact gun to remove them).
Old Jul 27, 2014 | 09:11 PM
  #814
That is what I would figure also. Here is the story of the top hats. My friend wanted them welded up. He said he would be over one night with the stuff to be welded. I expected him to show up and have the top hats in hand with the pipes ready to roll. He shows up with the top hats still on the car. So had to remove them from there. He did bring a hole saw, but it was a shitty one and I only have a HF $9.99 drill. So drilling through them did not work well. They then took them to a friends house with a drill press. Unfortunately the hole saw was to messed up to make the cut. He took the top hats to his school and tried with a big *** drill press. Not sure why that failed. He then used some other tool and got the to hats into two pieces. The cuts were horrible and not very evenly around. So I did the best I could with what I was given on the welding.
Old Jul 28, 2014 | 02:40 AM
  #815
Pen2_the_penguin's Avatar
Total Cats: 97
I too, have been doing it wrong this whole time.
Old Jul 28, 2014 | 09:09 AM
  #816
m2cupcar's Avatar
Total Cats: 372
20 yrs ago I bought this for $8- no regrets:
Old Jul 28, 2014 | 10:40 AM
  #817
acedeuce802's Avatar
Total Cats: 175
My 3" downpipe! Don't have pictures yet of the manifold, but it's a simple log.
Old Jul 28, 2014 | 11:44 AM
  #818
scenturion's Avatar
Total Cats: 61
A different kind of fab, but I thought you all might enjoy it.
I bought a JDM 6-speed cluster for my NB.
I found that when using a US odometer unit, the speedometer wouldn't read right because the JDM speedometer tops out at around 190kph while the US speedometer is 260kph. The odometer drives the needle by angle, so it ended up being about 22% off from a true reading.
I taught myself some electronics and designed and built a custom circuit board that allows arbitrary scaling of the speedometer or tachometer. It reads the raw tach/vss signal from the cluster via a T-tap but doesn't require any permanent modification to the cluster. It's actually more accurate and has a faster response time than the stock gauges. On my cluster, I set it up to read mph rather than kph, so it's now a 180mph speedometer
The circuit is relatively simple: it implements a standalone air core motor driver and has a trimpot to fine-tune the scale while under way. It took about three board layout revisions to get the design perfect, but it works great now. On my cluster, I was able to get it within +/-1mph from GPS speed reading.
Old Jul 29, 2014 | 11:53 PM
  #819
shlammed's Avatar
Total Cats: 51
I'll post a picture here that I posted in my personal fab thread. Check out the rest of the work in my thread if you havent already.
HellaFab Miata Vband bottom mount manifold by HellaFab, on Flickr
I have an EFR manifold coming up next.
Old Jul 30, 2014 | 08:05 AM
  #820
TurboTim's Avatar
Total Cats: 425
Nice, that should work well. I like how you got close to equal length while still using large radius bends, good job Matt.
