COP Thread
Old Nov 13, 2007 | 10:32 AM
  #741
Ben's Avatar
Ben
Total Cats: 134
Flippy's car runs fine.
scope your ignition output. you have a car that's not available here.
Old Nov 13, 2007 | 10:57 AM
  #742
Bronze's Avatar
Ben or Braineack,
Any ideas on my problem? Could it be a ground or my wiring? When I switch back to the plug wires it runs just fine and the idle is nice and smooth.
Old Nov 13, 2007 | 02:11 PM
  #743
jrmotorsports55's Avatar
Total Cats: -50
I'm going to go ahead and try to wire mine up in the next few weeks. I'll let you all know the results.
Old Nov 13, 2007 | 02:28 PM
  #744
Total Cats: 4,370
Originally Posted by Bronze
Ben or Braineack,
it should work with the stock ecu if you follow the diagram.
but:
the brown wire splits for the 2 & 3 trigger; brown/yellow splits for the 1 & 4 trigger
black is a shared ground
blue is the 12v source
yellow/blue is the tach output, you need to attach the black/white to this lead for a 1v source to power the signal.
that's it.
Old Nov 13, 2007 | 02:41 PM
  #745
Ben's Avatar
Ben
Total Cats: 134
did you get that from a good wiring diagram? I thought I remembered on Dan's car brown/yellow was the 2-3 coil trigger and brown was 1-2. Might be mistaken.
Old Nov 13, 2007 | 02:56 PM
  #746
Total Cats: 4,370
it's that way all the way to 2005...dunno why after the first 3 years they'd swap it. I used the same.
when i was building the MSs I was reversing the output inside the CPU itself, so on the harness it will look different.
Old Nov 13, 2007 | 04:59 PM
  #747
y8s's Avatar
y8s
DEI liberal femininity
Total Cats: 574
umm
Old Nov 13, 2007 | 05:06 PM
  #748
Ben's Avatar
Ben
Total Cats: 134
Again, that was from MEMORY. I wasn't looking at his car when I wrote that, as I'm not looking at it now. I just thought I remembered the yellow stripe coil was the dead one.
Not all of us can be cool like you with 4 triggers.
Old Nov 14, 2007 | 12:25 AM
  #749
Stitches's Avatar
awesome
Old Nov 14, 2007 | 06:13 AM
  #750
Bronze's Avatar
Well, I checked grounds and wire harness three times last night and it was perfect. Stupid me finally decided to check the coils and the number 3 coil wasn't firing. So just to check the harness and coil I swapped it with the number 1 and it still wasn't firing. I guess I got a bad coil and will have to go searching again. Thanks for all your help guys.
Old Nov 14, 2007 | 10:22 AM
  #751
y8s's Avatar
y8s
Total Cats: 574
ummm = look closer at what you said.
Old Nov 14, 2007 | 10:30 AM
  #752
Ben's Avatar
Ben
Total Cats: 134
oh,
maybe that explains why is car doesn't run
good eyes.
Old Nov 16, 2007 | 08:14 PM
  #753
MiaTurbo's Avatar
Just scored a set off of a 2000 Celica GT...
Old Nov 16, 2007 | 09:27 PM
  #754
jasonrobo02's Avatar
I was really hoping nobody would see those and I could grab them for $10. But oh well.
Old Nov 17, 2007 | 12:16 AM
  #755
Ben's Avatar
Ben
Total Cats: 134
For auctions on ebay like that, I see no problem with a post here stating your intention to bid and your max price. That way we don't bid against each other.
Old Nov 22, 2007 | 09:46 AM
  #756
Jefe's Avatar
And as I suspected, 90-93 ecu pins fit on the cops' terminals perfectly. I'm just going to make my own harness, and suggest others do the same. Hoping that I can find a local source for the pins. Tyco has a minimum order of 1000.
Next step is finding spades for the ignitor side.
Thanks for the tip!
FWIW: the Emanage pins are the same as the stock ECU pins (That's how I made my EMB semi PNP)
Old Nov 22, 2007 | 11:56 AM
  #757
Total Cats: 4,370
Jeff, you're so out of the loop. I've been selling these pins to members fors weeks now.
Old Nov 22, 2007 | 11:58 AM
  #758
cjernigan's Avatar
Total Cats: 7
Mine. Up to $70
http://cgi.ebay.com/ebaymotors/4-Use...spagenameZWDVW
Old Nov 22, 2007 | 07:45 PM
  #759
Jefe's Avatar
I know, but it's tough to stay on top of it all... The technological break throughs that keep occuring on this forum are too fast for old guys like me...
This has to be one of the longest threads on this forum?
Old Nov 23, 2007 | 12:27 PM
  #760
MiaTurbo's Avatar
yeah, I agree. There is a wealth of info in this thread. It's easy to skip over something...
