Building a blonde young beefcake wearing nothing but skimpy shorts named Rocky
Old Sep 5, 2012 | 03:46 PM
  #701
miatauser123's Avatar
Total Cats: 68
Originally Posted by 18psi
I think its beyond retarded to waste money on single digit dragster parts only to bolt them up to a BP.
Right - There is "Man stuff" or reasonable and smart. The way I look at it… Sure.. I could dump 5-6K making my Miata drive line more drag strip reliable. Or maybe I could spend that money on a complete and mechanically sound, track prepped shifter cart and half a season worth of tires and amazingly good times... Maybe..
Old Sep 5, 2012 | 03:51 PM
  #702
thenuge26's Avatar
Total Cats: 239
Or you could even buy a fox body 5.0 or an f-body camaro/firebird and mod it to go as fast in a 1/4 as your miata for close to that money if you really like drag racing.
Though I bet half of the fun is surprising said fox body 5.0s in your miata.
Old Sep 5, 2012 | 04:18 PM
  #703
Total Cats: 68
Exactly. The surprise factor is the biggest kick at a drag strip. I've even had the announcer mouth off a little as I approached the staging lanes.. He quickly changed his tone.
Some of the best times I've had with the car have been on a road course though. Smash most cars in the turns and smash the rest of them on the straights. It's a real kick when 5-6 owners of modified Corvettes wonder over to the car after the first session. They usually all say the same thing.. "What the %$# is in that thing?"
Old Sep 5, 2012 | 04:47 PM
  #704
573's Avatar
573
Total Cats: 17
Oh dear god shifter carts give me a boner. Yeah, do that.
Old Sep 7, 2012 | 11:31 AM
  #705
Total Cats: 68
So I've decided that waiting for a diff housing only to break it again was not really in the list of things I'd like to do. Ultimately I’d like to swap the Cobra rear end but that can happen over the winter.
I have not seen anyone repair a diff housing before and it's probably for a couple of good reasons:
1. They are cheap to replace.
2. It's cast aluminum rendering it rather weak and difficult to repair
So I shall repair. I started by simply cleaning up the area with a gasket removal bit.
Since this is 100% structural I used a grinding bit to bevel into the material for the best weld penetration.
There was also a hairline crack that I dug into for repair.
To strengthen the structure I’ve picked up aluminum plate to box in the I beam structure. This should leave the assembly stronger than before. You can see to begin; I’ve taken a flat file to create a flat mating surface for the new metal.
I’ll bring it to my guy tonight to have it welded up.
With that set aside, I tightened down my fuel rail and wanted to check my fuel system for leaks. I still needed to complete the return line by removing it from the “evap” canister thing and running it to the return tube on the tank.
This is a bit hard to explain but the smaller “return” line I’ve used was put in place for the EVAP system, meaning it does not go to the return on the fuel tank. Instead it goes to a charcoal canister for filtering. So it must be disconnected and run to the fuel tank as a return line.
I’ve created this illustration to show exactly how the routing ended up. Where is my +1 naow. I didn't make this for me guys
And bam – We’ve got fuel.
Attached Thumbnails Building a blonde young beefcake wearing nothing but skimpy shorts named Rocky-2e8732e8.jpg   Building a blonde young beefcake wearing nothing but skimpy shorts named Rocky-c4983a08.jpg   Building a blonde young beefcake wearing nothing but skimpy shorts named Rocky-f162d7d5.jpg   Building a blonde young beefcake wearing nothing but skimpy shorts named Rocky-f8e0ddfb.jpg   Building a blonde young beefcake wearing nothing but skimpy shorts named Rocky-a3b52bec.jpg
Building a blonde young beefcake wearing nothing but skimpy shorts named Rocky-b2c25146.jpg   Building a blonde young beefcake wearing nothing but skimpy shorts named Rocky-d9477e69.jpg
Old Sep 7, 2012 | 11:36 AM
  #706
I knew your "original" routing was too good to be true lol.
Also curious to see how the welded carrier will hold up to 400whp
Old Sep 7, 2012 | 12:11 PM
  #707
RyanRaduechel's Avatar
Total Cats: 149
It'll probably be stronger than the rest of it and it will break somewhere else. Thats my guess anyways
Old Sep 7, 2012 | 12:52 PM
  #708
Total Cats: 68
Well I'm less concerned about it breaking now because I've installed the Beatrush brace, essentially allowing only minimal movement from the differential.
I've also considered boxing in the other side.
Old Sep 7, 2012 | 01:16 PM
  #709
I'd consider doing both too: I bet you a good beer the other side will snap within weeks just like Ryan says with such a large difference in strength
Old Sep 7, 2012 | 04:07 PM
  #710
vehicular's Avatar
Total Cats: 47
If you don't box the other side, you're just going to end up boxing it later when it breaks. I would do both sides, the whole length of the arm.
Actually, I would just throw it away and get one that isn't broken :/
Old Sep 7, 2012 | 05:16 PM
  #711
Total Cats: 1,924
I'm glad to see I'm not the only one who had to modify their M-Tuned fuel rail to get it to fit.
About the fuel system... So you ended up with these adapters?
Russell Line Adapter 5/16 to -6 AN 644113 x1
Russell Line Adapter 1/4 to -6 AN 641303 x1
also:
I'm sure there is more to it than just hooking the return side of the regulator to the vapor port and bypassing the carbon canister. Any chance you have some pictures of this procedure and routing around the canister? I'm retarded and do better with pictures, plus I like knowing what I'm getting into.
I love visiting this thread, it akes me feel that much better about my mess. You have an impossibly clean NB, me likes! Keep up the good work!
Old Sep 13, 2012 | 02:24 PM
  #712
Total Cats: 68
Old Sep 13, 2012 | 02:54 PM
  #713
Fireindc's Avatar
Total Cats: 905
Sounds beast. Have you done any tuning yet? In for WOT pulls
Old Sep 13, 2012 | 03:14 PM
  #714
viperormiata's Avatar
Total Cats: 283
in 4 glory
Old Sep 13, 2012 | 06:14 PM
  #715
oh yes
gettn antsy in my pantsy
Old Sep 13, 2012 | 08:35 PM
  #716
Total Cats: 1,410
Hmm, you can see some disturbing vibration in the wastegate right at the end. Just sayin'.
Old Sep 13, 2012 | 09:24 PM
  #717
Total Cats: 68
You're a disturbance... The diff and the PPF brace are loose...
Old Sep 13, 2012 | 11:35 PM
  #718
Faeflora's Avatar
Total Cats: 130
OMGZ ur just like me!! I leave mine kinda loose and slutty too.
Old Sep 25, 2012 | 04:57 AM
  #719
Erat's Avatar
Total Cats: 830
I'm going through withdrawls here.
Old Sep 25, 2012 | 11:46 AM
  #720
Fireindc's Avatar
Total Cats: 905
How dare you bump this thread, Erat. I came here to fap to updates and now i'm left with blue *****.
