Old Sep 23, 2015 | 12:03 PM
  #4081
hi_im_sean's Avatar
SadFab CEO
Total Cats: 1,143
It mixes itself inside the trans
Old Sep 23, 2015 | 12:05 PM
  #4082
Total Cats: 1,870
<p>
</p><p>Shut up, you know what I meant . 1 quart of each? Going to power dial concealer until he adds a quart to my order.</p>
Old Sep 23, 2015 | 12:23 PM
  #4083
ofspunk7's Avatar
I used 1qt of the syncromesh and the rest the AMSoil tranny fluid.
Old Sep 23, 2015 | 12:24 PM
  #4084
Total Cats: 1,870
<p>Back to arca_ex question, how come you can mix the 5w-30 and 75w-90</p>
Old Sep 23, 2015 | 12:30 PM
  #4085
ofspunk7's Avatar
It's easy. I follow the advice of a very knowledgeable person, since I am not expert on the subject matter. It has worked well for our applications. Sorry, that is all the SCIENCE I can provide on the matter.
  #4086
Total Cats: 1,870
<p>Hmmm, I need more science.</p>
Old Sep 23, 2015 | 12:34 PM
  #4087
ofspunk7's Avatar
Browsing what the Google Scientists have posted on the interwebs, I do see quite a few posts about this mixture on multiple car platforms. Not that this really means anything, but there is some reading that can be done.
Old Sep 23, 2015 | 12:35 PM
  #4088
Total Cats: 1,870
<p>I'm going to order a quart. And go from there. If it doesn't show up before the weekend then i definitely wont be running it.</p>
Old Sep 23, 2015 | 12:45 PM
  #4089
Total Cats: 3,588
Because diff/trans oil is measured by a different scale than engine oil. 80w trans oil and 80w engine oil are not the same thickness. Sounds odd but it is true because engineers.
Old Sep 23, 2015 | 12:54 PM
  #4090
M.Adamovits's Avatar
Total Cats: 23
They're not too far off.
Attached Thumbnails Aidan's loose oily bunghole actually runs a track lap-table_5_viscosity_comparison_chart.jpg
Old Sep 23, 2015 | 12:57 PM
  #4091
Total Cats: 3,588
I don't want to hear anyone complaining about their transmission not working well with this fluid or that fluid when they get hot and you don't have any heat shields around the exhaust. Even the factory shields the transmission from the exhaust at 100ish horsepower. Double or triple that and you are making 2 or 3 times the heat.
Wouldn't it be 2 or 3 times more important to shield it?
Y'all don't hear me.
/Andre3000
Old Sep 23, 2015 | 12:58 PM
  #4092
Total Cats: 1,870
<p>Picture of said heat shield?</p>
Old Sep 23, 2015 | 01:06 PM
  #4093
hi_im_sean's Avatar
SadFab CEO
Total Cats: 1,143
I understand aarons sentiment, but automatics running water for fluid go 100s of 1000s without gear wear issues. Not that that proves anything, but it's good enough for me.
Old Sep 23, 2015 | 01:08 PM
  #4094
patsmx5's Avatar
Total Cats: 559
Default Transmission Heat Shield Thread
https://www.miataturbo.net/general-m...-thread-86007/
Old Sep 23, 2015 | 01:34 PM
  #4095
Total Cats: 1,870
<p>Thanks pat.</p><p>Sean, do you remember the thread pitch for the intercooler mounting bosses? I want to order some rubber insulating thingies from mcmaster.</p>
Old Sep 23, 2015 | 01:37 PM
  #4096
hi_im_sean's Avatar
SadFab CEO
Total Cats: 1,143
M8x1.25
  #4097
Total Cats: 1,870
<p>Hmmm, i thought they were SAE for some reason.</p>
Old Sep 23, 2015 | 01:42 PM
  #4098
Total Cats: 1,870
<p>Going to buy 3 of these&nbsp;its something I've been meaning to do forever and keep holding off.</p>
Old Sep 23, 2015 | 02:30 PM
  #4099
Total Cats: 1,870
<p>Ordered. I'm blaming you if they don't fit sean.</p>
Old Sep 23, 2015 | 02:37 PM
  #4100
hi_im_sean's Avatar
SadFab CEO
Total Cats: 1,143
This is the internet, I cant be wrong.
