Shuiend blows motor #5; Naturally Aspirated Glory Incoming
Old Mar 29, 2011 | 01:44 PM
  #561
Originally Posted by TurboTim
What's those jagged spikes/drops in the duty cycle/pulse width?
The AFR changes a little bit. Goes from 11.5:1AFR to 12.1AFR briefly and that caused the spikes. The tune still needs a lot of time spent on it.
Old Mar 29, 2011 | 02:18 PM
  #562
TurboTim's Avatar
Total Cats: 425
Soo it's closed loop feedback that's making the changes?
I'm scared to run closed loop at WOT. I did it once and got something similar to your spikes but more violent, fortunately I let off before any damage.
Old Mar 29, 2011 | 02:19 PM
  #563
closed loop should be off in boost...
Old Mar 29, 2011 | 02:20 PM
  #564
TurboTim's Avatar
Total Cats: 425
I'll tend to agree...Larz?? Something's causing those injector pulse widths to change.
Old Mar 29, 2011 | 02:26 PM
  #565
y8s's Avatar
y8s
DEI liberal femininity
Total Cats: 574
those pulsewidth block changes are accel enrichment. raise the thresholds for MAP and TPS sensitivity.
incidentally, I love running closed loop in boost. y'all too paranoid.
Old Mar 29, 2011 | 03:13 PM
  #566
I really think it has to do with how the 4 fuel cells that it is passing through at those points are tuned. Right now they are really rough and that is causing it to go slightly lean. Below is what my fuel table currently looks like. The 4 boxes that are grey are where it is when those spikes occure. I think the one that has 177 in it just needs a little bit more fuel.
I was also AutoTuning with VEAL on during this time.
Old Mar 29, 2011 | 03:33 PM
  #567
ismael_pt's Avatar
check for bit 7/8 in mlv, those flags indicate when the accel enrichments kicks in
Old Mar 29, 2011 | 03:43 PM
  #568
y8s's Avatar
y8s
Total Cats: 574
MAP based enrichment was kicking in. we had him set accel to 100% TPS based to avoid MAP noise causing enrich/enleanments.
Old Mar 29, 2011 | 04:43 PM
  #569
JasonC SBB's Avatar
Total Cats: 84
He needs my "2 pole" MAP filter circuit.
Old Mar 29, 2011 | 04:58 PM
  #570
the software has built in filtering, he just needs to apply it.
Old Mar 29, 2011 | 07:23 PM
  #571
Faeflora's Avatar
Total Cats: 130
What happens if you smooth those cells out? That's a pretty big hole.
Old Mar 29, 2011 | 08:13 PM
  #572
ismael_pt's Avatar
I have found that filtering only applies to the MAP value but not for the mapdot, wich triggers the enrichments when they are MAP based. Unless this was fixed in MS3, the quickest way to fix the problem is using a small fuel filter to damp the fast changes in MAP signal.
http://image.made-in-china.com/2f0j0...lter-GF61-.jpg
Old Mar 30, 2011 | 11:46 AM
  #573
I just had Tim order me a new black BOV. Hells Yah.
Old Mar 30, 2011 | 11:56 AM
  #574
bling. hows thats part time job working out for you?
Old Mar 30, 2011 | 12:01 PM
  #575
It provides ramen noodles for food and absurdflow goodness for my car. Everyone can see where my priorities are.
Old Mar 30, 2011 | 12:08 PM
  #576
Gryff's Avatar
Total Cats: 16
^ LOL so theyre the same as my priorities then!
Old Mar 30, 2011 | 12:46 PM
  #577
TurboTim's Avatar
Total Cats: 425
Those are wastegates bud. You want this, right? Ask Trey what spring to get.
Old Mar 30, 2011 | 12:50 PM
  #578
Wow Tial totally has the wrong picture sitting on their website for the Tial Q BOV for available finishes. That is where I stole the picture from.
Old Mar 30, 2011 | 07:20 PM
  #579
Yes or no to mounting my MS3 on the rear shelf?
Old Mar 30, 2011 | 07:24 PM
  #580
Spool on the ChinaCharger is definitely a little slower then I would like. In a 4th gear pull in my 6speed I have 100kpa at 2800rpms and get to 200kpa at 5800rpms. It makes me a little sad. But damn does it still pull. I do not have VVT up and running yet so hopefully when I get that setup it helps the spool out a good bit.
HOLY FAIL BATMAN
I don't know wtf is up with that churbo of yours, but something aint right
